POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV 1.0 suggestion Server Time
3 Apr 2026 03:19:20 EDT (-0400)
  MegaPOV 1.0 suggestion (Message 1 to 10 of 20)
Subject: MegaPOV 1.0 suggestion
Date: 1 Jan 2003 07:41:01
Message: <3e12e1dd@news.povray.org>
Happy New Year to Everybody.
You made a great job, but i think that if
you include a reflection-blur and a hdr(mlpov)
patches it's perfect.
Is there anyone who knows how to do it?
Ceggi.
Subject: Re: MegaPOV 1.0 suggestion
Date: 1 Jan 2003 10:07:22
Message: <cjameshuff-82ED8A.10030601012003@netplex.aussie.org>
In article <3e12e1dd@news.povray.org>, "ceggi" <ceg### [at] tiscalinetit>
wrote:
> You made a great job, but i think that if you include a
> reflection-blur and a hdr(mlpov) patches it's perfect.
Anyone could do the old reflection blur patch, but it isn't needed:
there are better, more flexible ways of doing it already, without any
patch.
A patch could implement the average texture method and both eliminate
some of the overhead and make it easier to use. The pigment only needs
to be evaluated once in most cases, it rarely depends on the normal and
blurring it isn't always desired when it does. Same for things like
highlights, iridescence, etc...they should all be optionally excluded
from the blur.
http://tag.povray.org/
Date: 1 Jan 2003 12:11:03
Message: <3e132127@news.povray.org>
> but it isn't needed
Agree.
I've tried both the 'averaging' method and the 'microfacet' method, and I
clearly prefer the microfacets. So again, a patch is not needed. But it's
possible that even the microfacets could be speed up, by evaluating the rest
of the texture only once. To avoid confusion let me note, what I mean by
microfacets: One normal, scaled very small, but evaluated many times due to
HQ anti-alias.
Hugo
Date: 1 Jan 2003 12:49:49
Message: <cjameshuff-A3488D.12453601012003@netplex.aussie.org>
In article <3e132127@news.povray.org>, "Hugo Asm" <hua### [at] post3teledk>
> HQ anti-alias.
That has practically the same result as using the average texture method
with a small-scaled normal, only slower and less efficient. You seem to
misunderstand things: the average texture method simulates microfacets
too, it just keeps the supersampling to the blurry surface.
Date: 1 Jan 2003 13:44:44
Message: <3e13371c@news.povray.org>
I was thinking about averaging normals scaled very BIG, and that looks
horrible. It even seems slower than my method unless I use .. only 10
normals, and that looks plain wrong. But I see your point, and will try to
average just a few normals, scaled very small.
Some speed optimations could be done with radiosity and reflections. The
"bolts and plugs" picture I just posted, was rendered in 2 passes: First
radiosity without AA, without area_light, and with a low max_trace_level..
Second pass loads the radiosity data, and has the above mentioned features
activated. The result looks just as good, and only takes 1/4 of the render
time. But the 2-pass method is cumbersome, at least for animations.
Hugo
Date: 1 Jan 2003 14:25:25
Message: <3e1340a5@news.povray.org>
  In my experience scaling the normals big gives you a very smooth result,
which scaling the very small gives you a very grainy result. Personally
I like more the smooth one.
  Naturally you need a rather high amount of samples in order to get a
good-looking result with normals scaled big. When scaled small, the result
looks grainy no matter how many samples you use (even though a larger
amount of samples still gives a visually better result).
  It really depends on how you like grainy reflections. I usually don't
like them (unless it's a very rough surface where you are expecting a
grainy reflection).
  In any case, you can get both worlds with the same trick, just changing
one number.
Date: 1 Jan 2003 15:12:21
Message: <3e134ba5@news.povray.org>
> result, ... Naturally you need a rather high amount
> of samples in order to get a good-looking result
Yes, and so many samples are too slow. With just a few samples, the normals
are pointing in all kinds of wrong directions considering the true surface.
> When scaled small, the result looks grainy no matter
In theory yes, sure. But as you said, more samples gives a smooth result. I
just did an experiment based on Chris Huff's explanation: I'm rendering the
"bolts and plugs" scene again, this time I changed the reflective textures
to have 3 averaged normals instead of one with HQ anti-alias over the entire
scene.. It was good at first, faster, but now it hangs at the bottom of the
picture... This part still render and it will break the 2-hour limit
(compared to my posted picture).
It must be because adc_bailout and max_trace_level doesn't come and save the
day.. Now there are 3 normals to average no matter what.. The ping-pong goes
on inside the metal for the red plug... My old method also had ping-pong,
but there was only 1 normal to evaluate, so adc_bailout had more effect, so
to say.
The visual result is almost the same, but a tad worse because there are some
white spots, so for now I think my old method was the best one.
Hugo
Date: 1 Jan 2003 15:55:15
Message: <cjameshuff-DD4062.15510301012003@netplex.aussie.org>
In article <3e134ba5@news.povray.org>, "Hugo Asm" <hua### [at] post3teledk>
You get that no matter what. There is no way to get accurate blur with
only a few samples.
In practice. In theory, you could take enough samples to get smooth
results with random/small scale normals, in practice you can't without
taking huge amounts of processing power. The recommended method uses
large scale normals, it is easier to get smooth looking results with
fewer samples.
You *don't need* the high-quality AA to get a blur with this technique,
and 3 samples are far too few. You are simply doing it wrong.
Date: 1 Jan 2003 18:04:20
Message: <3e1373f4@news.povray.org>
> a blur with this technique, and 3 samples are far
> too few.
I know, and I was not using high-quality AA on the render with 3 averaged
normals, just a decent AA so the rest of the scene looks ok: +AM2 +A0.1
+R2 -J.
Now I tried to increase the amount of averaged normals. I started a render
with 64 samples and another one with 32 samples. Both of them are actually
incredibly slow, with or without AA. My original approch was definitely the
fastest, and looks smooth. Will you be willing to accept that?
Friendly greeting,
Hugo
Date: 1 Jan 2003 18:12:48
Message: <3e1375f0@news.povray.org>
  It probably depends on the scene. In some scenes the grainy approach
is best, while in others the smooth one. You can't simply dump one of
the approaches because in a particular scene the other one works better.
