POV-Ray : Newsgroups : povray.binaries.images : Raytraced luminous color bleeding (80kb jpeg) Server Time
4 Aug 2026 15:33:37 EDT (-0400)
  Raytraced luminous color bleeding (80kb jpeg) (Message 14 to 23 of 23)
Subject: Re: Raytraced luminous color bleeding (80kb jpeg)
Date: 25 Jun 2004 15:27:59
Message: <40dc7cbf@news.povray.org>
Samuel Benge wrote:
> Hello everyone. Today I made a scene file which
 > takes an image and applies a 'bloom' effect to
 > the bright parts.
Did you do this by rendering a grayscale map with something like [.5 rgb
0][.5 rgb 1] blurring the map, and then combining the blur, the original
map, and the original image? (hope that made sense)
...or, is this a one-step process? For the record, I don't see anything
procedural/repeatable as unacceptable post-processing.
  -Shay
Date: 25 Jun 2004 18:04:32
Message: <40dca170$1@news.povray.org>
Samuel Benge wrote:
> Hello everyone. Today I made a scene file which takes an image and
> applies a 'bloom' effect to the bright parts. The example attached is a
> bit overdone to show the results. I can control which values in the
> image are active.
> I think that this technique is probably okay to use in the IRTC, but I
> wonder if it would be considered a post-processing step or not....
> Happy raytracing~
> -Sam Benge
Congratulations, clever technically and pleasing visually.  Is it my
imagination or is diffused atmosphere in photos becoming so popular
lately as to practically define current visual style.  Like in ads, TV,
movies, photo-art, etc., etc.
Date: 25 Jun 2004 21:34:20
Message: <40dcd29c@news.povray.org>
> it my imagination or is diffused atmosphere in photos becoming
> so popular lately as to practically define current visual style.
> Like in ads, TV, movies, photo-art, etc., etc.
The Bruckheimer effect.
 -Shay
Date: 25 Jun 2004 22:10:38
Message: <40DCDAB9.80306@hotmail.com>
Jeremy M. Praay wrote:
<snip>
> Incredible work!  :-)
Thanks!
> Only if it can be done in one step.  It sounds like it's a 2 part process
> (render scene then take image and add bloom effect), which could disqualify
> it, since it's done through the renderer.
Since POV-Ray has so many options (as a programming language), it might
be possible to link the post-processing file to execute right after a
render is complete. I'll have to look into that....
> Now having said all of that, I'll say that I actually hate IRTC
> post-processing rule discussions...  bleh
Me too.
-Sam
Date: 25 Jun 2004 22:18:57
Message: <40DCDCAB.2010308@hotmail.com>
It does, and it's almost completely correct. There are two planes. One
has the original image, and it remains unharmed. The second plane is
above the first one. It contains the blurred highlights using parts from
the original image. All darker portions are transparent. The upper and
lower values are controlled in a pigment_map, and allow for a smooth
transition from transparent color to image-based color. (if that made
any sense :)
-Sam
Date: 25 Jun 2004 22:23:12
Message: <40DCDDAA.5030905@hotmail.com>
Thanks
> Is it my
It adds an extra dimension of realism to an image at low overhead. Cheap
to render; worth the extra time for some renders. I'll end up using it
in too many of my renders for a while, eventually learning when *not* to
use it :)
-Sam
Date: 26 Jun 2004 06:23:31
Message: <40dd4ea3@news.povray.org>
> image are active.
This reminds me of my Glare-Include I've written a while ago. What I did was
to render the scene with Black-Textures and Specular-Highlights only, then
calculate the position for the Glare-Image in-scene. Using average-pattern,
I blurred the image a little and thus got me the glaring effect.
Do you use the colored output of your image as input for the blooming
effect?
Tim
"Tim Nikias v2.0"
Date: 26 Jun 2004 12:54:25
Message: <40DDA9DA.3060101@hotmail.com>
That would be perfect for ocean scenes and rolex scenes :) I can't
imagine lining the image up 'in scene' though... sounds very difficult.
Can you post a link to an example of your technique?
> effect?
Yes. I have to first place the #declared image_map inside a
pigment_pattern block, which makes it grayscale. With that map I am able
to make the darks parts transparent and the light parts colored with my
original image_map. I blur the result over a plane with the original
image_map, untouched. I am thinking of releasing the code, but it has to
be cleaned up quite a bit.
-Sam
Date: 26 Jun 2004 19:50:52
Message: <40de0bdc$1@news.povray.org>
was
then
average-pattern,
It's in my Download-Section:
http://www.nolights.de/download.html#Glare Macros
What I do is just a little arithmetic: take the camera's location and
look_at (along with right, up, and sky) and calculate the viewing frustrum
from that. Place a quad (two triangles) in the line of sight with the
described image_map-function, and there you go! You can have a look at the
source if you like. But linking to my Download-Section should imply that.
"Tim Nikias v2.0"
Date: 28 Jun 2004 05:53:05
Message: <40dfea81$1@news.povray.org>
> image are active.
   It's a very nice effect, and the scene you used for the test is also
beautiful and very apropiated.
   I think it is clearly a postprocessing filter, but it is allowed as
it is done by the same renderer. If you do it automatically using a two
pass technique it's perfectly "legal". Other thing is if the judges will
detract point for it not being a "true" 3D effect... I will not, as I
see it as a very creative use of the renderer, wich is what the spirit
of the competition is all about, IMHO.
   Indeed, congrats: I see your inspiration is coming back!
Jaime
