POV-Ray : Newsgroups : povray.binaries.images : Still Life with Limes III (WIP) Server Time
4 Aug 2026 16:56:41 EDT (-0400)
  Still Life with Limes III (WIP) (Message 11 to 15 of 15)
Subject: Re: Still Life with Limes III (WIP)
Date: 1 Jun 2004 10:57:08
Message: <40bc9943@news.povray.org>
Aaron Gillies wrote:
> POV folks:
> Here is the latest iteration on my limes still life.  I have incorporated
> the suggestions that I got from the last couple of postings into this one.
> The limes are a better color and shape, although the shape is not perfect.
> I toned down the vivid red in the ceramic pot.  I think I'm making some
> progress ...
much better limes. the floor texture looks like it has less of a normal this
time. I like the version 2 floor better. maybe it's due to the change i
camera placement though.
I wonder how you could make the shadows of the limes to be the complimentary
color, like cezanne did so often in his still lifes.
Date: 1 Jun 2004 18:31:03
Message: <40bd03a7@news.povray.org>
Ross Litscher nous apporta ses lumieres ainsi en ce 2004/06/01 06:55... :
>>POV folks:
>>progress ...
A light_source with the projected_through property. Make a second
no_image copy of your object, flaten it perpendicular to the light,
locate it a bit behind the main object and have the project_through
light coincide with your primary light. Give that light the colour you
want for the shadow, like bright red.
Date: 1 Jun 2004 21:51:35
Message: <40bd32a7$1@news.povray.org>
Hmmm .... I changed the finish on the floor to be less reflective, because I
increased the intensity of one of the light sources and it made the floor
too "noticeable."  I'll try to see what else I can do ...
As far as the Cezanne effect goes ...  I am doing on variation on this, but
not with complimentary colors.  One light source is yellow and the other is
blue ...  The blue provides the "cooler" illumination in the shadow, but I
suppose something like this could be reversed ...  It's very subtle, but
serves to "round out" the image in a way.
Aaron
this
complimentary
Date: 2 Jun 2004 12:40:42
Message: <40be030a$1@news.povray.org>
"Alain" <aze### [at] qwertygov> wrote in message
news:40bd03a7@news.povray.org...
> >>POV folks:
incorporated
one.
perfect.
> >>progress ...
this
complimentary
> Alain
cool. i've never played with those features. thanks for the tip. i'm not
sure why you have to flatten the no_image copy. i guess i'll wait and see
when i get home :)
can multiple "projected_through { OBJECT }" statements be inside a
light_source, or would i have to declare a union {...} around all the
objects i want to use? Also, i'm curious why no_image is neccesary (again,
i've never used it). projected_through documentation states, "Any textures
or interiors on the object will be stripped and the object will not show up
in the scene."
of course, this all may become obvious later when i try it out.
Date: 2 Jun 2004 17:22:37
Message: <40be451d$1@news.povray.org>
Ross nous apporta ses lumieres ainsi en ce 2004/06/02 12:40... :
>>>>POV folks:
>incorporated
>one.
>perfect.
>>>>progress ...
>this
>complimentary
>>Alain
>when i get home :)
>light_source,
don't know... but
Puting all objects in an union will make it simpler for you, less
chances to make errors. It can also reduce memory use.
>in the scene."
OK, I forgot about that bit of information. So, you don't need to add
the "no_image" as it's added by the projected_through.
If you don't flaten the object, it can cause the projected_through light
to shine on some part of the visible object if those are behind any part
of the one used to do the projection. You may also keep only those
components that are the most away from the light_source.
