POV-Ray : Newsgroups : povray.binaries.images : Raytraced luminous color bleeding (80kb jpeg) Server Time
4 Aug 2026 15:33:38 EDT (-0400)
  Raytraced luminous color bleeding (80kb jpeg) (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Raytraced luminous color bleeding (80kb jpeg)
Date: 25 Jun 2004 09:00:02
Message: <cbh7i2$50e$1@chho.imagico.de>
Norbert Kern wrote:
>>I think anyway that this is posprocessing because it is applied on a 2d
>>image and not in a 3d scene
> What, if you make an animation with two images - first the actual render,
> then afterwards the "postprocessing" using the first frame?
The problem is quite simple. What you do this way is circumventing the
rules of the IRTC.  This is fine IMO but it should lead to the rules
being modified to be more precise and allow less 'tricks' to circumvent
them.  Since the IRTC rules have not been changed at all recently post
processing with external tools is now in fact allowed.  This is not bad
per se but the rule is a joke then and should be removed.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 25 Jun 2004 13:30:04
Message: <40dc611c@news.povray.org>
news:cbh7i2$50e$1@chho.imagico.de...
I think that the spirit of the original rule is to prevent photoshopping,
because otherwise it would be impossible to prevent obviously unacceptable
(*) modifications of a rendered image, like painting new elements by hand.
Perhaps the rule could just be altered by stating that the image generation
(rendering + ant not-rendered effect) should be done with the same program.
This would prevent the use of paint programs while officially authorising
post-processing when done with built-in features of the renderer, including
SDL-based post-processing.
The phrase:
"Images must not be enhanced or altered ('post-processed') by use of paint
programs such as PhotoShop(tm) etc."
could then be replaced by:
"Images must not be modified by use of a program other than the original
renderer".
G.
(*) in the context of a rendering competition of course
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 25 Jun 2004 14:40:01
Message: <cbhrg2$8bb$1@chho.imagico.de>
This would surely be much clearer than the current rule.  The difference
between post processing the image in photoshop and doing the same post
processing in an awfully slow and memory intensive SDL based system is
quite academic though.  But unless you want to completely remove the
post processing rule this probably is the clearest line that can be drawn.
Date: 25 Jun 2004 15:27:59
Message: <40dc7cbf@news.povray.org>
Samuel Benge wrote:
> Hello everyone. Today I made a scene file which
 > takes an image and applies a 'bloom' effect to
 > the bright parts.
Did you do this by rendering a grayscale map with something like [.5 rgb
0][.5 rgb 1] blurring the map, and then combining the blur, the original
map, and the original image? (hope that made sense)
...or, is this a one-step process? For the record, I don't see anything
procedural/repeatable as unacceptable post-processing.
  -Shay
Date: 25 Jun 2004 18:04:32
Message: <40dca170$1@news.povray.org>
Samuel Benge wrote:
> Hello everyone. Today I made a scene file which takes an image and
> applies a 'bloom' effect to the bright parts. The example attached is a
> bit overdone to show the results. I can control which values in the
> image are active.
> I think that this technique is probably okay to use in the IRTC, but I
> wonder if it would be considered a post-processing step or not....
> Happy raytracing~
> -Sam Benge
Congratulations, clever technically and pleasing visually.  Is it my
imagination or is diffused atmosphere in photos becoming so popular
lately as to practically define current visual style.  Like in ads, TV,
movies, photo-art, etc., etc.
Date: 25 Jun 2004 21:34:20
Message: <40dcd29c@news.povray.org>
> it my imagination or is diffused atmosphere in photos becoming
> so popular lately as to practically define current visual style.
> Like in ads, TV, movies, photo-art, etc., etc.
The Bruckheimer effect.
 -Shay
Date: 25 Jun 2004 22:10:38
Message: <40DCDAB9.80306@hotmail.com>
Jeremy M. Praay wrote:
<snip>
> Incredible work!  :-)
Thanks!
> Only if it can be done in one step.  It sounds like it's a 2 part process
> (render scene then take image and add bloom effect), which could disqualify
> it, since it's done through the renderer.
Since POV-Ray has so many options (as a programming language), it might
be possible to link the post-processing file to execute right after a
render is complete. I'll have to look into that....
> Now having said all of that, I'll say that I actually hate IRTC
> post-processing rule discussions...  bleh
Me too.
-Sam
Date: 25 Jun 2004 22:18:57
Message: <40DCDCAB.2010308@hotmail.com>
It does, and it's almost completely correct. There are two planes. One
has the original image, and it remains unharmed. The second plane is
above the first one. It contains the blurred highlights using parts from
the original image. All darker portions are transparent. The upper and
lower values are controlled in a pigment_map, and allow for a smooth
transition from transparent color to image-based color. (if that made
any sense :)
-Sam
Date: 25 Jun 2004 22:23:12
Message: <40DCDDAA.5030905@hotmail.com>
Thanks
> Is it my
It adds an extra dimension of realism to an image at low overhead. Cheap
to render; worth the extra time for some renders. I'll end up using it
in too many of my renders for a while, eventually learning when *not* to
use it :)
-Sam
Date: 26 Jun 2004 06:23:31
Message: <40dd4ea3@news.povray.org>
> image are active.
This reminds me of my Glare-Include I've written a while ago. What I did was
to render the scene with Black-Textures and Specular-Highlights only, then
calculate the position for the Glare-Image in-scene. Using average-pattern,
I blurred the image a little and thus got me the glaring effect.
Do you use the colored output of your image as input for the blooming
effect?
Tim
"Tim Nikias v2.0"
