Subject: Feature Request: Multiple scenes in one POV-file
Date: 27 Mar 2008 10:18:35
Message: <47eb828b$1@news.povray.org>
I believe I already mentioned it a while ago on povray.general, but this
might be a better place. What I would like to see in POV-Ray 4 is the
possibility to define more than one scene in one POV-file with the
possibility to "layer" your scenes, meaning: use one scene as background for
the second, and so on. This way, the problem mentioned in "Lighting problem
at extreme distances" (povray.general) could be solved by using one scene
for the astronomical objects, planets and sun, and another for the smaller
objects, like spaceships, with the first scene as background for the second.
It would also be a lot easier this way to add a HUD to your image: just
create a HUD-scene (very easy to do with a orthographic camera) and use the
original scene as background. Or lensflares.
It should also be possible to use one scene as image_map in another scene,
but now I think of it, maybe that's *all* you should be able to do. Layering
of scene could then be done this way:
---BEGIN CODE---
//declare common objects and macros
#declare Common1=...
#macro CommonMacro(...) ... #end
//declare individual scenes
#declare Scene1=scene {
camera {...}
light_source {...}
object {Common1}
sphere {...}
#declare MapView=scene {
Scene1
orthographic
location y
up z*10
right x*10
#declare HUD=scene {
orthographic
union {
pigment { //add a map to the HUD
image_map {scene MapView}
orthographic
location -z*10
right x
up y
look_at 0
translate .5
plane {
z,0
pigment {image_map {scene Scene1}}
finish {ambient 1 diffuse 0}
plane {
z,-1
pigment {image_map {scene HUD}}
---END CODE---
That way, nothing would change for those who don't want to use layered
scenes.
cu!
_(0x+y.5+y/2x)_(0x-y.5+y/2x) // ZK http://www.povplace.com
Subject: Re: Feature Request: Multiple scenes in one POV-file
Date: 28 Mar 2008 14:22:30
Message: <47ed0d36@news.povray.org>
I would simply make the distance limits a user-alterable value instead
of something written directly in the code. The other items can be done
by modeling the scene to produce the desired results, often without
terrible difficulty. I make most of my subtitles by simply placing text
in the right way, relative to the camera (although I could also do it
with a post-processing render).
John
Date: 28 Mar 2008 15:07:49
Message: <47ed17d5$1@news.povray.org>
There aren't any hard-coded distance limits. The limits are using 64-bit
floating-point maths. Using arbitrary precision floating-point means a
lot of code changes and making things slower by an order of magnitude.
Date: 28 Mar 2008 23:37:04
Message: <47ed8f30$1@news.povray.org>
"John VanSickle" <evilsnackKOSHER [at] hotmail com> wrote in message
news:47ed0d36@news.povray.org...
>> at extreme distances" (povray.general) could be solved by using one scene for
> I would simply make the distance limits a user-alterable value instead of
> something written directly in the code. The other items can be done by
> modeling the scene to produce the desired results, often without terrible
> difficulty. I make most of my subtitles by simply placing text in the right
> way, relative to the camera (although I could also do it with a
That's how you would do things now, but I believe being able to define more than
one scene is a much cleaner, easier and much more versatile solution.
cu!
Date: 1 Apr 2008 07:22:43
Message: <47f1f0d3@news.povray.org>
"Zeger Knaepen" <zeger.knaepen [at] povplace com> wrote in message
news:47eb828b$1@news.povray.org...
>for the second, and so on. This way, the problem mentioned in "Lighting
>problem at extreme distances" (povray.general) could be solved by using one
>scene for the astronomical objects, planets and sun, and another for the
>smaller objects, like spaceships, with the first scene as background for
>the second.
> the original scene as background. Or lensflares.
> Layering of scene could then be done this way:
I second that. I have been thinking along the same lines myself.
-Nekar Xenos-
MegaPOV has something like that already, a special 'camera_view' pigment type
that can use a camera for a pigment. I'd love to see camera_view in the
official POV-Ray. Without it you have to render the scene twice, once for to
create the image to put on the pigment from one camera location, then again to
render the scene that contains the first.
Date: 22 May 2008 23:05:39
Message: <4835fc43$1@news.povray.org>
"Allen" <brian_vanderburg2 [at] yahoo com> wrote in message
news:web.4835b0ce710383a8cd46d2150@news.povray.org...
>> scene,
> type
> to
> again to
the camera_view pigment is not nearly as versatile as being able to define
multiple scenes in one file, with which the camera_view pigment can be
emulated.
cu!
