POV-Ray : Newsgroups : povray.advanced-users : Why are CSG copies different from mesh copies? Server Time
28 Jul 2024 16:15:21 EDT (-0400)
  Why are CSG copies different from mesh copies? (Message 1 to 6 of 6)
Subject: Why are CSG copies different from mesh copies?
Date: 7 Jan 2005 09:07:25
Message: <41de979d@news.povray.org>
I've been thinking about this for a while and I simply can't find a
reason why it is not possible to copy a CSG object in the same, memory
saving way you can copy meshes.
My knowledge of the POV sources is very limited, so please correct me if
I'm wrong, but IMHO copies of the same mesh are simply references to the
same internal dataset, i.e. pointers, and additional data like
transformations. Why can't the same technique be applied to CSG objects
as well? Is this a general, algorithmic problem or is the way things are
handled in the POV-Ray sources the reason for this?
Please not that this is is not a feature request, but simply a question
out of curiosity. Also, I found this group a better place to ask than
p.programming, but again please correct me if I'm wrong.
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Subject: Re: Why are CSG copies different from mesh copies?
Date: 7 Jan 2005 09:25:36
Message: <Xns95D79CEE2BB73jgrimbertmeandmyself@203.29.75.35>
HISTORY is your one-word answer.
CSG were implemented far before mesh even become available.
Moreover, mesh was perceived as a huge memory-filler, and was therefore
optimised (because, at that time, even 4 megabytes of memory could have
been luxury), whereas CSG is usually feeled like a simple (and short) tree.
(a CSG operation, a sphere and a plane, that's short!)
l'habillement, les chaussures que le maquillage et les accessoires.
Date: 7 Jan 2005 09:27:13
Message: <df6tt0pu5pgntqu8tbebm9fq0kot077oav@4ax.com>
On Fri, 07 Jan 2005 15:08:19 +0100, Florian Brucker <tor### [at] torfboldcom> wrote:
That was mentioned several times (for example in
http://news.povray.org/povray.unofficial.patches/thread/%3CMPG.156f6f504b27c9c29896b3%40news.povray.org%3E/
) but from my own experimenting it caused slowdown in rendering.
Unfortunatelly I fail to find thread with my results I posted long time ago to
this server about 3-4 years ago. Perhaps it waits for more effective
implementation than my attempt. I think I lost the sources from that time.
ABX
Date: 7 Jan 2005 17:20:28
Message: <41df0b2c$1@news.povray.org>
Thanks for your answers, and for the link, both of you. Would be
interesting to see some benchmarks of those transformation-optimizations
vs. referencing, but it looks like really hard work, so I doubt we'll be
getting some soon.
Would be a killer feature, though. There are many scenes where I'd have
traded rendering speed for memory, but that's as usually, an issue of
personal taste.
Thanks again,
Florian
Date: 8 Jan 2005 09:29:32
Message: <41dfee4c@news.povray.org>
I thought about the subject again and found some new questions I can't
answer myself :)
The basic argument in the thread ABX provided a link to is, that CSG
objects are optimized for the used transformations, so that e.g.
sphere {
	0, 1
	scale 20
	translate <-1,2,3>
is "translated" into
sphere { <-1,2,3>, 20 }
This is done to avoid the application of the transformation to the
incoming ray, right? This is not applicable on referenced objects, as
those would store their transformations separately.
Now I do see that this kind of optimization will work for simple objects
like a sphere, but does it still hold true, say, for a rotated box? A
sheared box? I don't know how the intersection tests are performed
internally, but I could imagine that there are (a lot?) of combinations
of objects and transforms for which it is not possible to perform
optimizations as above. So in that cases, the transformations would have
to be applied to the ray, wouldn't it? And applying the transformation
to the ray is a matrix*vector operation, right? So once you mixed one
transformation with an object which can't be optimized for that special
transformation, you will have to do the matrix*vector stuff, no matter
what any other transformations are applied to the object. In those
cases, the argument against referencing does not work.
Can anyone tell me how much of the usual intersection tests benefit from
this kind of optimization (I know that this is scene dependant, but just
to have an idea)?
Thanks for any pointers and sorry if I'm talking BS, just tell me :)
Florian
Date: 9 Jan 2005 15:15:39
Message: <41e190eb@news.povray.org>
As already said, there's a historical reason for this. The first coders
thought of this kind of optimization and embedded it so deeply into the
core of povray that now it would be quite laborious to change.
  POV-Ray 4 will probably change this.
