List,
I'm modeling a highly detailed F1 race car in Rhino 1.1 and exporting as a
Moray udo object. I think I have encountered some limits in file size
because of the following:
If I export the entire model as a udo and attempt to render in Moray
3.2/Povray 3.1, I will get an error like this:
error: no triangles in triangle mesh
rear_susp_object62
I was able to locate 'object62. Knowing what the object is I went back into
Rhino and exported a smaller portion of the model which included 'object62.
This time I was able to get a render with Moray/Povray. This leads me to
believe that I may have run into some kind of limitation for the size of the
file. Would this be the case? Workarounds?
Thanks, in advance,
Steve Clarke
http://www.teleport.com/~sclarke
Steve Clarke wrote:
> List,
> rear_susp_object62
What that error message usually means is that your mesh object(s) contained
nothing but degenerate triangles which POV-Ray will not accept. I have
seen this in the past when using 3DWin to convert between various formats
but only rarely.
Ken <tyl### [at] pacbellnet> wrote in message
news:399C51B5.506F6DF9@pacbell.net...
contained
> but only rarely.
The main clue for me is that the same object rendered with no errors when it
was exported in a smaller group of objects. A much smaller file size.
Although I kind of wonder if my system didn't make some errors while
handling the really large export of the entire model. It was swapping out
to disk a lot during the udo translation operation in Rhino.
-Steve
> Steve Clarke wrote:
> > List,
a
> > rear_susp_object62
into
'object62.
to
the
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
I have rendered massive meshes before without problem but they were
obviously well behaved and written properly. As I said sometimes
something gets messed up during the translation efforts and you
end up with millions of degenerate triangles that POV-Ray silently
and dutifully removes for you. I am fairly certain that in your
case file size had nothing to do with it.
Thanks,
I'll look at model clean up next.
later,
Steve Clarke
