POV-Ray : Newsgroups : povray.advanced-users : Infinite cones Server Time
4 May 2026 11:04:55 EDT (-0400)
  Infinite cones (Message 1 to 10 of 22)
Subject: Infinite cones
Date: 20 Jul 1999 04:32:22
Message: <379434CE.F35B69A7@inapg.inra.fr>
This one puzzles me...
The code below shows 2 bunches of cones. One is called "slow", the other
one "quick". Render the code to see why : render the "quick" ones first
and then the "slow" ones.
The only difference between the slow and quick ones is that the slow
ones have a slightly larger base radius.
POV says that the slow cones are infinite objects !!!!
I came upon this problem when rendering a tree : for some mysterious
reason, some trees took forever to render (not counting parsing time).
The "slow" cones below were (painstakingly) extracted from a file
containing 16000 cones.
Scaling the cones or moving the camera sometimes make the problem
disappear, sometimes not.
Any idea about what's going wrong ?
Gilles
#declare PdV=<-1, 64 , -1>;
#declare PdA=<-1,64,0>;
camera {location  PdV direction <0.0 , 0.0 , 2 > up y  right 4*x/3
look_at   PdA}
light_source{<130,40,-200> color White*1.8}
#declare slow=
union{
cone{<-1.4877,62.1686,7.44824> ,0.204866,<-1.58298,62.4111,7.54819>
,0.204862}
cone{<-1.58298,62.4111,7.54819> ,0.204862,<-1.67826,62.6535,7.64813>
,0.204857}
cone{<-1.67826,62.6535,7.64813> ,0.204857,<-1.77355,62.896,7.74808>
,0.204853}
cone{<-1.77355,62.896,7.74808> ,0.204853,<-1.86883,63.1384,7.84802>
,0.204848}
cone{<-1.86883,63.1384,7.84802> ,0.204848,<-1.96411,63.3809,7.94797>
,0.204844}
cone{<-1.96411,63.3809,7.94797> ,0.204844,<-2.05939,63.6233,8.04791>
,0.20484}
cone{<-2.05939,63.6233,8.04791> ,0.20484,<-2.15468,63.8658,8.14786>
,0.204835}
cone{<-2.15468,63.8658,8.14786> ,0.204835,<-2.24996,64.1082,8.2478>
,0.204831}
cone{<-2.24996,64.1082,8.2478> ,0.204831,<-2.34524,64.3507,8.34775>
,0.204826}
cone{<-2.34524,64.3507,8.34775> ,0.204826,<-2.44052,64.5931,8.44769>
,0.204822}
cone{<-2.44052,64.5931,8.44769> ,0.204822,<-2.5358,64.8356,8.54764>
,0.204818}
cone{<-2.5358,64.8356,8.54764> ,0.204818,<-2.63109,65.078,8.64758>
,0.204813}
cone{<-2.63109,65.078,8.64758> ,0.204813,<-2.72637,65.3205,8.74753>
,0.204809}
cone{<-2.72637,65.3205,8.74753> ,0.204809,<-2.82165,65.5629,8.84747>
,0.204804}
cone{<-2.82165,65.5629,8.84747> ,0.204804,<-2.91693,65.8054,8.94741>
,0.2048}
#declare quick=
union{
cone{<-1.4877,62.1686,7.44824> ,0.254866,<-1.58298,62.4111,7.54819>
,0.204862}
cone{<-1.58298,62.4111,7.54819> ,0.254862,<-1.67826,62.6535,7.64813>
,0.204857}
cone{<-1.67826,62.6535,7.64813> ,0.254857,<-1.77355,62.896,7.74808>
,0.204853}
cone{<-1.77355,62.896,7.74808> ,0.254853,<-1.86883,63.1384,7.84802>
,0.204848}
cone{<-1.86883,63.1384,7.84802> ,0.254848,<-1.96411,63.3809,7.94797>
,0.204844}
cone{<-1.96411,63.3809,7.94797> ,0.254844,<-2.05939,63.6233,8.04791>
,0.20484}
cone{<-2.05939,63.6233,8.04791> ,0.25484,<-2.15468,63.8658,8.14786>
,0.204835}
cone{<-2.15468,63.8658,8.14786> ,0.254835,<-2.24996,64.1082,8.2478>
,0.204831}
cone{<-2.24996,64.1082,8.2478> ,0.254831,<-2.34524,64.3507,8.34775>
,0.204826}
cone{<-2.34524,64.3507,8.34775> ,0.254826,<-2.44052,64.5931,8.44769>
,0.204822}
cone{<-2.44052,64.5931,8.44769> ,0.254822,<-2.5358,64.8356,8.54764>
,0.204818}
cone{<-2.5358,64.8356,8.54764> ,0.254818,<-2.63109,65.078,8.64758>
,0.204813}
cone{<-2.63109,65.078,8.64758> ,0.254813,<-2.72637,65.3205,8.74753>
,0.204809}
cone{<-2.72637,65.3205,8.74753> ,0.254809,<-2.82165,65.5629,8.84747>
,0.204804}
cone{<-2.82165,65.5629,8.84747> ,0.254804,<-2.91693,65.8054,8.94741>
,0.2048}
#declare toto=object{quick} // render this  first
//#declare toto=object{slow} // render this last
#declare i=-2;#while (i<5) #declare j=0;#while (j<20)
object{toto translate <i,0,j> pigment{Red}}
#declare j=j+1;#end #declare i=i+1;#end
background{White}
Subject: Re: Infinite cones
Date: 20 Jul 1999 05:33:21
Message: <37944261@news.povray.org>
Gilles Tran <tra### [at] inapginrafr> wrote:
: Any idea about what's going wrong ?
  Perhaps there's something wrong with the automatic bounding? Just a guess.
Date: 20 Jul 1999 08:11:30
Message: <379464CE.C2AE6398@xs4all.nl>
> Gilles
It obviously has something to do with the small difference between the base and
the top of the slow cones. The difference here is more or less redundant. I
changed them into cylinders and it rendered fast and seamless.
I don't know what the actual cause is, it's somewhere in the code, but assuming
you don't want to make a patch for this I guess there's not much more you can do
then adapt your scene-code or sit and wait.
Remco
Date: 20 Jul 1999 08:54:41
Message: <3794724B.5BE5C2BB@inapg.inra.fr>
It's very strange in fact. Sometimes it also happens when the difference between top
and base is not so small (and doesn't happen when there's no difference). In fact,
it seems that even when pov doesn't say they're are "infinite" some cones render
very slowly under certain circumstances, as if POV would consider them as very large
for some of its calculations.
After Nieminen's suggestion, manual bounding of the cones removes the problem so at
least there's a possible workaround to investigate.
Of course, this is a problem only when there are many (hundred) cones like this in a
scene so maybe it's not worth reporting as a bug.
G.
> Regards,
> Remco
Date: 20 Jul 1999 09:24:02
Message: <379477F5.EF048865@pacbell.net>
> Gilles
Perhaps the programs epsilon limit is causing rounding errors ?
  Your slow cones are only .000004 pov units different between the
radius at each end. Adding .000010 to the first radius in the cone
statement at least removes the infinte object problem but it still
renders slowly.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 20 Jul 1999 09:34:54
Message: <37947afe@news.povray.org>
: Of course, this is a problem only when there are many (hundred) cones like this in a
: scene so maybe it's not worth reporting as a bug.
  If it really is a bug, I think it should be reported.
Date: 20 Jul 1999 11:32:33
Message: <37949749.B0FFDA61@inapg.inra.fr>
As bare as possible :
camera {location  -z*200} light_source{<1,1,-1>*1000 color 2}
cone{0 ,15,<8,90,8> ,15.1 pigment{rgb <1,0,0>}}
This is a pretty normal infinite cone... There maybe something about the
epsilon value, but in this case there's nothing uncommon about this cone, at
least nothing you wouldn't hand-code.
Actually, the fact that some non-infinite cones render more slowly than others
bother me more than the infinite cone problem itself, because at least I can
hunt down the infinite cones but can't do anything for the slow finite ones
when they pop up randomly in a 16000-cone tree and make it useless.
Well, I think I'll report it (and I supported Ken Tyler some time ago when he
said it was better to let the pov-team develop pov instead of bothering them
about unusual bugs <sigh> ).
Gilles
> renders slowly.
> Ken Tyler
Date: 20 Jul 1999 12:14:53
Message: <3794A001.94300B37@pacbell.net>
Strange !
> Gilles
  And Ken Tyler appreciated that support when everyone was accusing me
of blasphemy :)
Ken Tyler
Date: 20 Jul 1999 13:47:42
Message: <3794b5b3.2674853@204.213.191.228>
On Tue, 20 Jul 1999 14:00:14 +0200, Remco de Korte
>Regards,
>Remco
This is odd as cylinders are internally represented as cones with two
equal radii.
Peter Popov
ICQ: 15002700
Date: 20 Jul 1999 14:12:12
Message: <3794BCB3.DD2B3820@inapg.inra.fr>
> equal radii.
> Peter Popov
> ICQ: 15002700
And manually bounding each cone by the corresponding cylinder removes the whole
problem (-UR setting necessary)...
BTW, manually bounding the cones speeds them all, see below (compare slow_cone_finite
and slow_cone_finite_bounded for instance).
This problem may have been with POV since the very beginning but until POV 3.0 few
people ventured to make scenes with tens of thousands of cones so it never appeared.
G.
camera {location  -z*1000} light_source{<1,1,-1>*1000 color 2} background{rgb 1}
#declare slow_cone_infinite= cone{0 ,15,<8,90,8> ,14.9}
#declare slow_cone_infinite_bounded= cone{0 ,15,<8,90,8> ,14.9
bounded_by{cylinder{0,<8,90,8> ,15}}}
#declare slow_cone_finite= cone{0 ,15,<8,90,8> ,14.8}
#declare slow_cone_finite_bounded= cone{0 ,15,<8,90,8> ,14.8
#declare fast_cone= cone{0 ,15,<8,90,8> ,10}
#declare fast_cone_bounded= cone{0 ,15,<8,90,8> ,10 bounded_by{cylinder{0,<8,90,8>
,15}}}
#declare testcone=object{slow_cone_infinite}
#declare testcone=object{slow_cone_finite}
#declare testcone=object{fast_cone}
#declare testcone=object{slow_cone_infinite_bounded}
#declare testcone=object{slow_cone_finite_bounded}
#declare testcone=object{fast_cone_bounded}
#declare i=-10;#while (i<10) #declare j=0;#while (j<200)
object{testcone translate <i,0,j>*35 pigment{rgb<1,0,0>}}
