POV-Ray : Newsgroups : povray.binaries.animations : mechsim falling balls, 610 KBU mpeg1 Server Time
2 May 2026 02:21:56 EDT (-0400)
  mechsim falling balls, 610 KBU mpeg1 (Message 1 to 6 of 6)
Subject: mechsim falling balls, 610 KBU mpeg1
Date: 22 Jan 2003 07:38:02
Message: <Xns930B8062E934Dveentukibmcom@204.213.191.226>
Hi all,
Another try of the mechsim feature in Megapov. Although the balls still
fall from the same spot each time, they bounce into each other so that
gives some randomness. I will post the source for both animation shortly.
ps I hope this post doesn't get broken into pieces.
Download 'falling.m1v.mpg' (611 KB)
Subject: Re: mechsim falling balls, 610 KBU mpeg1
Date: 22 Jan 2003 08:22:47
Message: <3e2e9b27@news.povray.org>
Looks very nice. The radiosity isn't perfect but I suppose you're using
'fast' settings?
The balls are still lined up after the bouncing, like a 2d picture. I
suppose in real life, the balls will have an initial rotation that, when
they hit another surface (either another ball or the boxes) results in some
movement in the Z direction. Also, when two balls hits each other, it will
almost certainly be at a skew angle, does the mechsim take this into
consideration?
Hugo
Date: 22 Jan 2003 09:10:58
Message: <Xns930B9041F516Eveentukibmcom@204.213.191.226>
"Hugo Asm" <hua### [at] post3teledk> wrote in news:3e2e9b27@news.povray.org:
> using 'fast' settings?
Thanks! Well they are pretty 'fast' settings.
> when they hit another surface (either another ball or the boxes)
> results in some movement in the Z direction. Also, when two balls hits
> each other, it will almost certainly be at a skew angle, does the
> mechsim take this into consideration?
DUH... I guess I should have put a bit of randomnes in the Z direction in,
just like in the other animation. Mechsim will take skew angles into
consideration as far as I know, so that should work.
Date: 22 Jan 2003 17:44:47
Message: <3e2f1edf$1@news.povray.org>
Mesmerising how they bounce past each other :)
PGP Public Key
Date: 23 Jan 2003 08:50:38
Message: <3e2ff32e$1@news.povray.org>
"Thomas van der Veen" <tho### [at] gmxnet> wrote in message
> Hi all,
I really like this one, particularly the scene layout.
To give more randomness to the start (and therefore the end positions), perhaps you
could add
a random velocity to each mass when they are created. I would do it like this:
#include "rand.inc"
#declare TT=seed(7);
#declare Variation=0.2;
mass {
        <0, 0, 0>,
        <RRand(-Variation,Variation,TT),
        RRand(-Variation,Variation,TT)>, // Maybe leave vertical velocity at zero?
        0.1
        density 600
Also, you could try changing the error_bound to something like 0.8 or 1 (is it
currently at
0.1?), which may help with the radiosity blotches you are getting around the spheres
(at the
expence of accuracy though).
All the best,
Andy Cocker
Date: 31 Jan 2003 12:31:56
Message: <Xns9314B2538B6CCveentukibmcom@204.213.191.226>
"Andrew Cocker" <mai### [at] andrewcockercouk> wrote in
news:3e2ff32e$1@news.povray.org:
> positions), perhaps you could add a random velocity to each mass when
> they are created.
Thank you! I posted the code now in text.scene-files so people can play
with it if they want to.
> 1 (is it currently at 0.1?), which may help with the radiosity
> blotches you are getting around the spheres (at the expence of
> accuracy though).
I didn't rerender the animation with better radiosity settings and some
randomness in the initial position of the balls mainly because I'm to lazy
;) As mentioned, the code is now available so if people want to give it a
try, they can.
