POV-Ray : Newsgroups : povray.advanced-users : format of hf_gray_16 .bmp files? Server Time
7 Apr 2026 17:20:22 EDT (-0400)
  format of hf_gray_16 .bmp files? (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: format of hf_gray_16 .bmp files?
Date: 7 Jul 2005 13:12:51
Message: <42cd6293@news.povray.org>
Christoph Hormann wrote:
> I would be really astonished if you could find a similarly complete
> specification for the BMP format.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/gdi/bitmaps_4v1h.asp
Because, of course, we all know that Microsoft hates developers and
wouldn't want to let anyone else create software that can export to
their proprietary formats, naturally.  That's why when you search for
"bitmap file" nothing comes up in MSDN. ;-)
     The samba was clearly inspired
     by the margarita.
Date: 7 Jul 2005 13:50:01
Message: <dajptc$chn$1@chho.imagico.de>
I mean they write "established bitmap file format" - which says it all.
Never try to fool an ex-OS/2 user about there being a kind of standard
in BMP files...
http://www.tu-bs.de/~y0013390/ (Last updated 01 Jul. 2005)
Date: 7 Jul 2005 14:53:46
Message: <42cd7a3a$1@news.povray.org>
> in BMP files...
Oh, you mean OS/2 took a Windows format and modified it, but called it
the same thing, and screwed things up? OK. ;-)
Seriously, they're *all* bitmap formats. I figured you meant the
microsoft bitmap format. Typing "OS/2 bitmap storage" into google and
hitting "I'm feeling lucky" gets you that bitmap format.
     by the margarita.
Date: 7 Jul 2005 15:01:10
Message: <VBi2$BA5UWzCFwJs@econym.demon.co.uk>
Wasn't it Christoph Hormann who wrote:
>Mike Williams wrote:
>> When I use POVRay to generate a hf_gray_16 TGA file, it works as a
>> height_field.
>> When I do exactly the same thing with a PPM file generated with
>> hf_gray_16 and +fp. I get an error "Parse Error: File is not in PPM
>> format (type 53)" when I try to use it as a height_field. (POVRay 3.6
>> Windows 98se).
>As said with hf_gray_16 POV-Ray generates PGM files - you have to
>specify them as 'pgm' in the heightfield statement.
Wow, how confusing. You're right and the documentation is wrong.
Mike Williams
Gentleman of Leisure
Date: 7 Jul 2005 15:25:01
Message: <dajvfd$dko$1@chho.imagico.de>
What exactly do you think is wrong in the docs?
Of course the documentation of hf_gray_16 should be more elaborate -
important information is missing but i am not aware of anything being wrong.
Date: 7 Jul 2005 15:35:02
Message: <dajvth$dot$1@chho.imagico.de>
I am sure MS would describe things like this.
No, but this isn't really the topic - i just wanted to point out that
there is nothing even approximately as well defined as the PPM/PGM specs
for BMP.
Date: 7 Jul 2005 15:42:26
Message: <42cd85a2$1@news.povray.org>
 > for BMP.
OK. I'd disagree, given the resources I pointed you to and the number of
people who have written to the specs. And in spite of the specs being
well-defined for PPM/PGM, it's not the case that everyone importing
those formats follows the specs either, including POV-Ray.
     by the margarita.
Date: 7 Jul 2005 15:49:36
Message: <ZPlVMAAlYYzCFwo5@econym.demon.co.uk>
It says that you can use a PPM file as a 16-bit height field, but you
have to use a PGM file (and the syntax is "height_field pgm filename").
It says that +fp outputs a PPM file, but if hf_gray_16 is active the
output is a PGM file with an incorrect extension.
I don't think that there's any way that someone could guess the correct
way to use PGM hf_gray_16 files by reading the documentation.
Mike Williams
Date: 7 Jul 2005 15:55:02
Message: <dak17s$dvs$1@chho.imagico.de>
In what way does POV-Ray's reading of PPM/PGM not follow the specs?
Date: 7 Jul 2005 16:20:01
Message: <dak2g9$e9p$1@chho.imagico.de>
You can use a PPM file in a height_field,
height_field {
   ppm "test.ppm"
works for any valid PPM - of course not for a PGM.
That's right.
What's unclear about the use of PGMs? - you can use them in
heightfields, image maps and elsewhere just like any other image file
format supported.
