POV-Ray : Newsgroups : povray.off-topic : For a price Server Time
15 May 2026 17:44:03 EDT (-0400)
  For a price (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: For a price
Date: 18 Aug 2009 04:32:35
Message: <4a8a6723$1@news.povray.org>
Chambers wrote:
> How hard would it be to get a couple of pressure sensors, and wire them
> up to a MIDI plug so you could have your own?
Harder than you'd think.
A peddleboard needs to not break when an 80 Kg person stamps on it. This
is non-trivial.
Where the hell do you buy pressure sensors?
You realise that MIDI is a serial communications protocol, right? It's
not like you just connect each sensor to a different pin on the plug;
you need some fairly elaborate electronics in there.
> Then you could go to the pub and tell some random girl, "Hey, baby, you
> ever dated a guy who wired his own base?" :)
*facepalm*
Date: 18 Aug 2009 04:35:26
Message: <4a8a67ce$1@news.povray.org>
>> them up to a MIDI plug so you could have your own?
> That's what I thought the moment I saw it.  Or maybe simpler to buy a
> standard cheap MIDI keyboard to get all the electronics and rig up some
> nice wooden pedals to it.
I guess that's a possibility, assuming I can find one that isn't
touch-sensitive. (For some reason, as soon as you buy a stand-alone MIDI
controller everybody automatically thinks you want the finest
weighted-key action with touch sensitivity and polyphonic aftertouch...
Hence, keyboards that have MIDI are quite cheap, but MIDI keyboards are
surprisingly expensive.)
Assuming you find one that isn't touch-sensitive, so pressing a key just
closes a circuit, it should be possible to rig something up.
The next problem is going to be how to make it sturdy enough to not fall
apart. ;-)
Date: 18 Aug 2009 05:08:32
Message: <4a8a6f90@news.povray.org>
> touch-sensitive.
Oh ok I didn't realise the pedals didn't need to be touch sensitive, even
simpler then!
Alternatively use another input method to a PC (you can get multiple digital
input to USB boards) and then generate the MIDI signals in software.
> apart. ;-)
The pedals are not going to be taking massive forces so you don't need to
worry about using bearings or anything fancy like that.  I would just put a
hole through the pedal at the back and let it rotate on a bolt that is
secured to some base-plate.  That way you can place each pedal at a
different angle.  To provide the resistance just glue on a lump of stiff
rubber underneath each pedal and mount a micro-switch to trigger at the
correct position.  Shouldn't take too much work.
Date: 18 Aug 2009 05:37:49
Message: <4a8a766d$1@news.povray.org>
>> touch-sensitive.
> even simpler then!
I'm trying to simulate a pipe organ here. They're generally not
particularly touch sensitive. ;-)
[Although... the mechanical-action ones *are* very slightly touch
sensitive, which not a lot of people know.]
>> just closes a circuit, it should be possible to rig something up.
> digital input to USB boards) and then generate the MIDI signals in
> software.
I'm guessing generating MIDI signals in software is going to be intractable.
>> fall apart. ;-)
> to worry about using bearings or anything fancy like that.  I would just
> put a hole through the pedal at the back and let it rotate on a bolt
> that is secured to some base-plate.  That way you can place each pedal
> at a different angle.  To provide the resistance just glue on a lump of
> stiff rubber underneath each pedal and mount a micro-switch to trigger
> at the correct position.  Shouldn't take too much work.
For one thing, it's going to take some big chunks of solid wood, and a
big iron bolt. Given how ludicrously expensive actual wood is, I guess
it might not even come out any cheaper than just buying the one in the
shop...
Date: 18 Aug 2009 05:42:43
Message: <4a8a7793$1@news.povray.org>
Ooo, hey! Maplin had a roll-up keyboard MIDI-controller thingy. Add some
mechanical linkage and some springs and you got a MIDI peddalboard. :-D
The only *minor* detail that remains is... building a peddalboard in the
first place. :-/
Date: 18 Aug 2009 06:07:24
Message: <4a8a7d5c@news.povray.org>
> intractable.
http://msdn.microsoft.com/en-us/library/ms711640(VS.85).aspx
I believe also if you have access to DirectX on your system then DirectMusic
offers a higher level interface to the MIDI controller.
> For one thing, it's going to take some big chunks of solid wood, and a big
> iron bolt.
An M4 or M6 standard steel bolt will do, you're not going to be levering up
cars with this thing!
It's only expensive *after* someone has spent time shaping it and treating
it.  Raw wood is pretty cheap, I would imagine that enough for a set of
pedals is not going to cost more than fifty quid.  It's up to you how much
time you then want to spend shaping and treating it.
> I guess it might not even come out any cheaper than just buying the one in
> the shop...
Oh it will definitely come out at least an order of magnitude cheaper, but
of course it's going to take some time and skill on your part...
Date: 18 Aug 2009 06:15:14
Message: <4a8a7f32$1@news.povray.org>
>> intractable.
> DirectMusic offers a higher level interface to the MIDI controller.
http://msdn.microsoft.com/en-us/library/dd551276(VS.85).aspx
"Warning: This technology is deprecated as is all of DirectMusic."
Gee, thanks for telling us what the recommended alternative is. :-P
I wonder though... I've always thought of writing "fancy" Windows
programs as intractable, since it requires calling the Win32 API, and
very few useful programming languages can do this. However, I did
successfully write a Haskell library that talks to the Windows console
functions, and it worked fine. I wonder if it's really possible to write
a Haskell library that does something nontrivial like sending and
receiving MIDI messages?
>> big iron bolt.
> up cars with this thing!
I'm guessing you can't buy that stuff at the local hardware store though.
> treating it.  Raw wood is pretty cheap, I would imagine that enough for
> a set of pedals is not going to cost more than fifty quid.  It's up to
> you how much time you then want to spend shaping and treating it.
Well, I don't have to worry about splinters. ;-) I suspect cutting it to
a precise shape isn't going to be easy though. Hmm, I'll have a think
about it.
>> one in the shop...
> but of course it's going to take some time and skill on your part...
Indeed.
Date: 18 Aug 2009 06:48:42
Message: <4a8a870a$1@news.povray.org>
Hehe yes true, it doesn't look like they do suggest an alternative for
communicating with MIDI hardware!
> I wonder though... I've always thought of writing "fancy" Windows programs
> as intractable, since it requires calling the Win32 API, and very few
> useful programming languages can do this. However, I did successfully
> write a Haskell library that talks to the Windows console functions, and
> it worked fine. I wonder if it's really possible to write a Haskell
> library that does something nontrivial like sending and receiving MIDI
> messages?
It should be no problem if you can call Windows API functions, the ones for
MIDI control are all still there.
Of course you can and they're dead cheap, B&Q will have a good supply of M4
and M6 bolts (plus many other diameters) at all sorts of lengths and head
types.  They do nuts and washers too.
> I suspect cutting it to a precise shape isn't going to be easy though.
If you're making a load of pedals then I would be tempted to first make a
jig so that you can cut each one to exactly the same dimensions.  You can
finish them off with some sand paper or an electric sander (more expensive
but faster).
Date: 18 Aug 2009 06:59:45
Message: <4a8a89a1$1@news.povray.org>
That was the conclusion I came to also, yes.
Their main section on MIDI control still mentions the same function
names, so...
http://msdn.microsoft.com/en-us/library/ms712733(VS.85).aspx
>>> levering up cars with this thing!
> M4 and M6 bolts (plus many other diameters) at all sorts of lengths and
> head types.  They do nuts and washers too.
B&Q sell nuts and bolts, but I doubt they sell large pieces of metal
such as random poles and rods.
> a jig so that you can cut each one to exactly the same dimensions.  You
> can finish them off with some sand paper or an electric sander (more
> expensive but faster).
My dad probably already has an electric sander or five.
I think the basic problem is that even if I do all this, it's never
going to be exactly like a real organ peddalboard. The whole point of
practicing is to get used to the feel of the real thing, so... I guess
I'll just stick to sneaking into the local church on saturdays. Much
cheaper. ;-)
Date: 18 Aug 2009 07:29:32
Message: <4a8a909c$1@news.povray.org>
> B&Q sell nuts and bolts, but I doubt they sell large pieces of metal such
I suspect they do actually, but I wouldn't do it with those.  I would get a
sheet of wood about 20 or 30mm thick to use as the base board.  I would then
get a thin strip of aluminium (25x2 cross section would be perfect, I got
metre lengths of that from B&Q before), cut it into perhaps 150mm lengths
and bend it into a U shape.  The bottom of the U I would bolt onto the base
board for each pedal, then fix an M4 bolt horizontally across the top of
each U with the pedal mounted on it so it's free to rotate.
Job done then!
> I think the basic problem is that even if I do all this, it's never going
Isn't there any way you can replicate what the pedal is actually connected
to in a real one?  It shouldn't be hard to think of something to replicate
the feeling.
