![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> with my iAUDIO M5, but only once I replaced the manufacturer's buggy
>> firmware with RockBox - a slightly nontrivial undertaking.
> Ah genius - RockBox works with my old iPod 4G and it seems like it will
> actually let me just copy&paste (part of) my mp3 collection to it and
> then play it. I *hate* the way iTunes and iPod work by assuming all the
> mp3 tags are present and correct. Going to try this out tonight...
Heh. I just hated the way iAUDIO's own firmware kept crashing and
SANDBLASTING MY EARS IN THE PROCESS! >_< Fortunately RockBox doesn't do
that. (It also allows me to do totally pointless stuff like plot and
zoom the Mandelbrot set while I'm listening to my music. Why you'd
bother with a blue/purple LCD screen I'm not sure...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> that.
I just want to navigate through my songs by the folder structure that I've
carefully set up on my PC, not by a bunch of incorrectly set mp3 tags in the
files.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> do that.
> I've carefully set up on my PC, not by a bunch of incorrectly set mp3
> tags in the files.
Yeah, I can see how that would suck pretty hard...
The iAUDIO firmware works that way in the first place, but so does
RockBox. (Annoyingly, by default RockBox only plays the files in the
current folder, rather than moving to the next folder. But there's an
option somewhere to change that. And I'm told you can configure custom
playlists somehow if you want to...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In particular I have a folder full of random songs that I like, I can find
no way in iTunes/iPod to play this folder. I thought maybe I could create a
playlist, but no of course there is no way to select every file from a
particular folder in order to create one. The best hack I could come up
with was to use a 3rd party program to give a certain comment to every mp3
file in that folder, then tell iTunes to make a playlist of songs with that
comment.
Also during my investigations I found that with the later versions of WinAmp
you can make it automatically tag an mp3 by analysing the conent (and
presumably sending it off somewhere). It's worked on every song so far, you
just select a bunch of songs within WinAmp, right click and choose "Send To:
Autotag" and it does it! I'm tempted to just select my entire mp3
collection and leave it running overnight to make sure they are all correct
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> find no way in iTunes/iPod to play this folder. I thought maybe I could
> create a playlist, but no of course there is no way to select every file
> from a particular folder in order to create one. The best hack I could
> come up with was to use a 3rd party program to give a certain comment to
> every mp3 file in that folder, then tell iTunes to make a playlist of
> songs with that comment.
> WinAmp you can make it automatically tag an mp3 by analysing the conent
> (and presumably sending it off somewhere). It's worked on every song so
> far, you just select a bunch of songs within WinAmp, right click and
> choose "Send To: Autotag" and it does it! I'm tempted to just select my
> entire mp3 collection and leave it running overnight to make sure they
> are all correct ;-)
All my files [which as Ogg Vorbis, not MP3] were created by me
personally, by encoding the data from the original CDs. I use CDex. Put
a disk in, type in all the details, hit a button, and it carefully puts
files into folders and places correct metadata inside. (Assuming it's an
album where everything is by the same artist. It can't handle
compilations properly, but it's easy enough to add the correct data with
WinAmp.)
Actually, that's a lie. My MP3 player *does* have just two MP3s on it
(and they're probably both illegal): Microsoft Jinglebells and Ugly
Girl. Go google them. ;-)
[Oh for the days when 10 CDs worth of data was considered "a lot".
KOMPLETE 5 comples on 14 dual-layer DVDs, BITCHES!]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> Perhaps you misunderstand. The sound cuts out if the bitrate goes TOO
> LOW. It never cuts out due to high bitrate.
I understand. Are you sure low-bitrate audio isn't harder to decode? Are you
sure it's not cutting out when the high bitrate comes back?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> actually let me just copy&paste (part of) my mp3 collection to it and then
> play it. I *hate* the way iTunes and iPod work by assuming all the mp3
OK so I tried this out, it was very easy to put on the iPod, literally run
the .exe, choose the mp3 player and click install. After a few minutes it
was done and my iPod was alive again!
Only problem I noticed is that pressing "skip next" sometimes takes 2 or 3
seconds to skip to the next track (I'm sure it was almost instant on the
original firmware) - that's a bit annoying but maybe there are some settings
to tweak...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> run the .exe, choose the mp3 player and click install. After a few
> minutes it was done and my iPod was alive again!
I guess it varies by player. I had to copy a bunch of files to a
specific location on the player and then reboot it while connected to
the mains.
> 3 seconds to skip to the next track (I'm sure it was almost instant on
> the original firmware) - that's a bit annoying but maybe there are some
> settings to tweak...
Yes, I notice this also. (Although on my player, the current track
continues playing while it seeks to the next one. Even so, it seems to
take a long time to seek...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeh that's what mine does too, so you press the skip button and nothing at
all happens for 2 seconds (you're then wondering if you actually pressed the
button or not), then it starts the next track. Maybe there's an option to
stop the current track immediately when you press the button, or to
pre-cache the next track or something. Still, I've hardly read the
documentation so looking forward to finding out what else it can do, there
seems to be loads of options.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> or 3 seconds to skip to the next track (I'm sure it was almost
>>> instant on the original firmware) - that's a bit annoying but maybe
>>> there are some settings to tweak...
> at all happens for 2 seconds (you're then wondering if you actually
> pressed the button or not), then it starts the next track. Maybe
> there's an option to stop the current track immediately when you press
> the button, or to pre-cache the next track or something. Still, I've
> hardly read the documentation so looking forward to finding out what
> else it can do, there seems to be loads of options.
On mine, you can do stuff like adjust how long the backlight stays on
after you press a button (so you can conserve battery power - or not),
whether tracks cross-fade into each other, whether it advances to the
next folder or loops or stops when it finishes all the tracks in the
current folder, and so on. I believe you can also install themes...
(I don't know about your player, but mine has a moderately large purple
LCD on it.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
