POV-Ray : Newsgroups : povray.off-topic : Visual C# .net (and XNA) first impressions Server Time
4 Jul 2026 09:01:37 EDT (-0400)
  Visual C# .net (and XNA) first impressions (Message 37 to 46 of 46)
Subject: Re: Visual C# .net (and XNA) first impressions
Date: 19 Oct 2009 08:55:38
Message: <4adc61ca@news.povray.org>
> Where does this "everybody has the .NET runtime" myth come from?
The only people who don't have it are those that still have XP, have not
installed all the Windows Upates, and have never installed a program that
needed the .net runtime.  It can't be that many compared to the number of
people without the Borland runtime :-)
> My brand new Vista laptop still doesn't have the .NET runtime.
Did you uninstall it somehow? Vista comes with .net 3.0.
Date: 19 Oct 2009 09:17:29
Message: <4adc66e9$1@news.povray.org>
> that needed the .net runtime.  It can't be that many compared to the
> number of people without the Borland runtime :-)
I would think the number of people with the .NET runtime *is* far, far
larger than the Borland runtime. But still, I've yet to come across any
PCs which have the .NET runtime "already". All the machines at work had
to have it added, and my PC at home only has it because VS requires it
for some reason.
I'm also pretty certain that the .NET runtime is *not* automatically
installed by Windows Update. You can _request_ it from Windows Update,
but it's listed as "optional software" rather than a required update.
(Of course, updates to any version of the runtime you've already
installed get added automatically. But not the runtime itself.)
And what do you mean "still have XP"? Last time I checked, virtually
*everybody* is "still" using XP. (Except for the tiny few who bought a
new PC recently.)
I rephrase: The .NET runtime is not listed in add/remove programs. I
presumed this to mean it isn't installed.
Date: 19 Oct 2009 09:41:50
Message: <4adc6c9e@news.povray.org>
> installed by Windows Update. You can _request_ it from Windows Update, but
> it's listed as "optional software" rather than a required update. (Of
> course, updates to any version of the runtime you've already installed get
Oh ok I hadn't checked what category it came under, I just remember seeing
it on my XP box a long time ago.
> *everybody* is "still" using XP. (Except for the tiny few who bought a new
> PC recently.)
Recently I've seen a lot of people show up with Vista laptops, I guess most
people get them replaced every few years so it's not surprising.  Anyway I
kind of meant the original un-updated XP, the service pack updates include
.net anyway.
BTW, according to Wikipedia 22% use Vista and 68% use XP, and you can guess
which way both those numbers are heading...
Ah ok, yes it *is* installed, but I assume you cannot uninstall it (because
presumably some parts of Vista were written to make use of it).
Date: 19 Oct 2009 09:46:10
Message: <4adc6da2$1@news.povray.org>
> Anyway I kind of meant the original un-updated XP, the service pack
> updates include .net anyway.
I'm pretty sure this is incorrect too. The Windows Update server had to
install SP3, reboot the PC and then install the .NET framework - which
doesn't like a lot of sense if SP3 *includes* it.
> guess which way both those numbers are heading...
Yes, I expect Vista usage to increase over time. (Or will it? Maybe
everybody will just move to Windows 7?) My point is *today* few people
use it.
> (because presumably some parts of Vista were written to make use of it).
Interesting. So it's installed but just not listed? Is there a
scientific way to confirm this?
I should have realised eventually I would have no choice in the matter...
Date: 19 Oct 2009 10:12:10
Message: <4adc73ba$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4adc6da2$1@news.povray.org...
> Interesting. So it's installed but just not listed? Is there a scientific
Look in Control Panel under Administrative Tools. If you have any of the
.NET frameworks installed, there should be an icon (or more) for it there.
IIRC, the only thing you'll see in Add/Remove programs is the service packs,
if any, that you have installed for the frameworks.
Date: 19 Oct 2009 11:00:16
Message: <op.u11ympu07bxctx@bigfrog.bredbandsbolaget.se>
Check your "Windows\Microsoft.NET\Framework" folder (and "Framework64" if
applicable). Each installed .NET version has its own subfolder there.
Alternatively, just run Windows Update and see which ones you have not yet
installed.
FE
Date: 21 Oct 2009 03:03:06
Message: <4adeb22a$1@news.povray.org>
Oh ok, I don't remember so I might be wrong, I thought I read that from XP
SP2 onwards .net was included.  Might the SP install just have deferred the
installation of .net until after the reboot?
I assume Windows 7 will include .net, so the % of machines with .net
installed should continue to rise.
Date: 21 Oct 2009 05:02:06
Message: <4adece0e$1@news.povray.org>
>> to install SP3, reboot the PC and then install the .NET framework -
>> which doesn't like a lot of sense if SP3 *includes* it.
> XP SP2 onwards .net was included.  Might the SP install just have
> deferred the installation of .net until after the reboot?
Nope. I sometimes have to do this manually if WUS doesn't work for some
reason, and just installing SP3 is insufficient. No amount of rebooting
helps. You have to also manually install the .NET framework, which is a
seperate [240 MB] download.
Oh, sure. I meant will Windows Vista continue to increase once Windows 7
is out. ;-)
Date: 21 Oct 2009 05:26:37
Message: <4aded3cd@news.povray.org>
> is out. ;-)
Probably, for a while.  Especially in large companies there is always a big
delay between a new OS being released and that OS starting to be used.  From
my experience a lot of places are starting to roll out Vista on new
machines, I suspect that trend will continue for at least another year or so
until they have tested Windows 7 sufficiently.
Date: 21 Oct 2009 05:34:26
Message: <4aded5a2$1@news.povray.org>
>> 7 is out. ;-)
> big delay between a new OS being released and that OS starting to be
> used.  From my experience a lot of places are starting to roll out Vista
> on new machines, I suspect that trend will continue for at least another
> year or so until they have tested Windows 7 sufficiently.
Certainly the company I work for has vowed to not even touch Vista. They
were going to wait 3 years, but not I think they're looking at going
straight to Windows 7.
Weird really. As soon as a new server OS comes out, they can't install
it fast enough. But desktop OS, they tend to wait until it's a few years
old before even testing it.
