POV-Ray : Newsgroups : povray.binaries.images : WIP: looking in Server Time
5 Jun 2026 02:19:44 EDT (-0400)
  WIP: looking in (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: looking in
Date: 26 Aug 2002 05:37:35
Message: <3D69F6C2.9080206@ibras.dk>
> Thanks for the suggestion, darkening the outside does seem to fit very well
> with the theme of the picture: I've given the light from the outside light a
> lot of fade so that it's presence doesn't give that bright flood-lit effect
> of the previous example.
I'm watching this on a cheap TFT-screen, so I could be wrong, but the
shadows still seems too bright. If you are using ambient, try turning it
down or off, so the shadows becomes almost black.
> Something about the window frame now looks a bit
> false now though but I can't place my finger on it so can't fix it!
As I see it, the window lacks a frame :-). It only has a sash. OK, I'm
not sure about the naming of the various parts, but usually a window has
  fixed part mounted on the wall (the frame?) and a moving part hinged
to the frame (the sash?) in which the glass pane is mounted. The frame
and sash could be about the same thickness (5-6 cm) but the parts, that
divide up the pane (muntins?) should only be about half that thickness.
Also the outside window sill should slope downwards, to avoid
accumulating rain water, that will rot the window frame.
/Ib
http://www.ibras.dk
Date: 26 Aug 2002 06:17:29
Message: <3d6a0039$1@news.povray.org>
"Ib Rasmussen" <ib### [at] ibrasdk> wrote in message
news:3D6### [at] ibrasdk...
I see it like you, overall lack of contrast. Maybe higher assumed_gamma
would help. Active matrix TFT LCD here too, and also cheap ;-)  Anyway, I
don't think that's the reason.
Date: 26 Aug 2002 08:44:33
Message: <3d6a22b1@news.povray.org>
I've gone through and put "gamma 0" everywhere where it might need it!
Hopefully that'll help it. I think my moniter must be darker than most,
although I never managed to work out what the display-gamma actually is for
this machine.
I'll repost it once I've remodelled the window, I'd like to get this
contrast sorted as a contrast is an important part of the "feel" that this
picture is meant to have.
"hughes b" <omn### [at] charternet> wrote in message
news:3d6a0039$1@news.povray.org...
Date: 26 Aug 2002 09:13:43
Message: <3d6a2987@news.povray.org>
"John Vodden" <jav### [at] gmxcouk> wrote in message
news:3d6a22b1@news.povray.org...
for
> this machine.
gamma 0? Not sure you are talking about POV-Ray and might be setting it in a
image editor instead? I meant global_settings {assumed_gamma 2.2} or more
than the 1.0 as suggested in the help and the default Insert Menu.
Have you seen the Scene Help section 5.2.2.2.2 (yes, that's the numbers)
yet? Should be able to get an idea of what to use for Display_Gamma in
pov-ray\renderer\povray.ini, although I still don't set assumed_gamma to 1.0
and either leave it out or make it 2.2 as well. It's still a confusing issue
to me too, I can't readily check image output on various monitors to see
what the changes might be.
Date: 26 Aug 2002 09:36:54
Message: <3D6A2ED5.2080307@ibras.dk>
That should be "ambient 0" I hope. As hughes b writes, gamma should only
be set once, and not to 0. I should be 2.2 for pcs and 1.0 for macs, IIRC.
You can use the attached image for a simple gamma adjustment of your
monitor. The center of each colour field should appear the same as the
frame, if your screen is set correctly.
/Ib
Download 'gamma.gif' (3 KB)
Preview of image 'gamma.gif'
Date: 26 Aug 2002 09:51:52
Message: <3d6a3278$1@news.povray.org>
It looks like it is ambient values to me as well.
Put the following at the top of the scene file:
global_settings {
  ambient_light rgb 0
And then go through and pull out all of the ambient
settings in the finish part of the textures.
Aaron
Aaron Gillies
New York City
x3rxes[*]yahoo.com
Date: 26 Aug 2002 13:49:20
Message: <3d6a6a20@news.povray.org>
My bad, I had "gamma" on the from brain talking about the display gamma... I
meant "ambient 0" (which is what I've put in there in response to "If you
are using ambient, try turning it down or off")
I'll play with that gamma image and see if I can get it right. Attempts I've
had with "gamma.gif" in the past to determine precisely the display_gamma of
my machine (as described in the help file) haven't seemed to work.
Currently I've got display_gamma as 2.2 (the default I believe and
recommended for PCs) and assumed_gamma 1.0 for the image.
Date: 26 Aug 2002 13:54:55
Message: <3d6a6b6f@news.povray.org>
"Aaron Gillies" <no### [at] spamcom> wrote in message
news:3d6a3278$1@news.povray.org...
> global_settings {
>   ambient_light rgb 0
Ah, I see the problem.
Help file section 6.11.2 says : "The default is a white ambient light source
set at rgb <1,1,1>"
I had assumed that it was rgb 0 if unspecified, which is apparently not the
case. It doesn't help that I seem to keep my moniter rather dark too so it
didn't show up that badly for me.
Date: 26 Aug 2002 18:06:19
Message: <3d6aa65b@news.povray.org>
news:3d6a6a20@news.povray.org...
Ah ha! ;-)
Well I just can't use that assumed_gamma 1.0, I'd have to do some extreme
contrasting of textures to use it. So I will only leave it out or use 2.2,
like Display_Gamma is set.
Date: 27 Aug 2002 00:40:48
Message: <3d6b02d0$1@news.povray.org>
Setting assumed_gamma to 2.2 was what
I did to keep the look of my older pics. Just
remember to use 1 when you begin a new scene!
Tim Nikias
Email: Tim### [at] gmxde
