POV-Ray : Newsgroups : povray.tools.poser : Future implementations of Poseray. A wish list Server Time
14 Dec 2025 23:02:32 EST (-0500)
  Future implementations of Poseray. A wish list (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Future implementations of Poseray. A wish list - an additional wish
Date: 2 Nov 2009 16:44:10
Message: <4aef52aa@news.povray.org>
Thomas de Groot schrieb:
> If, when saving a figure to POV-Ray, one changes the file name, this name
> should also be changed accordingly at the declared figure name, within the
> xxx_POV_geom.inc.
> Thus, an original Poser figure *Beggar*, saved under the file name:
> Beggar2_POV_geom.inc
> should contain:
> //Model assembly from the meshes
> #declare Beggar2_=
> union {
> instead of:
> #declare Beggar_=
> union {
> as happens under the present version of Poseray.
Why? It only complicates matters; for instance, if you want to use
different include files for different frames of an animation, having the
same figure carry the same name is of an advantage.
If it is about getting two figures of same base name in a single scene,
it may be easier, too, as in:
#declare MyFigures = array[10];
#local i = 1;
#while (i <= 10)
   #include concat("Beggar", str(i,0,0), "_POV_geom.inc");
   #declare MyFigures[i-1] = object { Beggar_ }
   #local i = i + 1;
Date: 3 Nov 2009 03:36:16
Message: <4aefeb80$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4aef52aa@news.povray.org...
> If it is about getting two figures of same base name in a single scene, it
> #local i = 1;
> #while (i <= 10)
>   #local i = i + 1;
> #end
Well, it seems inconsistent to me. If I change the name of the file for one
reason or another (for instance because I changed the materials but want to
keep the original too at the same time), I expect the name of the figure to
change too in order to avoid inconsistencies and confusion later in the POV
scene.
Your example is of course also valid, so maybe this change should be
optional.
Date: 3 Nov 2009 12:00:17
Message: <4af061a1$1@news.povray.org>
>> #local i = 1;
>> #while (i <= 10)
>>   #local i = i + 1;
>> #end
> scene.
> optional.
> Thomas
I will look into making it optional if it relatively easy to do.
FlyerX
Subject: Re: Future implementations of Poseray. Place of uv_mapping code
Date: 12 Nov 2009 04:40:18
Message: <4afbd802$1@news.povray.org>
It appears that the place were the uv_mapping code is placed in the latest
version of Poseray generates a faulty rendering of transparant materials.
In the present version, uv_mapping is coded in the xxxx_POV_mat.inc file as
follows:
#declare MyTex_=
material{
texture{ pigment{uv_mapping p_map1}
        finish{specular 0 roughness 0.00286312 ambient rgb <0.00,0.00,0.00>
diffuse 0.8   reflection{0 } conserve_energy}}
or, in the case of a transparancy map:
#declare MyTex__opaque=
        normal{uv_mapping p_map2 bump_size -6.192}
#declare MyTex_=
material{
texture{  pigment_pattern{uv_mapping p_map3}
texture_map{[0 pigment{Clear}]
            [1 MyTex__opaque]
In particular the alpha channel of the first example does *not* work for the
shadow casting. In order for this to work in all cases, the code should be
written as in a previous version of Poseray, i.e. the uv_mapping code is
written in the xxx_POV_geom.inc file and *not* in the xxx_POV_mat.inc one.
As follows:
#declare My_Figure_=
union {
object{My_Figure_1_  uv_mapping material{MyTex_1_}}
object{My_Figure_2_  uv_mapping material{MyTex_2_}}
etc...
This construction provides a correct render of the transparancy of the alpha
channel.
Date: 12 Nov 2009 05:38:17
Message: <4afbe599@news.povray.org>
> union {
> etc...
> channel.
> Thomas
I see your point but as I do never use the material files as generated
by PoseRay this would force me to also edit the geometry file every time
I convert an object file. I *need* separate control about the pigment or
normals or both being uv_mapped for multiple reasons.
A solution that should help us both would be to put the uv_mapping
statement directly into the texture block and not into the
pigment/normal blocks like:
material {
     uv_mapping
     pigment {MyPigment}
     normal {MyNormal}
As far as I do remember this does also solve the transparency by alpha
channel problem.
-Ive
Date: 12 Nov 2009 08:22:01
Message: <4afc0bf9@news.povray.org>
"Ive" <"ive### [at] lilysoftorg"> schreef in bericht
news:4afbe599@news.povray.org...
> I see your point but as I do never use the material files as generated by
> PoseRay this would force me to also edit the geometry file every time I
> statement directly into the texture block and not into the pigment/normal
> blocks like:
> material {
>   texture {
>     uv_mapping
>     pigment {MyPigment}
>     normal {MyNormal}
> channel problem.
Yes indeed. This is also the solution proposed by Clipka by the way and it
is certainly more elegant. My suggestion was just a step back to an earlier
version, but I admit that it is not the most ideal.
When using a transparency map instead of using the alpha channel, the code
in Poseray should then also be as follows (note the place of uv_mapping)
e.g.:
//Material definitions
#declare MyTexTex__opaque=
  uv_mapping
  pigment { p_map1}
  normal {MyNormal}
  finish {MyFinish}
#declare MyTexTex_=
material {
    uv_mapping
    pigment_pattern { p_map2}
    texture_map {
      [0 MyTex__opaque]
      [1 pigment {Clear}]
Date: 12 Nov 2009 08:26:07
Message: <4afc0cef$1@news.povray.org>
OK. To reduce confusion as I typed twice the same term:
  uv_mapping
  pigment { p_map1}
  normal {MyNormal}
  finish {MyFinish}
#declare MyTex_=
material {
    uv_mapping
    texture_map {
      [0 MyTex__opaque]
      [1 pigment {Clear}]
Date: 12 Nov 2009 12:23:33
Message: <4afc4495@news.povray.org>
> e.g.:
> texture {
>   uv_mapping
>   pigment { p_map1}
>   normal {MyNormal}
>   finish {MyFinish}
> #declare MyTexTex_=
> material {
>   texture {
>     uv_mapping
>     texture_map {
>       [0 MyTex__opaque]
>       [1 pigment {Clear}]
As a side note, usually I do use a construct like this:
#local MyTexTex_opaque =
    uv_mapping
    pigment { p_map1}
    normal {MyNormal}
    finish {MyFinish}
#local MyTexTex_trans =
    uv_mapping
    pigment { p_map1 transmit 1}
    normal {MyNormal}
    finish {MyFinishButWithoutAnySpecularPhongAndReflection}
  #declare MyTexTex_=
  material {
      uv_mapping
      texture_map {
        [0 MyTex_opaque]
        [1 MyTex_trans]
This does not make *much* of a difference but occasionally for closeup
shots and things like lace pattern or trans-mapped hair it looks better.
-Ive
Date: 12 Nov 2009 15:34:38
Message: <4afc715e@news.povray.org>
I put the uv_mapping inside the pigment and normal for more control. As
shown in the POV-Ray manual it can inside or outside of these
statements. I did not notice a problem because I have not used textures
with alpha channels in a very long time. Automatically putting
uv_mapping outside the pigment and normal should not be a problem.
Thanks for the suggestions.
The material structure has changed significantly in format in the latest
PoseRay because it now supports specular and transparency mapping at the
same time. Also I dropped the use of the predefined Clear pigment with
transparency mapping since I was having problems with it. I replaced it
by color rgbft<0,0,0,1,1>. I do not remember exactly the reason (I will
have to review my notes) but I believe the transparency at the edges was
not working well with Clear.
I will try to release a preliminary version of PoseRay this week since
it has some of the many changes that were suggested in this forum plus
other fixes.
Below are samples of the new PoseRay-generated materials. They have the
transformation at the end of each map. If any of you see anything wrong
with them please let me know (besides the uv_mapping issue). Most likely
I will have to define the textures before plugging them into the
texture_map entries so that uv_mapping could be placed outside the pigment.
pigment only:
http://mysite.verizon.net/sfg0000/files/p.txt
pigment only but multiplied by a color:
http://mysite.verizon.net/sfg0000/files/p_m.txt
pigment+transparency:
http://mysite.verizon.net/sfg0000/files/p_t.txt
pigment+finish+normal+transparency:
http://mysite.verizon.net/sfg0000/files/p_n_f_t.txt
pigment+finish+normal:
http://mysite.verizon.net/sfg0000/files/p_n_f.txt
pigment+normal:
http://mysite.verizon.net/sfg0000/files/p_n.txt
FlyerX
>> code in Poseray should then also be as follows (note the place of
>> uv_mapping) e.g.:
>> texture {
>>   uv_mapping
>>   pigment { p_map1}
>>   normal {MyNormal}
>>   finish {MyFinish}
>> #declare MyTexTex_=
>> material {
>>   texture {
>>     uv_mapping
>>     texture_map {
>>       [0 MyTex__opaque]
>>       [1 pigment {Clear}]
>  texture {
>    uv_mapping
>    pigment { p_map1}
>    normal {MyNormal}
>    finish {MyFinish}
>  texture {
>    uv_mapping
>    normal {MyNormal}
>  #declare MyTexTex_=
>  material {
>    texture {
>      uv_mapping
>      texture_map {
>        [0 MyTex_opaque]
>        [1 MyTex_trans]
> -Ive
Date: 13 Nov 2009 04:57:15
Message: <4afd2d7b@news.povray.org>
"FlyerX" <fly### [at] yahoocom> schreef in bericht
news:4afc715e@news.povray.org...
>shown in the POV-Ray manual it can inside or outside of these statements. I
>did not notice a problem because I have not used textures with alpha
>channels in a very long time. Automatically putting uv_mapping outside the
>pigment and normal should not be a problem. Thanks for the suggestions.
Youa re welcome :-)
> transparency mapping since I was having problems with it. I replaced it by
> color rgbft<0,0,0,1,1>. I do not remember exactly the reason (I will have
> to review my notes) but I believe the transparency at the edges was not
Ah yes. I think that I have noticed that as a side effect indeed.
> I will try to release a preliminary version of PoseRay this week since it
> has some of the many changes that were suggested in this forum plus other
> fixes.
Great! Looking forward to it!
> with them please let me know (besides the uv_mapping issue). Most likely I
> will have to define the textures before plugging them into the texture_map
> pigment only:
- I am not sure if a diffuse 1 is such a good idea. I prefer 0.6, or 0.8
when using an image map, like in the current version .
- Why a *double* declare for the pigment? It seems to me that only one
should be enough, either PR_MAP_DIFFUSE or PF (well, I see some consistency
now with the other pigments)
- Neat! I like this. I believe that this will work much better than the
current, rather crude, texture layering.
- OK. I see the change from Clear. Certainly works better.
- This is a difficult one. I need to test this to see how it works. My first
impression is that it looks fine however.
- Same as above.
> pigment+normal:
- I think you put the wrong example file here. No normal visible.
Looking good overall. I am thrilled!
