POV-Ray : Newsgroups : povray.off-topic : Project Blender Server Time
13 Oct 2024 13:20:54 EDT (-0400)
  Project Blender (Message 1 to 10 of 78)
Subject: Project Blender
Date: 17 Dec 2009 10:34:19
Message: <4b2a4f7b@news.povray.org>
Yes, I have Blender installed and I'm trying to figure out how to work it.
No, I think I'm definitely going to have to read the manual from cover
to cover. The program is just far too unconventional to learn any other
way. Nothing works in remotely the way you'd expect. All the commands
are hidden away and can only be accessed by pressing the secret keyboard
shortcuts. The only way you can find things is if you already know where
they are. There's no way you can learn this program just by playing with it.
So far, I've figured out how to move the view around, set up several
simultaneous views, how to get into edit mode, and how to move stuff
around. I haven't yet managed to figure out how to remove existing
geometry. (For example, deleting an edge makes every face that touches
it dissappear, rather than merging them like you'd expect.) I also have
no clue what the billions of cryptically-named buttons and displays do -
but hey, I probably don't need them yet anyway...
Subject: Re: Project Blender
Date: 17 Dec 2009 10:37:24
Message: <4b2a5034$1@news.povray.org>
> it.
	I'd suspect quite the opposite. I've heard the only way to learn is
total immersion - via numerous tutorials. Then you keep working on
Blender building whatever you wanted, and don't ever take a 2 week break.<G>
	Reading isn't going to make the keybindings/interface stick. Using them
a lot (tutorials) will.
The next war will determine not what is right, but what is left.
Date: 17 Dec 2009 10:45:58
Message: <4b2a5236@news.povray.org>
> break.<G>
> them a lot (tutorials) will.
I think knowing the logic behind the interface (assuming there *is*
some) will probably help a lot. But sure, if you want to become _expert_
you're going to need to practise a lot. Currently I just can't make it
to *anything* interesting, because the UI is getting in the way too much.
Date: 17 Dec 2009 11:22:33
Message: <4b2a5ac9$1@news.povray.org>
Invisible wrote:
> All the commands
> shortcuts.
This is not quite true. What *is* true is that you have a whole bunch of
buttons that reveal menus full of other commands, and getting to an
operation without keyboard shortcuts takes forever.
But I'm pretty sure most of the modeling stuff at least is all in menus down
at the bottom of each frame.
But yeah, you have to use it, and when you stop it goes away again, because
there's no mnemonic way of using it.  (Unlike wordstar, whose keyboard
commands I still remember 30 years after I stopped using it.)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 17 Dec 2009 11:29:14
Message: <4b2a5c5a@news.povray.org>
Invisible escreveu:
Hope the list is a good start.  And yes, most of it I learned myself by
just trying out keys myself.  Oh, the wonders that curiosity makes...
remember:  ctrL+x is your friend, not enemy.  That way, you can learn by
messing up real bad.
a game sig: http://tinyurl.com/d3rxz9
Date: 17 Dec 2009 11:37:45
Message: <4b2a5e59$1@news.povray.org>
Darren New escreveu:
> Invisible wrote:
>> All the commands are hidden away and can only be accessed by pressing
>> the secret keyboard shortcuts.
> down at the bottom of each frame.
> because there's no mnemonic way of using it.  (Unlike wordstar, whose
> keyboard commands I still remember 30 years after I stopped using it.)
I take it you just used wordstar far more than Blender.
ctrl+e = Edge tools menu
u = texture Unwrap
x,y,z = self evident axis
s = scale
r = rotate
g = grab
e = extrude
h, shift+h, alt+h = hide operations
and so on.  I think it's pretty logical.  What is ilogical is expecting
someone not used to visual 3D modelling knowing what extrude or unwrap
means...
Date: 17 Dec 2009 11:47:31
Message: <4b2a60a3$1@news.povray.org>
Well no, I mean for example: If you press [space], a whole bunch of
stuff appears. I can't immediately see any other way of getting at any
of those commands.
Now, if you didn't know that pressing [space] makes that stuff appear
(and why would you?), you're going to have a hard time finding any of
those commands. And it seems every page I read, I discover more secret
key combinations that pop up new menus...
There's nothing *wrong* with keyboard shortcuts, but it does make the
learning curve rather steep.
Currently my main problem is with figuring out the general principles
the UI works under. Stuff like... clicking a menu item makes the menu
open, but clicking it again doesn't make the menu shut. Wuh?
Date: 17 Dec 2009 11:50:14
Message: <4b2a6146$1@news.povray.org>
> means...
Well, I don't know. All the other 3D modellers have their quirks, but in
all of them, once you've selected the right mode, clicking on a point
and dragging it makes it move. (And also any edges and faces associated
with it, obviously.) In Blender, this basic operation doesn't seem to
work...
Date: 17 Dec 2009 12:04:03
Message: <4b2a6483$1@news.povray.org>
No. They just laid out the keyboard very mnemonically.
> u = texture Unwrap
> s = scale
> r = rotate
> g = grab
See, anyone else would have called that "translate".
> e = extrude
Great. Which is which?  ;-)
Well, when you list *only* the logically named keys, sure. Granted, blender
does a lot more than wordstar did, but that doesn't mean it's just as easy.
> means...
Hey, don't get pissy at *me* - I'm not the one arguing its useless. I just
said the UI is hard to learn and to remember, which I think you'll find most
people agree with. In part because it *does* do so much.
I wish Wings3D let you set up keyboard shortcuts for more stuff, because
that's easy to use but slow because you *have* to go thru the menus.
Date: 17 Dec 2009 12:06:06
Message: <4b2a64fe@news.povray.org>
Invisible escreveu:
> of those commands.
They are either in the add item in the top bar or in the select or
object menu items in the bar immediately below the 3D view.
left arrow keyboard button.
