POV-Ray : Newsgroups : moray.win : UDO file size limits? Server Time
28 Jul 2024 10:21:33 EDT (-0400)
  UDO file size limits? (Message 1 to 5 of 5)
Subject: UDO file size limits?
Date: 17 Aug 2000 16:08:45
Message: <399c464d@news.povray.org>
List,
I'm modeling a highly detailed F1 race car in Rhino 1.1 and exporting as a
Moray udo object.  I think I have encountered some limits in file size
because of the following:
If I export the entire model as a udo and attempt to render in Moray
3.2/Povray 3.1, I will get an error like this:
error: no triangles in triangle mesh
rear_susp_object62
I was able to locate 'object62.  Knowing what the object is I went back into
Rhino and exported a smaller portion of the model which included 'object62.
This time I was able to get a render with Moray/Povray.  This leads me to
believe that I may have run into some kind of limitation for the size of the
file.  Would this be the case?  Workarounds?
Thanks, in advance,
Steve Clarke
http://www.teleport.com/~sclarke
Subject: Re: UDO file size limits?
Date: 17 Aug 2000 16:59:11
Message: <399C51B5.506F6DF9@pacbell.net>
Steve Clarke wrote:
> List,
> rear_susp_object62
What that error message usually means is that your mesh object(s) contained
nothing but degenerate triangles which POV-Ray will not accept. I have
seen this in the past when using 3DWin to convert between various formats
but only rarely.
Date: 17 Aug 2000 17:31:14
Message: <399c59a2@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote in message
news:399C51B5.506F6DF9@pacbell.net...
contained
> but only rarely.
The main clue for me is that the same object rendered with no errors when it
was exported in a smaller group of objects.  A much smaller file size.
Although I kind of wonder if my system didn't make some errors while
handling the really large export of the entire model.  It was swapping out
to disk a lot during the udo translation operation in Rhino.
-Steve
> Steve Clarke wrote:
> > List,
a
> > rear_susp_object62
into
'object62.
to
the
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 17 Aug 2000 18:06:14
Message: <399C6170.25861B60@pacbell.net>
I have rendered massive meshes before without problem but they were
obviously well behaved and written properly. As I said sometimes
something gets messed up during the translation efforts and you
end up with millions of degenerate triangles that POV-Ray silently
and dutifully removes for you. I am fairly certain that in your
case file size had nothing to do with it.
Date: 17 Aug 2000 18:15:41
Message: <399c640d@news.povray.org>
Thanks,
I'll look at model clean up next.
later,
Steve Clarke
