POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
5 Jul 2026 08:45:48 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 131 to 140 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 6 Nov 2008 12:53:08
Message: <49132f04$1@news.povray.org>
Darren New wrote:
> Well, it asks once per process you invoke with admin rights, just like
> sudo. No, sudo doesn't ask for the password every time, but it makes you
> type "sudo" every time, which was kind of what I was saying.
BTW, what prevents a program from trying to run sudo, just to see if
your sudo hasn't expired yet, and thereby taking over your machine? I
mean, if I don't have to actively confirm every request, why can't a
program just occasionally try to trojan its way in?
And, for the record:
1) SP1 apparently vastly improved how rarely you needed to UAC.
2) You can turn off UAC confirmations for administrators.
3) You can set administrators to needing to provide the password too.
4) There's a mildly hacky way (equivalent to setuid) to set up specific
programs to run as administrator without any prompting.
So it's pretty flexible. If you want a root account, log in as
administrator and turn off the UAC for administrators only. :-)
Date: 11 Nov 2008 19:26:21
Message: <491a22ad@news.povray.org>
On Thu, 06 Nov 2008 18:53:22 +0200, Eero Ahonen wrote:
> Jim Henderson wrote:
>> OK - probably won't have time to look much until the weekend anyways.
> BTW, there's no installer nor install instructions, but luckily the
> directory structure of the package is pretty simple ;). Diff files
> before overwriting your old ones (ie. apaches httpd.conf), if you're
> running anything else on that machine.
Will do.  Thought I'd have time this weekend, but ended up busier than I
thought...
>>> 64-bit, running Gentoo Linux (surprisingly).
>> Why surprisingly? ;-)
> SaoIP (Sarcasm-over-IP).
Ah, I get it. :-)
>> That's true enough.  Now I just need to convert from PDF to Framemaker
>> and we've got the original files to work with again.  :-)
> Heh, conversion tunnel ;).
More or less, yes. ;-)
Jim
Date: 11 Nov 2008 19:27:11
Message: <491a22df$1@news.povray.org>
>> you type "sudo" every time, which was kind of what I was saying.
A proper sudo configuration.  Which arguably I don't have. ;-)
> 1) SP1 apparently vastly improved how rarely you needed to UAC. 2) You
> can turn off UAC confirmations for administrators. 3) You can set
> administrators to needing to provide the password too. 4) There's a
> mildly hacky way (equivalent to setuid) to set up specific programs to
It's good to know they've fixed a few things, should I ever have a need
to go back. :-)
Jim
Date: 11 Nov 2008 20:09:26
Message: <491a2cc6@news.povray.org>
What would be a proper sudo configuration?  What would you have it do,
other than (say) require the human to check sudo failure logs regularly
or something?
> to go back. :-)
Yes. Almost all (but certainly not all) of the complaining I've seen was
either about beta versions of the stuff, or just plain wrong (such as
complaining "they should have left an advanced way to do X" when they
already did, and the review just wasn't advanced enough to find it).
I must admit, this is the first time Windows has "improved" that I've
immediately liked the new version better than the old, just in terms of
look and functionality and such. Altho it does seem to be even more
dumbed down, lacking (for example) progress bars for many things you'd
think would have progress bars. And omitting useful functionality (like
backups? Come on...) unless you pay for the full packages and more.
Mine worked much better once I scraped all the proprietary ad-ware off
the thing, and put on only the device drivers it didn't already have
signed copies of from Microsoft.
Of course, I haven't used it for real work yet, so maybe it's a lot
flakier. But as a concept, it works for me. :-)
Date: 11 Nov 2008 21:48:38
Message: <491a4406$1@news.povray.org>
> or something?
Not use the NOPASSWD keyword, primarily.  On a critical system, I
wouldn't allow that in the file at all.  That would prevent a trojan such
as you describe from successfully using sudo to act as root.
On such a system, I'd also do other things, too, like require public key
authentication via SSH and disable root's remote access via SSH.
>> to go back. :-)
Whereas for me, I used it for about 15 minutes and then rebooted the
machine into openSUSE 11.0 and left it there.  Vista's still there, but
pretty much all of my apps are Linux-based now, so I don't have a need
for it, really.
Jim
Date: 11 Nov 2008 21:58:58
Message: <491a4672@news.povray.org>
Oh, well, yes. Then you get what UAC does. That was kind of my point. I
mean, people were complaining that UAC asks for a password for every
process that need root privs. I was just wondering why this isn't a good
thing.
> for it, really.
Yep. To each his own. :-) I already had to reinstall OpenSuSE 11 twice
due to it doing f'ed up things I couldn't figure out how to undo. Like,
taking the "start button" off the "task bar", or screwing up the package
management system so that attempts to update crash out.
(BTW, I *hate* the new package update thingie in SuSE 11. Confusing as
hell, and doesn't work nice at all.  Warp talks about rearranging menus
- how about an "accept" button that doesn't actually install the listed
updates until you push another button that reveals the magic button that
says "Yes, this is what I want to accept". Sheesh.)
Date: 12 Nov 2008 14:13:54
Message: <491b2af2$1@news.povray.org>
> thing.
I think it's largely a mindset - coming from a Windows background, one
typically is used to just being able to do things.
On *nix platforms with sudo, the mindset is a little different, but also
having the option to use NOPASSWD (which is ignored actually by kdesu and
gnomesu).  When I installed VNC on Vista, UAC prompted me *several* times
during the installation, and that was a pain.  With Linux, I get asked
once during a software installation.
>> for it, really.
KDE or GNOME?  I haven't had those issues as a GNOME user.
I've not had that problem - using KDE or GNOME?  (I use GNOME, and found
the updater works very well and makes a lot of sense - the only thing I
don't like is that it only applies patches - security patches, for
example - and doesn't do application upgrades).
Jim
Date: 12 Nov 2008 14:55:01
Message: <491b3495$1@news.povray.org>
Yes. I was amused by one reviewer complaining he got a UAC prompt trying
to change the time.
Maybe MS could put UAC prompts in appropriate to the version of the OS.
Home users can change the time without a prompt, while enterprise
versions need a prompt, for example.
> gnomesu).
Yah. You can do this just by logging in as administrator, for example.
Then you get no prompts at all.
Yeah, they could obviously clear this up. Maybe you would have had
better results using "run as administrator" on the install script, as I
expect VNC was installing (for example) both the client and the server,
perhaps as launching separate executables.
GNOME. I didn't have them in KDE SuSE 10, either.
I think I'm just f'ing unlucky. I seem to run into every weird problem
that no other Linux user ever has trouble with. Must be my morphogenic
field or something.
GNOME, this time. I'm just picking "yast" off the system menu and going
to the "update" stuff.
It used to be YaST would say "Hey, there's three packages to install to
update the installer. Click "OK" to install them, and I'll restart."
Now it tells you there's three you ought to install, so go scroll thru
the list of 600 updates and find just those three, then click on each to
make the "install" button appear, then click on the "Install" button,
*then* accept it.
And don't just select all the packages and say "install", because then
we'll warn you that we're about to break stuff, even if we really aren't.
I just think the UI went really downhill there, even if it makes more
sense to someone more experienced.  Or maybe there's a better way to get
to the same functionality now, or something.
Except it locks the package manager for several minutes when I log in.
(Probably less annoying than in SuSE 10, where it downloaded the package
lists every time you logged in.)  Assuming you're talking about the
automatic one that runs in the systray-equivalent.
That's what I *thought* I was turning off when I confirmed ditching the
"start menu" button, since it had crashed out repeatedly with bad
package repositories or something. And just *try* to figure out how to
get that button back when it's gone. ;-)  Since I had *just* made a full
backup, it was easier to restore than to look up what I needed to know.
Date: 17 Nov 2008 17:16:32
Message: <4921ed40$1@news.povray.org>
> to change the time.
That would probably make more sense.  Or make it configurable via a GPO
but have the defaults be sane for the home user.
>> also having the option to use NOPASSWD (which is ignored actually by
>> kdesu and gnomesu).
On Vista?  I ran the home version here, and was logged in as
administrator (hadn't created another user as of yet IIRC).  But maybe
running the "Home" version was my problem. ;-)  Certainly, pre-SP1.
>> When I installed VNC on Vista, UAC prompted me *several* times during
>> the installation, and that was a pain.  With Linux, I get asked once
Maybe, but it was packaged as a single MSI.
>>> Like, taking the "start button" off the "task bar", or screwing up the
>>> package management system so that attempts to update crash out.
Right click the panel and select "Add to panel" - then filter to
"Menu".  :-)
> field or something.
LOL
> *then* accept it.
> aren't.
You don't want to use YaST to do updates - I see what you're talking
about, and yes, that is confusing.  I use the updater applet which is
really clear.  The one thing I don't like, though, is that application
upgrades aren't included in the updater - you have to install those
separately for some reason.  I'm hoping they've addressed that in 11.1.
It shouldn't take that long - they got rid of the old zmd stuff from 10.x
(which was absolute garbage - they took Red Carpet from Ximian and ported
it to run as a Mono app; thing is, Mono wasn't ready for prime time yet,
and using your updater app to showcase a new technology is just mind-
bogglingly stupid IMNSHO) and replaced it with packagekit.  I've found
that to be MUCH better.
Jim
Date: 17 Nov 2008 17:26:58
Message: <4921efb2$1@news.povray.org>
Actually, it's kind of weird to me that you can turn off the computer
from a remote login without a UAC prompt, but you can't (say) change the
clock.  Strange.
And it still takes two UAC prompts to change "advanced" power management
settings. (Or maybe a different number if you're actually at the console
and not logged in remotely? It's a bit weird, IIRC.)
> On Vista?
On my version, yes. Or go into Local Policies and set it up how you
like. But on mine, by default, UAC is set to allow the actual
"Administrator" account anything. (You have to actually turn on the
ability to log in as administrator.)
Note I'm not talking "Member of the Administrators group", but the one
actually called "Administrator".
> "Menu".  :-)
Ah, thank you.  Yes, as I say, I probably could have solved it, but
since the problem happened as I booted back from a full restore, I
figured it was easier than actually trying to figure it out just then
and there.
Vista, on the other hand, has apparently made it impossible to
completely hide or reposition the task bar, or to pull toolbars off of
it. Given how often I've seen someone want their start button in the top
right corner vs how often I've seen it there, I can't fault this change.
> I use the updater applet which is really clear.
The thing in the "system tray" area? I never liked that. For one, it
would take a long time every time you logged in to check for updates,
preventing you from actually doing any package management or logging out
cleanly or whatever. (As I said, probably fixed now that they don't suck
down manifests every time.)
This is a complaint? ;-)
Cool. Maybe I'll turn it back on, when I get another job doing linux stuff.
