Orchid XP v8 wrote:
> Darren New wrote:
>> Personally, I'd leave "bright" in there. You'll have to decide. :-)
> OK. Fair enough.
For my thinking, it's telling them something about how you see yourself.
Certainly if you put "dedicated" or "loyal" or something in there, it
would be saying something else.
>> "Learned Tcl/Tk in a week" is misspelled.
> Damn. Now I have to figure out why it's misspelt...
My copy says "leaned Tcl/Tk." Unless *I* misread it. :-)
> Heh. You really do enjoy subtly implying that I'm more important than I
> really am, eh? ;-)
That's part of what you have to do.
> How about "rigourous recording of changes"?
Good.
> Soft systems are warm, fuzzy things that are ill-defined. The kind of
> thing where figuring out exactly what you're trying to do is usually the
> hard part.
Uh, OK. Never heard that term. Maybe it's a British term.
"Underspecified" might be the term I'd use, but again you take a look
and decide. It just struck me as odd.
On 21-Nov-08 21:47, Orchid XP v8 wrote:
> andrel wrote:
>> Better.
> That's usually a good start...
>> I am still missing the games group you are in. At least I suppose that
>> is a hobby of yours.
> Didn't seem highly relevant. (I suppose you could attempt to pretend
> that this illustrates teamworking or social skills or something... but
> mainly it involves shooting things!)
It does illustrate that you are not the social inept moron that you are
trying to pretend. Remember: they asked you to be on the team. You even
met IRL and you were not thrown out immediately. (The reason they asked
nor the reason why they keep up with you does matter, so don't give your
version in a job interview).
>> Tcl/Tk is in point 5 but not in 3.
> It's in point 2 though.
sorry missed that. That is probably a good sign.
>> If you would apply for a job more in my field then you may tell a bit
>> more about what your company does. 'policy and procedure documents'
>> are one thing, but for work in a medical lab you may be much more
>> qualified than most.
> Our lab doesn't do diagnostic stuff, only quantitation.
irrelevant IMO, our lab is in a constant transition to more regulation
(partly because of the hype of the time and partly because the type of
research is changing) you seem to know at least partly what kind of
regulations are out there *and* you know how to implement such measures.
If someone here notices that they might even create a job description
for you just to get you in. Pity you seem to be stuck in that hole in
the UK.
> (Actually, all the mass spectrometers say "NOT FOR DIAGNOSTIC USE" on
> them in big lettering. I'm not sure why... Presumably if you want to do
> diagnostic work, they sell you an identical machine for 12x the price.)
I know a company that does do the labeling and the reason is simply that
they a) don't want to get sued for misdiagnoses because their system
happened to be in the same room. b) they are a small company that can
not afford expenses associated with the testing. and c) their
administration of the development and production is not even remotely
resistant to an medical grade audit. Not everybody can afford an Andy,
you know.
Orchid XP v8 wrote:
> OK, so I *think* I've taken nearly everybody's suggestions on-board.
> What do we think of this then?
One more comment by the way. Nowhere does it actually say "Windows", as
far as I can remember. You might want to mention you administered AD,
and that some of your scripts were work-arounds for design flaws in
roaming profiles, for example.
(What, you think nobody remembers what you complain about? :-)
On Fri, 21 Nov 2008 20:48:12 +0000, Orchid XP v8 wrote:
> Jim Henderson wrote:
>> "Troubleshooting" is a good general term for this, or "problem
>> diagnosis and resolution".
> Troubleshooting is the term I'd go with.
It's a good one; "problem isolation" is another that I've seen.
Jim
Another that gets attention is "root cause analysis".
Jim
Personally, I'd say fault finding ;)
Seriously, on this side of the Pond. The simpler the word or phrase the better.
I'd rather hire someone who could do a good job rather than talk a good job.
"Troubleshooting" is acceptable but it would be more applied to whole system
problems not individual equipment faults.
I think it's interesting that "fault finding" sounds like a "blame game" to
Darren. Here a phrase like "root cause analysis" would get the CV passed around
so everyone could have a good snigger. Again two countries separated by a common
language :)
Regards
> (The information about my degree is incomplete and possibly incorrect; I
> can't seem to find the transcript right now.)
> I've basically dumped in everything that seems remotely relevant.
> Presumably before I finalise this document I'll need to trim it back
> down again a little.
Much better.
Many people have further comments about what could be improved. Some I
agree with, some I don't. You decide.
However it is now at the stage where the major improvements have been made.
I'd be much more likely to interview somebody based on this version.
Your original I would have declined without even reading it all the way
through.
So, stage 2 - Get applying.
Cheers.
> better. I'd rather hire someone who could do a good job rather than talk
> a good job.
> system problems not individual equipment faults.
See, over here, we troubleshoot everything from system-wide faults to
individual hardware component failures.
> to Darren. Here a phrase like "root cause analysis" would get the CV
> passed around so everyone could have a good snigger. Again two countries
> separated by a common language :)
Ain't that the truth. :-)
"Fault finding" to me does imply "blamestorming" as well - the result of
"fault finding" is that "it's your fault", so has a very negative
connotation in most parts of the US IME.
Jim
Lordy, lordy you'll have me speaking 'Merican yet. :)
Tell me about it!
I suppose that differentiate it by saying someone is finding fault.
Regards
One by one. ;-)
>>> game" to Darren. Here a phrase like "root cause analysis" would get
>>> the CV passed around so everyone could have a good snigger. Again two
>>> countries separated by a common language :)
> Tell me about it!
Well, you see, you're in the UK, I'm in America, we both speak English
but we can't understand each other. I thought you understood that, but I
hope this clears things up a bit. ;-)
I think the evolution of language, though, means that one who finds fault
engages in fault finding. ;-)
Jim
