POV-Ray : Newsgroups : moray.win : Bowling Pin Surface and Texture Server Time
18 Jan 2026 01:02:40 EST (-0500)
  Bowling Pin Surface and Texture (Message 1 to 10 of 13)
Subject: Bowling Pin Surface and Texture
Date: 14 May 1999 21:58:01
Message: <373cc699.0@news.povray.org>
As a newbie to 3D raytracing, I have been using a bowling pin design to
explore sPatch, Moary and PovRay.  I'm satisfied that I understand the
mechanics of using the software but would like to do a more realistic
rendering of the surface of the bowling pin now.  I see lots of
possibilities, of course, but which ones lead to good realism?  I'm thinking
of the color plate in the popular book on Renderman (name of book escapes me
right now) as an example.  This rendering is rather striking (pardon the
pun) as it includes just a tinge of yellow/off-white and numerous dents,
etc.
Has anyone reproduced this image?  I would love to see the sample code.
Tim Hutcheson
w4l### [at] bellsouthnet
Subject: Re: Bowling Pin Surface and Texture
Date: 15 May 1999 05:45:01
Message: <373d340d.0@news.povray.org>
try to make to bowling pin white, and use a bump map to give the impression
of dents, maybe use a gradient texture for the pin, that way you can unclude
the red stripe.
dont worry about the yellow tinge, a combination of good lighting and
radioasity should take care of that. (assuming you are going to do a whole
scene, it bowling alley, ball, room, etc etc etc.
as i say, just may a bleach white w/ strip texture and render a few pins,
post it to bin.imag and take it from there.
Tim Hutcheson <w4l### [at] bellsoughnet> wrote in message
news:373cc699.0@news.povray.org...
thinking
me
> etc.
> Tim Hutcheson
Date: 15 May 1999 07:06:08
Message: <373D46CC.F8BA60D9@aol.com>
I've done the bowling type scene before, very compressed image at:
 http://members.aol.com/versecurse/lbowling.jpg
and someone else here at the did another also a while back, much better as
I recall. Might try seeking them out in the binaries.images group if you
can search far enough back.
If you want to see the pov scene file (not a moray file) for mine go ahead
and email me via the address below.
> etc.
> Tim Hutcheson
 mailto://inversez@aol.com?Subject=PoV-News
Date: 15 May 1999 11:19:31
Message: <373d8273.0@news.povray.org>
Thanks for the tips, Rick.  I'm going to try to add the red stripe this
morning and a logo of some sort.  Don't know the best way even to add the
stripe.  Is this an sPatch, Moray or Povray problem?  I mean I could add a
cylindrical band as a separate object (as a patch) or section the pin, in
sPatch, and color that in Moray.  But that will add surface anomalies. Or I
guess I could do it directly in Povray with code, which seems to be the more
mature way to go at it.  But that would mean rolling up my sleeves a bit
more and learning the language.  If so, I'm off to the bookstore to see what
povray books are there.
Obviously there are easy and direct approaches to this but it isn't clear
how to paint detail on an object as opposed to coloring and texturing an
object, which is straight forward.  When I lathed the bowling pin, I was
trying to create a toy problem to learn the right approaches to the general
cases that arise.  How would you proceed, other than to just have at it and
spend hours fiddling?
Thanks for your thoughts in advance.
Tim Hutcheson
Rick <kit### [at] dialpipexcom> wrote in message
news:373d340d.0@news.povray.org...
impression
unclude
> the red stripe.
> Rick
> thinking
escapes
> me
> > etc.
> > Tim Hutcheson
Date: 15 May 1999 11:32:55
Message: <373d8597.0@news.povray.org>
Thanks, Bob.  Nice image, I really like the floor treatment.
Tim Hutcheson
Bob Hughes <inv### [at] aolcom> wrote in message
news:373D46CC.F8BA60D9@aol.com...
thinking
escapes me
> > etc.
> > Tim Hutcheson
>   http://members.aol.com/inversez/homepage.htm
Date: 15 May 1999 12:58:55
Message: <373D998D.8246ED7B@pacbell.net>
  There currently are no books in print on Pov-Ray unfortunatly. A better
bet would be a visit to my links page and head towards the online tutorials
section of the page. There you will find a wide variety of tutorials on many
different pov related subjects and they cover from plain white wrapper newbie
all the way to some of the more advanced subjects.
> Tim Hutcheson
 As far as texturing the pins I would not hesitate for a second to
consider using image maps for this. While you could easily add one
red stripe to each pin it gets more difficult to add logos to each
pin with just proceedural texturing alone. I would definatly advise
against breaking up your object unless you just dig doing things the
difficult way. I am attaching a teeny little image to the bottom or
this reply in hopes I don't get burned for posting an image into a
non binaries group. Anyway the image gives you a reasonable idea of
what you could create in a paint program and then use it as a image
map for the colors and even blemishes on the pins.
An example code for applying it would be:
object { Bowling_Pin
  image_map { gif "PinStripe.gif" interplolate 2 mape_type 0 }
   translate -0.5 scale <1, 2, 1> }
  Or if you have your heart set on a proceedural pigment (no logo with this
method ) try a gradient like this:
 pigment { gradient y
  color_map {
  [0.0 rgb <1,1,1>] // white
  [0.6 rgb <1,1,1>] // white
  [0.6 rgb <1,0,0>] // red
  [0.8 rgb <1,0,0>] // red
  [0.8 rgb <1,1,1>] // white
  [1.0 rgb <1,1,1>] // white
  scale <1,2,1>}
  With the above the scale of course will change depending on oyur object size
and you may need to translate it a bit to get the stripe where you need it.
The last example is basicaly jsut that and is not garanteed to work right
out of the box (though I bet it is close).
Ken Tyler
mailto://tylereng@pacbell.net
Download 'bowlpin.jpg' (3 KB)
Preview of image 'bowlpin.jpg'
Date: 15 May 1999 13:36:56
Message: <373DA277.86294899@pacbell.net>
Ken wrote:
 A better
A link to the links might help:
http://home.pacbell.net/tylereng/links.htm
Ken Tyler
Date: 15 May 1999 18:14:23
Message: <373de3af.0@news.povray.org>
for  an idea of how tio do the texture, have a lookin the moray texture
libray, there's one called candy cane, one you see it you will get what i
had in mind
Date: 15 May 1999 22:22:59
Message: <373E1E1D.27B4D68B@home.com>
I like the image too but I have a few suggestions if you don't mind. The pins are
a little too squat and a little too fat, they look a little like cartoon bowling
pins. Also there is nothing behind the pins! What I mean is the area behind the
pins where you would usually see some simple machinery which catch and reset the
pins and where the ball falls into and get returned to the player. Anyway, don't
mean to offend, other than that, very nice I like the wood texture!
> > etc.
> > Tim Hutcheson
Date: 16 May 1999 09:07:48
Message: <373EB510.AECD5B82@aol.com>
No offense taken, however, you are talking about something from a couple
years ago and I'm not sure if I'll ever do anymore with it. You've gone
and wasted some good advice ;)
Btw the pins are a lathe, and I didn't even do a good guess on the
dimensions. Went for a "looks right to me" way of doing things while
putting numbers in. And as we all probably know, not the best way to go
when modelling real life objects.
Thanks for your time regardless Thomas.
> > > etc.
> > > Tim Hutcheson
> >  omniVERSE: beyond the universe
