POV-Ray : Newsgroups : povray.pov4.discussion.general : Feature Request: Multiple scenes in one POV-file Server Time
18 Dec 2025 08:20:43 EST (-0500)
  Feature Request: Multiple scenes in one POV-file (Message 1 to 10 of 11)
Subject: Feature Request: Multiple scenes in one POV-file
Date: 27 Mar 2008 06:18:35
Message: <47eb828b$1@news.povray.org>
I believe I already mentioned it a while ago on povray.general, but this
might be a better place.  What I would like to see in POV-Ray 4 is the
possibility to define more than one scene in one POV-file with the
possibility to "layer" your scenes, meaning: use one scene as background for
the second, and so on.  This way, the problem mentioned in "Lighting problem
at extreme distances" (povray.general) could be solved by using one scene
for the astronomical objects, planets and sun, and another for the smaller
objects, like spaceships, with the first scene as background for the second.
It would also be a lot easier this way to add a HUD to your image: just
create a HUD-scene (very easy to do with a orthographic camera) and use the
original scene as background.  Or lensflares.
It should also be possible to use one scene as image_map in another scene,
but now I think of it, maybe that's *all* you should be able to do. Layering
of scene could then be done this way:
---BEGIN CODE---
//declare common objects and macros
#declare Common1=...
#macro CommonMacro(...) ... #end
//declare individual scenes
#declare Scene1=scene {
    camera {...}
    light_source {...}
    object {Common1}
    sphere {...}
#declare MapView=scene {
    Scene1
        orthographic
        location y
        up z*10
        right x*10
#declare HUD=scene {
        orthographic
    union {
            pigment { //add a map to the HUD
                image_map {scene MapView}
    orthographic
    location -z*10
    right x
    up y
    look_at 0
    translate .5
plane {
    z,0
    pigment {image_map {scene Scene1}}
    finish {ambient 1 diffuse 0}
plane {
    z,-1
    pigment {image_map {scene HUD}}
---END CODE---
That way, nothing would change for those who don't want to use layered
scenes.
cu!
Subject: Re: Feature Request: Multiple scenes in one POV-file
Date: 28 Mar 2008 10:22:30
Message: <47ed0d36@news.povray.org>
I would simply make the distance limits a user-alterable value instead
of something written directly in the code.  The other items can be done
by modeling the scene to produce the desired results, often without
terrible difficulty.  I make most of my subtitles by simply placing text
in the right way, relative to the camera (although I could also do it
with a post-processing render).
John
Date: 28 Mar 2008 11:07:49
Message: <47ed17d5$1@news.povray.org>
There aren't any hard-coded distance limits. The limits are using 64-bit
floating-point maths. Using arbitrary precision floating-point means a
lot of code changes and making things slower by an order of magnitude.
Date: 28 Mar 2008 19:37:04
Message: <47ed8f30$1@news.povray.org>
"John VanSickle" <evi### [at] hotmailcom> wrote in message
news:47ed0d36@news.povray.org...
>> at extreme distances" (povray.general) could be solved by using one scene for
> I would simply make the distance limits a user-alterable value instead of
> something written directly in the code.  The other items can be done by
> modeling the scene to produce the desired results, often without terrible
> difficulty.  I make most of my subtitles by simply placing text in the right
> way, relative to the camera (although I could also do it with a
That's how you would do things now, but I believe being able to define more than
one scene is a much cleaner, easier and much more versatile solution.
cu!
Date: 1 Apr 2008 03:22:43
Message: <47f1f0d3@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:47eb828b$1@news.povray.org...
>for the second, and so on.  This way, the problem mentioned in "Lighting
>problem at extreme distances" (povray.general) could be solved by using one
>scene for the astronomical objects, planets and sun, and another for the
>smaller objects, like spaceships, with the first scene as background for
>the second.
> the original scene as background.  Or lensflares.
> Layering of scene could then be done this way:
I second that.  I have been thinking along the same lines myself.
-Nekar Xenos-
Date: 22 May 2008 13:45:00
Message: <web.4835b0ce710383a8cd46d2150@news.povray.org>
MegaPOV has something like that already, a special 'camera_view' pigment type
that can use a camera for a pigment.  I'd love to see camera_view in the
official POV-Ray.  Without it you have to render the scene twice, once for to
create the image to put on the pigment from one camera location, then again to
render the scene that contains the first.
Date: 22 May 2008 19:05:39
Message: <4835fc43$1@news.povray.org>
"Allen" <bri### [at] yahoocom> wrote in message
news:web.4835b0ce710383a8cd46d2150@news.povray.org...
>> scene,
> type
> to
> again to
the camera_view pigment is not nearly as versatile as being able to define
multiple scenes in one file, with which the camera_view pigment can be
emulated.
cu!
Date: 12 Dec 2013 13:15:00
Message: <web.52a9fcea710383a882dd1ac40@news.povray.org>
Does this feature even have to wait until POV 4?
I would think it could be something that could be done in POV3.8?
The way I understand this it is akin to a green screen, in which an image is
place d over the original area (green) being replaced.
From what I understand of the way POV works is that for each pixel (let's say
800x600 for easy arithemetics sake) the color of the pixel is obtained, by
calculating the collision, reflection, etc, the path of light passing through
that pixel takes.
Couldn't someone just put into POV some logic that says if the ray "hits" an
object with the scene mapped texture, it "switches" to the mapped scene?
I know that MegaPOV has this feature but it seems to be limited to multiple
viewpoints of a single scene, rather than completely different scenes. The
difference being that the MegaPOV results in the same sky sphere for each
version, where as a scene map could potentially result in different sky spheres.
-Jeff
Date: 13 Dec 2013 20:11:07
Message: <52abb02b$1@news.povray.org>
Am 12.12.2013 19:14, schrieb Woody:
Such a feature is actually on my personal to-do list, meaning that it
will probably wind up in either POV-Ray proper or UberPOV sooner or -
more likely - later.
The basic problem is that there's still too much legacy C-style code in
POV-Ray, some of which was designed to render /the/ scene, not /a/ scene.
I'm slowly weeding out such code these days (C-style code in general,
that is), but it's still a long way to go until I can tackle the
scene-level stuff.
Date: 18 Dec 2013 20:15:01
Message: <web.52b2482d710383a882dd1ac40@news.povray.org>
> scene-level stuff.
I actually saw the post about uber pov a week ago. I haven't had a chance to
take a look at it yet. Is it being done in ANSI C (I think the only other option
being Objective C, though I admit I haven't done much development on the Mac)?
