> The heightfield is not generated with Povray so the POV-code won't help
> you much. If i make a version using an isosurface i will post the code.
It's propably better that way for speed. I generated my height_field with
function 1000, 1000
and parse time was about 2 minutes IIRC (Athlon 1,4Ghz). 1000,1000 doesn't
get you a lot of smooth water :)
> > > The main idea is to superpose several sine waves (160 in this case)
with
> > > different frequencies and directions according to a certain
distribution
> > > function.
> > I tried averaging 160 sine_wave gradients then rotating and scaling
> > semi-randomly
> > but the effect is nothing like with your approach. So how about atleast
> > giving the
> > rest of us atleast a clue
> Simply random waves does not work, you have to use the correct
> distribution functions for frequency and direction to get it right.
Yeah. I kind of suspected it from the result I got.
Anyway I'm eagerly waiting to see what you can do with this.
-Jide
Subject: Re: water waves simulation (349k)
Date: 21 Nov 2001 11:27:49
Message: <3BFBD605.EC38EA4@gmx.de>
Probably not, rendering the isosurface will be much slower than the
heightfield.
> function 1000, 1000
My animations used 256x256 and 512x512, generated with a separate program
that is faster than povray in this aspect (only a few seconds per frame)
The nice thing about an isosurface would only be that you don't need large
data files and it's possible to render arbitrarily sized water surfaces.
Christoph Hormann <chr### [at] gmxde>
> heightfield.
Yeah. I meant generating a hf is good for speed but after looking at my
post I see I messed it up.
-Jide
What separate program did you use?
Does this mean that for rendering *huge* water surfaces isosurface is
recommended?
My own. ;-)
> recommended?
Well, it's not exactly 'recommended', but it's more realistic than a plane
with normal and with a heightfield it's simply not possible to make a
large water surface extending from foreground to horizon.
In that case I'll have to start tweaking with isos, because I like lakes...
> The main idea is to superpose several sine waves (160 in this case) with
> different frequencies and directions according to a certain distribution
> function.
Where can I get (slightly readable) info about the distributions of sine
frequencies and directions?
I downloaded 'wt_water.pov' from your website but it doesn't seem to work in
PoV3.5 (release 7).
The parses stops here: #declare fnRMF=function{"ridgedMF",<0.07, 2.2, 7,
0.6, 0.9>}
because of this error: "Parse Error: Expected 'valid function expression', <
found instead"
Maybe I should download megapov for this to work?
> The formulas are given in:
Failed to understand the math, so my question may be complete nonsense.
Is it possible to turn all this into a pattern for POV-Ray?
Ingo
Pov-Ray : http://members.home.nl/seed7/
I just did a first test and it is very slow (30 minutes for the scene the
animation is made from, 512x384 with only 40 different waves)
As I previously mentioned, there is an implementation of this technique
in the latest issue of 'PC Magazin', together with some explanations.
> PoV3.5 (release 7).
> 0.6, 0.9>}
> found instead"
The function syntax has changed so you have to convert it, just check the
3.5 docs for the details. Reflection parameters will need to be adapted
too.
Surely it is, i'm not sure how much gain in speed this would mean in
relation to the user defined function version, but it would be possible.
Code for an isosurface version is now in p.b.s-f.
