POV-Ray : Newsgroups : moray.win : Flat surfaces Server Time
18 Jan 2026 09:56:18 EST (-0500)
  Flat surfaces (Message 1 to 6 of 6)
Subject: Flat surfaces
Date: 15 Jan 1999 16:15:57
Message: <369FAFCF.E454057B@ix.netcom.com>
I am trying to render a flat glass plate and mirror. What
I get is large distortions in the reflections. Is there
anyway to define a "prefectly' flat/smooth surface in
moray/povray?
TIA...
	R
Subject: Re: Flat surfaces
Date: 15 Jan 1999 16:18:09
Message: <369FB0E6.185A71C0@istar.ca>
> moray/povray?
For some bizarre reason, a texture with no normal has a big old bozo
(granite? I dunno) normal applied by default.
Give it a normal with a bump size of 0.
Yeah, this really sucks.
Simon
http://home.istar.ca/~sdevet
Date: 15 Jan 1999 20:01:14
Message: <369fe4da.0@news.povray.org>
Hi
Thanks for the tip !!!
I just spent ages trying to figure out why a rendered button I was making
for a windows program was looking horrible. I am using the latest Moray and
Pov versions, the Phong highlight was very odd and non uniform. I tried your
tip of putting in an agate normal with a bump size of 0. Hey presto, the
highlighting I was expecting. See the 2 small samples attached.I haven't
looked into this problem, anyone know if this is a Moray or more likely a
POV bug ?
                                 Geoff
Simon de Vet wrote in message <369FB0E6.185A71C0@istar.ca>...
>> moray/povray?
>Simon
Download 'ok.gif' (6 KB) Download 'odd.gif' (6 KB)
Preview of image 'ok.gif'
Preview of image 'odd.gif'
Date: 16 Jan 1999 09:48:51
Message: <36a09ebe.3604082@194.174.214.110>
Hi Simon de Vet, you recently wrote in moray.win:
That's was my fault. The last maintenance releas of Moray includes a
file called MorayPOV.inc which defines a default texture with normals
and phong highlighting.
Simply delete or edit the MorayPOV.inc file and the renderings will be
as expected.
The final V3.1 release (due early next week) will fix this.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Subject: Rounded Cone (WAS Re: Flat surfaces)
Date: 17 Jan 1999 10:33:13
Message: <36A2030A.BCA407F@istar.ca>
Geoff wrote:
> Hi
> POV bug ?
Nice button. May I ask how you got the nice rounded edge between the conical
base and the flat surface?
Simon
Subject: Re: Rounded Cone (WAS Re: Flat surfaces)
Date: 26 Jan 1999 07:17:32
Message: <36adb25c.0@news.povray.org>
Simon de Vet schrieb in Nachricht <36A### [at] istarca>...
conical
>Simon
Don't know how he did it, but you could do it:
- using a lathe object
- using a sor (ahem, no, impossible: multiple points with same y value)
- using a CSG of a cylinder, a cone and a torus (hard to adjust the torus on
the cone)
- using a non-standard transformation of a superellipsoid (hard to figure
out).
So I think it was a lathe object (I would use one) here. OR a CSG of a sor
and a cylinder.
But your tip was very useful. Is this default bozo documented somewhere
(except for the source code, which I didn't have a look at yet)?
O sorry again. I should have read a bit further. It was in the MorayPOV.inc,
not in POV-Ray. I am rather new to Moray, but I like it.
Rudy Velthuis
