POV-Ray : Newsgroups : povray.unofficial.patches : Tesselation and mesh data extraction patches Server Time
30 Jun 2026 01:40:22 EDT (-0400)
  Tesselation and mesh data extraction patches (Message 23 to 32 of 32)
Subject: Re: Tesselation and mesh data extraction patches
Date: 15 Dec 2000 22:24:13
Message: <3a3ae031.42359775@news.povray.org>
On Fri, 15 Dec 2000 16:16:04 -0600, David Fontaine <dav### [at] faricynet>
wrote:
>Jerry Anning wrote:
>> http://www.ee/surrey.ac.uk/Research/VSSP/3DVision/mt.html
>404?
http://www.ee.surrey.ac.uk/Research/VSSP/3DVision/mt.html
typos are irritating.
Date: 17 Dec 2000 05:16:38
Message: <Xns900D79CAEseed7@povray.org>
Chris Huff wrote:
>Takes an object to use for insideness checks, the object could be
>declared or specified directly. Meshes generated with the "tesselate"
>feature could use this by default, unless something else is specified.
To prevent confusion, the default should be the same as the current mesh.
Also you do not always want a mesh to be solid.
Ingo
Date: 17 Dec 2000 12:43:56
Message: <3a3cfb5c@news.povray.org>
> That's a bit different from tesselating an object... :-)
Duh... :)
> A similar syntax could be used, though...especially if you ignore
> texturing information and only read geometry:
<snip> Yes, geometry is the only thing I really care about. That syntax
sounds OK. I would love to be able to use these files directly without
worrying about translating them to POV meshes. With the ability to read in
the files we could write macros to export to PCM all within POV... anyway, I
can dream, can't I? :)
Date: 17 Dec 2000 21:44:48
Message: <3A3D7A81.62AE0E08@nospamthanx.hotmail.com>
Warp wrote:
> Jim Kress <kre### [at] kressworkscom> wrote:
> : What tessellation method did you use?
> I'm sampling tetrahedrons thorough the entire bounding box volume.
What about specific methods for different types of objects?
Bye
Pabs
Date: 18 Dec 2000 12:22:12
Message: <chrishuff-68B138.12231218122000@news.povray.org>
In article <3A3D7A81.62AE0E08@nospamthanx.hotmail.com>, Pabs
I agree, it would be nice if a sphere could use a geodesic tesselation,
a cube could be done with 12 triangles, etc...the sampling method could
be used for each object until a method specific to it is implemented.
This is the approach I have been planning with the proximity
pattern...however, I might make a slight adjustment to my plans:
tesselate the object and measure proximity to the resulting mesh instead
of sending dozens of rays. The tesselation patch could also be useful in
the glow patch, which will require information about the proximity of a
ray to the object...
Christopher James Huff
Date: 18 Dec 2000 12:30:46
Message: <3A3E49C1.2B818210@gmx.de>
But that would not work for CSG.  You would either have to calculate the
boundary lines between the different parts or calculate the CSG of
different solid meshes separately.
Date: 18 Dec 2000 12:43:57
Message: <chrishuff-A13EC7.12450118122000@news.povray.org>
In article <3A3E49C1.2B818210@gmx.de>, Christoph Hormann
It would work perfectly fine for CSG...because they are a separate type
of object, they will just use the marching tetrahedrons method (or some
other sampling method) until someone implements something better
specifically for them. The whole idea is that you don't have to write a
specialized method for every object at once, you can do it for a few
objects at a time.
Someone could eventually go through the trouble to implement the code
for CSG on meshes, and tesselate the objects individually and combine
them together. Unions, for example, would be very easy, just put the
meshes of each object together into one big mesh, you don't have to
worry about boundary lines.
Date: 19 Dec 2000 04:14:55
Message: <3a3f270f@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
:> What about specific methods for different types of objects?
: I agree, it would be nice if a sphere could use a geodesic tesselation,
: a cube could be done with 12 triangles, etc...
  I can do that, but I want to get the basic tesselation to work first.
I still can't find the bug. It's making me crazy. I really don't know what
is causing it.
  I'm tempted to just give up.
  This is a very simple test scene where the bug shows up:
--------8<--------8<--------8<--------8<--------8<--------8<--------8<------
#declare YOffs = 0;
background { rgb z*.5 }
#default { pigment { rgb <1,.8,.6> } finish { specular .5 } }
#declare Obj = sphere { -y*YOffs,1 }
tesselate
{ Obj
  accuracy 10
  translate y*YOffs
camera { location <0,4,-13>*1.1 look_at y*.6 angle 35/10 }
light_source { <200,100,-150>, 1 }
light_source { <-200,100,-100>, x*.5 }
  With YOffs 0 there's no bug:
http://www.cs.tut.fi/~warp/tess/tessbug1.jpg
  With YOffs 4 the bug shows up:
http://www.cs.tut.fi/~warp/tess/tessbug2.jpg
  With YOffs 8 more bugs show up:
http://www.cs.tut.fi/~warp/tess/tessbug3.jpg
  The odd thing is that the location of the sphere shouldn't matter. Only
the size of the bounding box should have any effect on the algorithm, not
the location, and it's only the location which changes in the examples
above.
  I just don't know what to do anymore.
Date: 19 Dec 2000 09:31:06
Message: <chrishuff-216878.09321219122000@news.povray.org>
In article <3a3f270f@news.povray.org>, Warp <war### [at] tagpovrayorg>
> what is causing it.
Send me the code and I will look at it...though I'm not too hopeful,
since I have never done anything with this sort of tesselation...
Noooo! Don't even talk like that... ;-)
> above.
Does it show up if you don't translate the tesselated sphere back in
position? Are all your calculations relative to the bounding box and not
to the origin?
Date: 21 Dec 2000 07:18:59
Message: <3a41f533@news.povray.org>
: Send me the code and I will look at it...though I'm not too hopeful,
: since I have never done anything with this sort of tesselation...
  Let me look at the code just once again. If I can't figure out anything,
I'll send it to you.
: Does it show up if you don't translate the tesselated sphere back in
: position?
  Yes.
: Are all your calculations relative to the bounding box and not
: to the origin?
  The calculations always take the geometry of the bounding box. It
shouldn't matter what is the location of the bounding box.
