![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is it possible to transform any object (or group of objects) by a 3x3 or 4x4
matrix in POV SDL?
I wrote a realtime application about steeringbehaviors in 3D space (Open GL)
and now I want to be able to export movements to POV to create
photorealistic animations (polygon models will be reset by predefined POV
objects). My program handles transformations with matrices. So a function
that works like the camera's look-at would do the trick (the matrix stores
the up-, right- and direction-vector).
Any Idea?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 11 Jun 2003 09:51:23 EDT, "J. Diehl" <j.d### [at] firemail de> wrote:
> matrix in POV SDL?
What about looking into documentation for keyword 'matrix'?
http://www.povray.org/search/?s=matrix
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
rtfm is always a good idea, however, in this case the manual says:
6.3.1 Transformations
The supported transformations are rotate, scale, and translate.
but should read
The supported transformations are rotate, scale, translate and matrix.
[Not very advanced, though...]
>>matrix in POV SDL?
> ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 11 Jun 2003 17:48:31 +0200, sascha <sas### [at] users sourceforge net>
> but should read
It says correct IMO. Imagine I have baloon. I can do following transformations:
a) rotate it turning around
b) translate it by moving
c) scale it with blowing
but I can't matrix it becouse there is no transformation 'matrix' in reality,
though matematically I can describe this transformations with matix and that's
what is written in next sentence "A transformation matrix may also be used to
specify complex transformations directly." :-)
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks. Sorry, I was sure that matrix transformation is not supported by pov
(never read about it before), so I didn't search it in the documentation.
Now it will be easy :)
'bye
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> transformations: a) rotate it turning around
> reality, though matematically I can describe this transformations with
> matix and that's what is written in next sentence "A transformation matrix
> may also be used to specify complex transformations directly." :-)
Maybe
d) an arbitrary *affine transformation* specified by a matrix
would be the correct terminology.
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>but should read
>ABX
(6.3.1.4 Matrix Keyword)
... the matrix command allows more general transformation effects like
/shearing/. The following matrix causes an object to be sheared ...
The manual could be changed to make this clearer
The supported transformation modifiers are |rotate|, |scale|,
|translate|, and matrix. They are used to turn, size and move an object
or texture. A transformation matrix may also be used to specify complex
This would clear up the meaning of "may also be used" (for complex
transformations) instead of (is also supported).
Tim Attwood
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 11 Jun 2003 23:04:47 -0700, Tim Attwood <tim### [at] worldnet att net>
http://www.cs.berkeley.edu/~ug/slide/pipeline/assignments/as5/transforms3d.shtml#shear_rot_scale_rot_scale
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
