POV-Ray : Newsgroups : povray.off-topic : Blender Server Time
7 Apr 2026 00:44:54 EDT (-0400)
  Blender (Message 21 to 30 of 35)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Blender
Date: 15 Feb 2009 17:53:42
Message: <49989cf6$1@news.povray.org>
nemesis wrote:
> Best way to get into Blender is to slowly learn your way through both
> its 3D space and through its interface, which is organized in panels
> containing related functionality.  All of it via keyboard, of course.
 From what I can tell, most everything can be accessed without the mouse at
all, which is nice. When you can't remember the button, you can grope around
thru the menus until you find something.
My main stumbling blocks seem to center around the system doing the wrong
thing to be fast by default, in preference to doing the right thing slowly,
which you have to figure out how to set up.
Otherwise, it seems pretty straightforward. Altho there are a couple (so
far) of bothersome limitations, particularly in the textures. (Like, I don't
know how to do checkerboards or hex shapes or some of the other stuff POV
has built in, and you can't rotate a texture directly, so your wood rings
are fixed in one axis - just minor stuff like that).
I've played with Hash Animation:Master, so most of the concepts (bones,
strides, texture stacks, etc) are familiar, at least.
This is an awesome site for the parameters of the simulators:
http://www.pkblender.it/index.html
(What should be in the documentation to start with. :-)
And this guy does a great job of showing how to model something that isn't
organic, which HAM made exceedingly difficult in my limited experience:
http://www.vimeo.com/groups/9075/videos/812311
Hope that helps anyone else who might be playing with Blender soon.
> I don't know, I'm a single-monitor guy. ;)
It's amazing how helpful it is, altho I don't understand people who put the
space between the monitors right in front.
I saw one video of a UI idea, where when you're doing drag-and-drop, you can
peel back the corner of the window you're over to expose the window
underneath. I think D-a-D is the biggest win with a bigger monitor. :-)
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 15 Feb 2009 20:30:00
Message: <web.4998c146f1240d5549817ca0@news.povray.org>
Much more powerful procedural textures are coming to Blender soon enough,
completely modifiable via the nodes editor as well.  Anyway, most people into
Blender -- and most other 3D apps as well -- simply use image maps, though
being a povhead myself, I never quite adapted to the whole UV-unwrap thing
either.
Yeah, I've did any animation either.  I'm a still guy.
OTOH, I'm pretty happy myself with the newer monitor that came with my new
q6600.  More available screen estate to the sides.  Though I know some people
who simply occupy the whole screen with a single window, because that's the
standard Windoze way. ;)
Date: 15 Feb 2009 21:08:40
Message: <4998caa8$1@news.povray.org>
> either.
I had noticed that. The POV community seems more purist, perhaps because
POV's procedural textures are more powerful. One of my experiments consists
of seeing how to get POV to render a texture in a way that I can use it
easily as an image map.  (Not hard. Just a matter of getting the texture
stack full of normals and displacements and all that right.)
I never understood that myself. Blender makes it easy to work that way, but
I usually get nuts of windows are under other windows.
   "Ouch ouch ouch!"
Date: 15 Feb 2009 21:10:00
Message: <web.4998c9c6f1240d55aac76da0@news.povray.org>
> Does anyone here use blender?
I tried three times to get warm with "Blender".
I try it real serios and try to have no prejudices.
And certainly "Blender" have some nice features.
But the conceptional difference between POV-RAY and
"Blender" is not conquerable for me - at the moment.
Date: 15 Feb 2009 21:15:01
Message: <web.4998cb24f1240d554726e92b0@news.povray.org>
> Oh no, I do believe I said POV-Ray's texture system was superior in many
> ways to Blender's:
http://news.povray.org/povray.general/thread/%3Cweb.48fdae14f034d1aa519bbb570@news.povray.org%3E/
> Each program has its strong points, so it's all a matter of preference.
>   POV-Ray is a much more *fun* environment to experiment in.
> Sam
Okay, I guess my memory's not what it once was, heh! And no, I don't recall ever
seeing a Blender image posted here by you :)
But I'm sure I speak for a lot a folks when I say that your POV insights and
macros are an inspiration Sam; you produce some amazing work :)
Date: 15 Feb 2009 22:51:03
Message: <4998e2a7$1@news.povray.org>
> either.
Well, I don't get how they do it anyway. I mean, you "unwrap" your mesh
to a pattern which is either a) sort of like the original, but not
really, or b) a lot of squares, where you can't tell the original
geometry. Then you paint it, reimport, overlay it into the UV pattern
then how the frack it works. Think the guys with.. deep paint, or what
ever its called, have it right. Lose the idiot, "make it some place
else, then glue it on like a label", BS and just paint directly on the
object, like you would in the real world. If you can't precisely control
the texture, its position, etc., or get an "accurate" mesh layout to
draw into, what is the point? And, even if its "may" be accurate,
technically, it takes a very different mind than mine to "get" how the
two correspond, without having some way to "see it" as I am doing the
drawing.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 16 Feb 2009 01:12:18
Message: <499903c2$1@news.povray.org>
In Blender it is possible to paint directly on the model using texture
paint. Works best if it is a low-poly model with subsurf that can be turned
off while painting. It isn't something that I've completely mastered but I
have been able to get it to work pretty well. That is how I created the
texture map for this model http://www.youtube.com/watch?v=JqmRT87HhtE
I created a grid pattern for the uvmap, unwrapped the head and applied the
map, and then used texture paint to block in the colors, like the eyebrows,
eyeliner, lips, and blush. The image at that point shows the features well
enough to figure out what-goes-where and then I added details in photoshop.
Takes quite a long time so I've been putting it off for several other models
in the works. I find the hardest part is remembering all the steps involved
in using the uv editor.
Mike
"Patrick Elliott" <sel### [at] npgcablecom> wrote in message
news:4998e2a7$1@news.povray.org...
>>> don't
>>> POV
>>> rings
>> into
>> though
>> thing
>> either.
> Well, I don't get how they do it anyway. I mean, you "unwrap" your mesh to
> a pattern which is either a) sort of like the original, but not really, or
> b) a lot of squares, where you can't tell the original geometry. Then you
> paint it, reimport, overlay it into the UV pattern then how the frack it
> works. Think the guys with.. deep paint, or what ever its called, have it
> right. Lose the idiot, "make it some place else, then glue it on like a
> label", BS and just paint directly on the object, like you would in the
> real world. If you can't precisely control the texture, its position,
> etc., or get an "accurate" mesh layout to draw into, what is the point?
> And, even if its "may" be accurate, technically, it takes a very different
> mind than mine to "get" how the two correspond, without having some way to
> "see it" as I am doing the drawing.
> void main () {
>   else
> <A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models, 3D
Date: 16 Feb 2009 01:42:30
Message: <49990ad6$1@news.povray.org>
That's one of the things Animation Master got right. You could just stamp an
image down. Especially nice if you modeled something based on orthographic
views, because then you could just slap the image down.
I saw another program where you could draw the geometry, then hand basically
a frontal view to an artist who would paint on the view you'd see from the
camera, and then you could import that right back onto the model. Find spots
you couldn't see, get the artist to fill them in, reimport, lather rinse
repeat. The examples used buildings in game levels, so I'm not sure how good
it would be for faces or something. It helped that you could put some basic
texturing on the buildings and let the artist fill in details like dirt and
rust and signs and cobwebs and doorknobs and stuff.
The UV mapping in blender lets you do other stuff, tho, too, like
automatically baking shadows into the images so you can turn the ray-tracing
off for drawing animations, and stuff like that.
It's a very complicated program.
   "Ouch ouch ouch!"
Date: 16 Feb 2009 02:43:31
Message: <49991923@news.povray.org>
Glad you seemed to have fixed your problem yourself - sometimes the last
resort is to make a post somewhere in the hope of getting an answer!
Personally I've mainly used Blender for mesh generation and simple UV
texture mapping (for export for use in a game), but I did dabble a bit with
the bones and animation features.  I do remember a couple of things about
that where, like you say, doing seemingly exactly the same thing would
sometimes work and sometimes not (to do with getting an animal walking).  To
this day I don't think I ever figured out what it was, and the tutorials I
was following seemed to be based on a previous version of Blender.  I just
lost interest in the end.
Date: 16 Feb 2009 06:33:27
Message: <49994f07$1@news.povray.org>
Am Sat, 14 Feb 2009 13:08:53 -0800 schrieb Darren New:
I'm using it. Not for rendering mainly, but for designing cardboard
models (ok, not the best-suited program for that task like for example
Rhino, but Rhino isn't free as in beer). Modelling, constructing and
scripting basically.
OOC, does anybody here do cardboard modelling (or papercraft, whatever
you call it)?
Micha
