POV-Ray : Newsgroups : povray.advanced-users : Smoke Server Time
30 Jul 2024 10:22:54 EDT (-0400)
  Smoke (Message 1 to 9 of 9)
Subject: Smoke
Date: 22 Nov 1999 03:29:25
Message: <383A18F2.92F05850@mail.flashmail.com>
Does anyone have any suggestions on how one would model smoke coming off
say a cigarette?
Would using an image of smoke as an imagemap with a transparent
background (can you do that?) work if it was pointed directly at the
camera?  I suppose if I made the object with the imagemap partly
transparent, it would look not too bad.
Or does anyway know of a "better" way to do this?
Cheers,
Joel
PS-And if the imagemap's the way to go, anyone got any good ideas on how
to draw smoke? :0)
Subject: Re: Smoke
Date: 22 Nov 1999 04:08:40
Message: <383907C6.F7E91334@pacbell.net>
> say a cigarette?
> Cheers,
> Joel
> to draw smoke? :0)
I think I have a better solution. Check out the SmokeGen include file at:
http://www.studenter.hb.se/~arch/smokegen/smokegen.htm
This file uses POV-Ray's media feature to create smoke.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Subject: Re: Smoke
Date: 22 Nov 1999 04:21:34
Message: <38390b1e@news.povray.org>
> say a cigarette?
> Cheers,
> Joel
> to draw smoke? :0)
I managed quite a convinsing smoke a while back, using a cone extending
slowly out from the source, then texturing it with a marble texture (most of
which was transparent)
It worked o.k. but was  very tricky to align and scale the texture to get
the right effect, even resorting to a bit of csg to cut out a few bits of
phantom smoke.
it worked perfectly for what i wanted, which was a small part of the scene,
more of an added effect than a feature.
i doubt it would work well, if you entire scene was called "look at my smoky
cig"
Subject: Re: Smoke
Date: 22 Nov 1999 10:35:18
Message: <EV85OF2dujqhfCTkaeOwj26mKIiJ@4ax.com>
On Sun, 21 Nov 1999 22:32:51 -1000, Joel Gilmore
>say a cigarette?
>Cheers,
>Joel
>to draw smoke? :0)
Image map is a good idea for a quick solution (i.e. non-media). The
easiest way to create it that I can think of is using Eye Candy's
Smoke plugin gfor PhotoShop and PainShop Pro. If you don't have access
to it, I'll make it for you. I used to be a long-time smoker till
recently so I have a pretty good idea how cigarette smoke looks.
The other replies already indicated the rest of the (most common) ways
to make smoke.
Peter Popov
ICQ: 15002700
Subject: Re: Smoke
Date: 22 Nov 1999 19:41:20
Message: <3839E354.F284B018@peak.edu.ee>
An image_mapped triangle could do the job, but the trick will become apparent
when the smoke is reflected in a mirror. A workaround might be to use two or
more intersecting triangles, all with the smoke texture.
Media smoke would theoretically look best, if you're up to the challenge :)
Margus
> say a cigarette?
> Cheers,
> Joel
> to draw smoke? :0)
Subject: Re: Smoke
Date: 25 Nov 1999 03:50:34
Message: <383cf85a@news.povray.org>
>PainShop Pro
*lol*
(But it was not intended, was it?)
Simen.
Subject: Re: Smoke
Date: 25 Nov 1999 03:53:12
Message: <383cf8f8@news.povray.org>
One way to avoid slow-rendering media is to use several semi-transparent
cones inside each other, 5 or 6 would do. They all should have the same
pigment, i suggest bozo with a [clear -> semi transparent gray] color_map.
Since they will be placed on different coordinates, the texture will look
like it is in fact a media. I haven't tried it, though.
Simen.
Subject: Re: Smoke
Date: 25 Nov 1999 06:04:09
Message: <383d17a9@news.povray.org>
Simen Kvaal <sim### [at] studentmatnatuiono> wrote in message
news:383cf8f8@news.povray.org...
I can confirm this works fine - i have used this technoque for rocket engine
exaust - however to do it properly its not much quicker than using real
media
Subject: Re: Smoke
Date: 25 Nov 1999 15:09:18
Message: <05Y9OBRtdEEnxu1GkwCg4mLiZviJ@4ax.com>
On Thu, 25 Nov 1999 09:50:33 +0100, "Simen Kvaal"
<sim### [at] studentmatnatuiono> wrote:
>>PainShop Pro
>*lol*
>Simen.
LOL, no, it was not indeed. It's a great proggie from what I hear
about it, but personally I haven't had the chance to try it yet.
Peter Popov
pet### [at] usanet
ICQ: 15002700
