POV-Ray : Newsgroups : povray.unofficial.patches : finish_map and layered textures Server Time
27 Jul 2026 02:29:28 EDT (-0400)
  finish_map and layered textures (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: finish_map and layered textures
Date: 29 Jan 2002 16:23:31
Message: <3c5712d3@news.povray.org>
In article <slr### [at] fwicom> , Ron Parker
<ron### [at] povrayorg>  wrote:
> I wonder why you wonder.  Perhaps it's because the people who want it and
> the people who would implement it aren't the same people.  The patches that
> are in MegaPOV, and to some extent the features that are in POV itself, are
> not there because some user or group of users wanted them.  They're there
> because some programmer thought they'd be useful, or fun to implement, or
> interesting to play with.
There are also history reasons.  It didn't make sense until 3.1 in the first
place, as <http://www.povray.org/working-docs/id000174.html#6_6_1> explains
finish originally contained things that didn't exactly were finishes and that
could not be applied in any useful way.  Of course, as this problem has been
fixed in 3.1 there is no reason not to have a finish map, except that it is
rarely needed and can be created (as pointed out here already) with texture
maps.
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Jan 2002 16:27:27
Message: <3c5713bf$1@news.povray.org>
> You would need a map for every property of the finish-block ...
No.  You could nest finish_maps without making a texture_map, so you still can use it
with
layered textures.
cu!
Date: 29 Jan 2002 17:42:50
Message: <3c57256a@news.povray.org>
That would be equivalent to color_map and bump_map but the requested feature
is a map equivalent to pigment_map and normal_map. That is, *not* a map for
every property of the finish-block, but just one map for the entire finish.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 29 Jan 2002 18:37:10
Message: <chrishuff-4A6E4D.18392829012002@netplex.aussie.org>
In article <3c56a626@news.povray.org>,
 "Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote:
> Hmmm, my actual question was: many people wanted finish_maps for a
> very long time, even before MegaPov existed.  And yet it isn't part
> of MegaPov.  I wonder why.  Is it hard to implement?
It wouldn't be easy, and would be impossible to do it cleanly in 3.5,
you would have to modify the code to interpolate for every finish
option, and there's lots of them. It would probably slow things down
detectably. In addition, a workaround is available for the vast majority
of cases...texture_map.
It's another thing that will probably wait for 4.0.
Date: 29 Jan 2002 18:40:04
Message: <chrishuff-B46498.18422329012002@netplex.aussie.org>
In article <3c570cf0@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
Not really...you could store entire finishes, and interpolate for each
option when they are needed. The texture_map feature would probably be
faster though.
What would be nice is if you could map each attribute individually,
having separate maps for diffuse and reflection. There would have to be
a standard way of doing the mapping, and it would require rewriting a
lot.
Date: 30 Jan 2002 14:24:52
Message: <3c584884$1@news.povray.org>
> faster though.
HOW would you interpolate ...
I don't think it is always desired, to interpolate linear between them ...
btw: In my opinion these methods are all cheating, but do I count ? ;]
WinOSI goes the only right way... *g*
#macro J(N A)#local a=mod(N 3);#local W=<int(mod(A,4)*2)int(-A/4)9>*2;#if
(!mod(a 2))sphere{W,2,2pigment{color rgb<a*5A/2W.x/A*5>}}#if(a<1)sphere{W
+<2,0>2 2pigment{color rgb<a*10A 10>}}#end#end#if(N>3)J(int(N/3)A+1)#end#
end blob{J(29229171 0)threshold 1translate<-6 3>}/******Jan Walzer******/
Date: 30 Jan 2002 17:09:34
Message: <chrishuff-ABB650.17104530012002@netplex.aussie.org>
In article <3c584884$1@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
Element by element...when calculating diffuse, the diffuse values would
be interpolated, etc.
All the other maps (except slope_map, which is rather unusual) are
linearly interpolated. I think it would lead to the best and most
predictable results, though I've often wondered if quadratic and cubic
options would be useful for color maps.
Again, I think the best solution would be to have each attribute
individually mappable, but that is not practical in the current POV-Ray.
Date: 30 Jan 2002 17:25:44
Message: <3c5872e8@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
: All the other maps (except slope_map, which is rather unusual) are
: linearly interpolated.
  Are you sure that slope_map is not linearly interpolated?
  Linearly interpolating a _slope_ may get a result which doesn't _look like_
it was linearly interpolated (eg. in lighting), but that doesn't mean that
the slope is not interpolated linearly.
  (I think this is because interpolating a slope linearly causes an
interpolation in the apparent height of the surface which is not linear.)
Date: 30 Jan 2002 17:41:43
Message: <chrishuff-B0A220.17425430012002@netplex.aussie.org>
In article <3c5872e8@news.povray.org>, Warp <war### [at] tagpovrayorg>
The documentation seems to imply otherwise...you specify an "apparent
height" and a "slope", and I always thought the slope was used to
control the interpolation of the height. I've never really used slope
maps before, though...
Date: 30 Jan 2002 18:16:10
Message: <3c587eba@news.povray.org>
: I've never really used slope maps before, though...
  You should. They are difficult to understand at first, but once you master
them, they are really handy. You can make pretty nice effects with them.
  Just a quickie which I cooked in a couple of minutes:
camera { location <0,1,-1>*3 look_at 0 angle 35 }
light_source { <20,15,-5>, 1 }
plane { y,0 pigment { rgb .5 } }
cylinder
{ 0,y*.1,1
  pigment { rgb <1,.5> }
  finish { specular .5 }
  normal
  { wood 1 slope_map
    { [0 <0,1>][.5 <1,1>][.5 <1,0>]
      [.9 <1,0>][.9 <1,-1>][1 <.5,0>]
    scale .3
    rotate x*-90
