POV-Ray : Newsgroups : povray.unofficial.patches : name for no interpolation Server Time
18 Nov 2025 18:46:02 EST (-0500)
  name for no interpolation (Message 1 to 10 of 43)
Subject: name for no interpolation
Date: 10 Sep 2002 09:43:48
Message: <5gtrnu4hdr0h52c3kh4s5e3e0om32eqs46@4ax.com>
Any idea for nice name for interpolation without interpolation ?
In my rewrtitten sphere_sweep module I have added additional types for
interpolations. One of them is something like "no interpolation" - it makes
set of spheres without connections - then in fact it works for spheres just
like mesh for triangles - have own internal bounding hierarchy, shares data
between instances and reserves memory only for center, radius and pointer to
texture. My problem is that I don't know how to call this kind of
interpolation. I don't like the
  no_interpolation
  interpolation off
  spline off
and have no language experience to choose anything better than
  no_spline
So any help with this language problem? Note it should look readable when more
than one interpolation type is specified:
  sphere_sweep{
    // make rounded cylinder ...
    linear_spline
    sphere{x 1 pigment{rgb 1}
    sphere{y 0.1 pigment{red 0.1}}
    // ... and one additional separated sphere
    no_spline
    sphere{z 0.2 texture{My_Favourite}}
ABX
Subject: Re: name for no interpolation
Date: 10 Sep 2002 10:05:57
Message: <3D7DFC44.6B1C7ECB@gmx.de>
>   no_interpolation
>   interpolation off
>   spline off
>   no_spline
I think it should have 'connection' somewhere.  This clearly shows there
is no connection at all between the spheres and not just no interpolation
(which could mean anything).
How about:
connection off | linear_spline | cubic_spline | ...
BTW this sounds like a very interesting feature after all.  I'm just
rendering a 6000 spheres mechanical simulation and it's taking ages (not
for the simulation but for the render).
Date: 10 Sep 2002 10:10:17
Message: <v2vrnusj53e06kllq8d1ukvdpmhi1lurrv@4ax.com>
On Tue, 10 Sep 2002 16:05:56 +0200, Christoph Hormann <chr### [at] gmxde>
You mean like you wrote or :
  connection TYPE_OF_CONNECTION
  TYPE_OF_CONNECTION: off | linear_spline | cubic_spline
what about replacing 'connection' with 'sweep_type' ?
ABX
Date: 10 Sep 2002 10:26:19
Message: <3D7E0109.EB139C68@gmx.de>
I find connection very intuitive.  sweep_type seems rather meaningless to
me.  Especially 'sweep_type off'.
Date: 10 Sep 2002 11:21:01
Message: <3d7e0ddd$1@news.povray.org>
In article <5gtrnu4hdr0h52c3kh4s5e3e0om32eqs46@4ax.com> , ABX
In the case of sphere_sweeps, don't you define a path it shall sweep on?  So
maybe call it "path" or "path_type".
    Thorsten
e-mail: tho### [at] trfde
Date: 11 Sep 2002 05:08:41
Message: <7e1unus8h9amgktm4ktrh7b1g77bgmevnb@4ax.com>
On Tue, 10 Sep 2002 17:21:01 +0200, "Thorsten Froehlich" <tho### [at] trfde>
Yes, 'path' sounds nice. So one vote for 'connection' and one for 'path'. Any
other vote? My heart is now for 'path_type FLOAT' becouse it is made with
short words and I don't like that I have to reserve new token for every new
type of interpolation. There are also subtypes for interpolations when I can't
choose nice names. For example there are two toroidal connection types: one by
Ron Parker and one by Slime (IIRC). Making type float is better IMO. What do
you think?
ABX
Date: 11 Sep 2002 06:12:41
Message: <3D7F1759.2070203@free.fr>
> you think?
> ABX
My vote, if you care, would go for 'path' but no float, a keyword for
each type/kind. (do you really remember by looking at the SDL that there
is various projection for image (using map_type) and which number
correspond to what kind ?
I do not. If you do (without looking at the help file or code),
please fill the following form to describ map_type in image_map:
  default value:
  0 :
  1 :
  2 :
  3 :
  4 :
  5 :
  6 :
I will check it later against the documentation!!
Date: 11 Sep 2002 06:36:25
Message: <f36unu8rueduockdrdm6vk534djddjkrtf@4ax.com>
I care, just don't be angry if I choose otherwise :-)
> I do not.
I do not either but I don't like so many keywords used so rarely. Apropriate
include file with identifiers assigned to floats could be enough. There are
two include files with identifiers assigned this way: "functions.inc" and
"const.inc" ?
One of my teachers at technical university learned me that I shoudn't remember
every equation, piece of kowledge, keyword. I should know how to find it if I
need it.
ABX
Date: 11 Sep 2002 06:51:14
Message: <3D7F2022.35006A54@gmx.de>
> you think?
'path_type FLOAT' seems fine, i agree using a float to specify the type is
a good idea, like with image_map map_type.
If you don't want to introduce a new keyword at all you could use 'method'
like in media but it would be quite difficult to understand.
Date: 11 Sep 2002 07:50:04
Message: <3D7F2E2F.4030502@free.fr>
No problem, it's your patch...
>>I do not.
> "const.inc" ?
> need it.
That's ok for technical inclined people, not for user-friendliness.
Let's me have a last 'extrem' example with POV.
You know there is a poly object... From your teacher point of view, it
is fine as it is. The order of the poly comes first, then the user must
provide the right number of float value. It's all in the doc, so no
problem (even if since the extension, the doc does not give the order
for more than 7th order while the root solver can handle up to 15th!).
But from a user-friendliness aspect, when Joe user (with a degree in
math, a.k.a not a mathemacaly ignorant) wants to have a poly equation to
be rendered, he has to carrefully spot the place for all values, and
simple things like x^6+y^5+z^4-10=0 turn into a nightmare of values.
If keyword, instead of positional syntax, had been used, it would be
far more easier to use the poly object, and p.b.i might be full of them.
Instead of a long collection of values (with a lot of zero), using
keyword would have make it easier (*):
   poly { x6 1 y5 1 z4 1 const -10 }
If later the user wants to add a x^2yz^3 term, it's also far easier than
retrieving the correct position in the list:
   poly { x6 1 y5 1 z4 1 const -10 x2yz3 -3 }
As a bad thing is always worth something, I believe iso-surface wouldn't
have been there so early if poly would have been easier in syntax, and
their success might have been reduced...
*: Using the classical 'keyword value' paradigm, instead of the
expectable (but more programmer-hostile) 'value [keyword]' which would
allow "poly { 1 x6 +1 y5 +1 z4 -10 }" (using the unary + for once !!!)
P.S: I removed the order of the poly in the example, but I'm not sure
that's a good idea, even if the order could be computed at the end of
the parsing of the poly. Anyway, It's only for the illustration, there
is no real patch here.
P.S.2: the number of keywords needed for the 15th order poly is between
800 and 900...(exact number is in the source code formulae) which also
means good luck to try a 15 th order poly in pov now (that's only about
800 zero to type and some rigthly placed other values!!!) [I do not want
to debug your formulae!]
P.S.3: You might ask what the relation with your question... my answer
is 'Think about user-friendliness, dismiss if you want, but think about it'.
