This one puzzles me...
The code below shows 2 bunches of cones. One is called "slow", the other
one "quick". Render the code to see why : render the "quick" ones first
and then the "slow" ones.
The only difference between the slow and quick ones is that the slow
ones have a slightly larger base radius.
POV says that the slow cones are infinite objects !!!!
I came upon this problem when rendering a tree : for some mysterious
reason, some trees took forever to render (not counting parsing time).
The "slow" cones below were (painstakingly) extracted from a file
containing 16000 cones.
Scaling the cones or moving the camera sometimes make the problem
disappear, sometimes not.
Any idea about what's going wrong ?
Gilles
#declare PdV=<-1, 64 , -1>;
#declare PdA=<-1,64,0>;
camera {location PdV direction <0.0 , 0.0 , 2 > up y right 4*x/3
look_at PdA}
light_source{<130,40,-200> color White*1.8}
#declare slow=
union{
cone{<-1.4877,62.1686,7.44824> ,0.204866,<-1.58298,62.4111,7.54819>
,0.204862}
cone{<-1.58298,62.4111,7.54819> ,0.204862,<-1.67826,62.6535,7.64813>
,0.204857}
cone{<-1.67826,62.6535,7.64813> ,0.204857,<-1.77355,62.896,7.74808>
,0.204853}
cone{<-1.77355,62.896,7.74808> ,0.204853,<-1.86883,63.1384,7.84802>
,0.204848}
cone{<-1.86883,63.1384,7.84802> ,0.204848,<-1.96411,63.3809,7.94797>
,0.204844}
cone{<-1.96411,63.3809,7.94797> ,0.204844,<-2.05939,63.6233,8.04791>
,0.20484}
cone{<-2.05939,63.6233,8.04791> ,0.20484,<-2.15468,63.8658,8.14786>
,0.204835}
cone{<-2.15468,63.8658,8.14786> ,0.204835,<-2.24996,64.1082,8.2478>
,0.204831}
cone{<-2.24996,64.1082,8.2478> ,0.204831,<-2.34524,64.3507,8.34775>
,0.204826}
cone{<-2.34524,64.3507,8.34775> ,0.204826,<-2.44052,64.5931,8.44769>
,0.204822}
cone{<-2.44052,64.5931,8.44769> ,0.204822,<-2.5358,64.8356,8.54764>
,0.204818}
cone{<-2.5358,64.8356,8.54764> ,0.204818,<-2.63109,65.078,8.64758>
,0.204813}
cone{<-2.63109,65.078,8.64758> ,0.204813,<-2.72637,65.3205,8.74753>
,0.204809}
cone{<-2.72637,65.3205,8.74753> ,0.204809,<-2.82165,65.5629,8.84747>
,0.204804}
cone{<-2.82165,65.5629,8.84747> ,0.204804,<-2.91693,65.8054,8.94741>
,0.2048}
#declare quick=
union{
cone{<-1.4877,62.1686,7.44824> ,0.254866,<-1.58298,62.4111,7.54819>
,0.204862}
cone{<-1.58298,62.4111,7.54819> ,0.254862,<-1.67826,62.6535,7.64813>
,0.204857}
cone{<-1.67826,62.6535,7.64813> ,0.254857,<-1.77355,62.896,7.74808>
,0.204853}
cone{<-1.77355,62.896,7.74808> ,0.254853,<-1.86883,63.1384,7.84802>
,0.204848}
cone{<-1.86883,63.1384,7.84802> ,0.254848,<-1.96411,63.3809,7.94797>
,0.204844}
cone{<-1.96411,63.3809,7.94797> ,0.254844,<-2.05939,63.6233,8.04791>
,0.20484}
cone{<-2.05939,63.6233,8.04791> ,0.25484,<-2.15468,63.8658,8.14786>
,0.204835}
cone{<-2.15468,63.8658,8.14786> ,0.254835,<-2.24996,64.1082,8.2478>
,0.204831}
cone{<-2.24996,64.1082,8.2478> ,0.254831,<-2.34524,64.3507,8.34775>
,0.204826}
cone{<-2.34524,64.3507,8.34775> ,0.254826,<-2.44052,64.5931,8.44769>
,0.204822}
cone{<-2.44052,64.5931,8.44769> ,0.254822,<-2.5358,64.8356,8.54764>
,0.204818}
cone{<-2.5358,64.8356,8.54764> ,0.254818,<-2.63109,65.078,8.64758>
,0.204813}
cone{<-2.63109,65.078,8.64758> ,0.254813,<-2.72637,65.3205,8.74753>
,0.204809}
cone{<-2.72637,65.3205,8.74753> ,0.254809,<-2.82165,65.5629,8.84747>
,0.204804}
cone{<-2.82165,65.5629,8.84747> ,0.254804,<-2.91693,65.8054,8.94741>
,0.2048}
#declare toto=object{quick} // render this first
//#declare toto=object{slow} // render this last
#declare i=-2;#while (i<5) #declare j=0;#while (j<20)
object{toto translate <i,0,j> pigment{Red}}
#declare j=j+1;#end #declare i=i+1;#end
background{White}
> This is odd as cylinders are internally represented as cones with two
> equal radii.
> Peter Popov
> ICQ: 15002700
And manually bounding each cone by the corresponding cylinder removes the whole
problem (-UR setting necessary)...
BTW, manually bounding the cones speeds them all, see below (compare slow_cone_finite
and slow_cone_finite_bounded for instance).
This problem may have been with POV since the very beginning but until POV 3.0 few
people ventured to make scenes with tens of thousands of cones so it never appeared.
G.
camera {location -z*1000} light_source{<1,1,-1>*1000 color 2} background{rgb 1}
#declare slow_cone_infinite= cone{0 ,15,<8,90,8> ,14.9}
#declare slow_cone_infinite_bounded= cone{0 ,15,<8,90,8> ,14.9
bounded_by{cylinder{0,<8,90,8> ,15}}}
#declare slow_cone_finite= cone{0 ,15,<8,90,8> ,14.8}
#declare slow_cone_finite_bounded= cone{0 ,15,<8,90,8> ,14.8
#declare fast_cone= cone{0 ,15,<8,90,8> ,10}
#declare fast_cone_bounded= cone{0 ,15,<8,90,8> ,10 bounded_by{cylinder{0,<8,90,8>
,15}}}
#declare testcone=object{slow_cone_infinite}
#declare testcone=object{slow_cone_finite}
#declare testcone=object{fast_cone}
#declare testcone=object{slow_cone_infinite_bounded}
#declare testcone=object{slow_cone_finite_bounded}
#declare testcone=object{fast_cone_bounded}
#declare i=-10;#while (i<10) #declare j=0;#while (j<200)
object{testcone translate <i,0,j>*35 pigment{rgb<1,0,0>}}
