POV-Ray : Newsgroups : povray.off-topic : Heavy metal Server Time
8 Feb 2026 17:52:25 EST (-0500)
  Heavy metal (Message 7 to 16 of 46)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Heavy metal
Date: 1 Jun 2009 15:33:21
Message: <4a242d01@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> Last I heard, airplanes aren't exactly "cheap", nor are cars, and
> cookware made of alunimium rather than steel is vastly more expensive.
  That only tells that steel is cheaper than aluminum, not that aluminum
is super-expensive.
Date: 1 Jun 2009 15:51:53
Message: <op.uuu2spfo7bxctx@e6600>
On Mon, 01 Jun 2009 20:24:51 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
Airplanes and cars are expensive, but not primarily because of raw material
costs I think.
> and cookware made of alunimium rather than steel is vastly more
> expensive.
The only reasonably useful aluminium cookware I have seen are frying pans,
and those are always Teflon-coated. Even so, I have not found them to be
more expensive than their cast-iron counterparts. In fact, the cheapest
ones are typically aluminium.
> (Ditto for computer cases.)
The same goes for computer cases; the cheapest ones are aluminium.
FE
Date: 1 Jun 2009 17:06:32
Message: <4a2442d8$1@news.povray.org>
> pans, and those are always Teflon-coated.
http://www.vita-mix.com/household/products/neova/
Highly recommended, btw. :-)
Aluminum conducts heat almost as well as copper and is less prone to
corrosion and is lighter, so it's a good choice for cookware.
   There's no CD like OCD, there's no CD I knoooow!
Date: 1 Jun 2009 18:34:40
Message: <op.uuvab1rh7bxctx@e6600>
Yeah, I have seen multi-layer cooking pots, but I would tend to classify
those as steel pots. I will admit, though, that there may be sufficient
aluminium in there to noticeably affect the material cost.
As an aside, I do own several "pure" aluminium pots. They work fine, but
they get ugly with old age.
I prefer iron; cookware that lets you cook *and* work out at the same time.
FE
Date: 1 Jun 2009 18:44:39
Message: <4a2459d7$1@news.povray.org>
> time.
You just have to be careful not to put things that are overly acidic into
the container - and remember not to scrub it with a wire brush (had a
friend who was being helpful and didn't know better with our cast iron
skillet....took us about 4 months to re-season the surface.  On the plus
side, bacon for the WIN!)
Jim
Date: 1 Jun 2009 20:10:09
Message: <4a246de1@news.povray.org>
Invisible wrote:
> OK, so I've been experimenting with Wolfram's Alpha thingy. Useful if
> you happen to want to know how long 10^15 seconds is, if you want a
> graph quickly, or if you want to look up the electrical resistence of
> silicon. Not much use for anything else.
I read this in a Facebook comment:
"This search engine is useless!
http://www.wolframalpha.com/input/?i=britney%20spears%20naked"
Date: 1 Jun 2009 21:34:45
Message: <4a2481b5$1@news.povray.org>
> the container
Why? The old Alzheimer's thing?  I think they figured out that was a
procedural error.
Date: 1 Jun 2009 22:11:08
Message: <4a248a3c@news.povray.org>
>> into the container
> procedural error.
Nope, acidic foods can destroy the "seasoning" of cast iron, and if you
then wash it in water, you can cause the pan to oxidize.
But even if you don't use water, stripping the seasoning off the pan can
create a metallic taste in foods cooked in the pan.  As Alton Brown would
say, that's definitely NOT good eats.
Jim
Date: 1 Jun 2009 22:17:14
Message: <4a248baa$1@news.povray.org>
Oh, right, sure. I thought you were talking about the aluminum. My bad.
Date: 1 Jun 2009 23:10:05
Message: <4a24980d$1@news.povray.org>
Ah, I see.  I hadn't heard the Alzheimer's thing before.  :-)
Jim
