POV-Ray : Newsgroups : povray.off-topic : New router Server Time
7 Sep 2024 03:21:43 EDT (-0400)
  New router (Message 1 to 10 of 10)
Subject: New router
Date: 18 Sep 2008 12:55:19
Message: <48d287f7$1@news.povray.org>
Dammit, this was hard to install and setup! Heh...
  I bought a Netgear router and it took nearly a day to install and setup,
and honestly, I don't know *how* I did it. I changed so many settings that I
think it was just luck in the end. Anyway, it's working now.  :)
  Ok, so those of you that are more experienced than me with routers, is
there anything that I should look out for? Security wise? I mean, this
router has an onboard firewall, but I have no idea whether it's active or
not. Where are the folders? lol. I have one folder called 'Netgear' in C:,
but as far as I can tell, none elsewhere...  :oO
    But this folder contains nothing usable, (it looks like that to me at
least), so how do you get 'into' these things?
    Also, in the tray, I have the two network tv's flashing away, but when
you hover over the icon it gives the speed as 100Mbps! o.o
    So where can I look locally to get the correct speed?
       ~Steve~
Subject: Re: New router
Date: 18 Sep 2008 13:11:53
Message: <48d28bd9@news.povray.org>
Which is the speed between your PC and the router, yes.
Ah, you want the speed between the router and the Internet? Well, that
is anoter matter... ;-)
If you dig around the settings for it, there might be a "status" or
"statistics" page somewhere that tells you something useful.
http://blog.orphi.me.uk/
Date: 18 Sep 2008 13:36:11
Message: <48d2918b@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:48d28bd9@news.povray.org...
>> when
    Ah! Cool! :) So that means I can genuinely say that I "have access to a
100Mbps connection" then...  Heh... :)
      Tell me about it!! Man, I feel that my computer is messed up because I
changed SO MANY settings! But, everything is working fine. I had to do the
http://192.168.0.1 thing - do all routers have to do that? (Oh, look,
there's the answer to my speed question, it's there on that page. See
attachment).
   What's your internet speed Andrew? (Just curious)
     No, no statistics page from what I can see, and the 'status' says
exactly the same thing as when you hover over the icon. Found the answer
above, but it would still be nice if I could access the workings of this
thing and get some answers.
    ~Steve~
Download 'router_speed.jpg' (16 KB)
Preview of image 'router_speed.jpg'
Date: 18 Sep 2008 13:58:14
Message: <48d296b6@news.povray.org>
>>> when
Indeed you do. And if you connect anything else to the router, you will
be able to talk to it at a full 100 Mb/sec too. ;-) Just not teh
interwebs...
It varies, but yes, typically "home" routers have a HTTP interface,
although the exact address varies. (You can usually just run "ipconfig"
and look at the default gateway setting, and try that.) At work, a lot
of our printers are configurable in a similar way. HTTP and HTML were
never ever designed for this, but it's widely deployed and ever since
Hotmail everybody has been using it this way more and more...
5.2 Mb/sec. Apparently. (Only downstream, obviously.)
At work it's 5.0 Mb/sec, but that's both ways, and it's guaranteed. (And
Scary fact: Your new router is *probably* just a customised computer
running a customised version of Linux! (My dad's router - Belkin I think
- gives you telnet access to a Bash shell...)
Date: 18 Sep 2008 14:29:05
Message: <48d29df1@news.povray.org>
news:48d296b6@news.povray.org...
>>>> when
>> a 100Mbps connection" then...  Heh... :)
> Indeed you do. And if you connect anything else to the router, you will be
> able to talk to it at a full 100 Mb/sec too. ;-) Just not teh interwebs...
>> because I changed SO MANY settings! But, everything is working fine. I
>> had to do the http://192.168.0.1 thing - do all routers have to do that?
> and look at the default gateway setting, and try that.) At work, a lot of
> our printers are configurable in a similar way. HTTP and HTML were never
> ever designed for this, but it's widely deployed and ever since Hotmail
   Yes, I did the 'ipconfig' thing about 5 times, and on the last one,
everything came together like magic. :)
  Oh, nice! That's what I should be on now but over the last 6 months it's
been steadily dropping on my SpeedTouch 330. Sometimes I could  barely get
2.5Mbps, and other times, I'd get a top slot of 4.5Mbps whereas I should be
getting something like 6 to 7 Mbps (being on an "upto 8Mb's" connection,
that is). No idea what's going on, but it's part of why I changed to a
router, to see if it would be any better. And to be honest, it is, even
though I'm still getting 3.9Mbps.
   What's with the 'packages' in the status dialogue?
      That's what you should be on...  :/
> running a customised version of Linux! (My dad's router - Belkin I think -
       No idea what that means, but...  O_O
           ~Steve~
Date: 18 Sep 2008 14:37:51
Message: <48d29fff$1@news.povray.org>
The figure I quoted is only the reported data link speed. That doesn't
mean my ISP will actually *deliver* data that fast. ;-)
If it in fact says "packets" rather than "packages" that would make more
sense...
It means... It probably has all the standard Linux tools, and if you're
a Linux hacker, you can probably change the configuration in ways that
the pretty HTTP interface doesn't have a button for. ;-)
Date: 18 Sep 2008 15:08:47
Message: <48d2a73f@news.povray.org>
news:48d29fff$1@news.povray.org...
>> it's been steadily dropping on my SpeedTouch 330. Sometimes I could
>> barely get 2.5Mbps, and other times, I'd get a top slot of 4.5Mbps
>> whereas I should be getting something like 6 to 7 Mbps (being on an "upto
>> 8Mb's" connection, that is). No idea what's going on, but it's part of
>> why I changed to a router, to see if it would be any better. And to be
>> honest, it is, even though I'm still getting 3.9Mbps.
> sense...
  Yeah, yeah, sorry, I meant 'packets'. That's just me being hyperactive
when I got a router working, lol. :)
    If you did something programming-wise exclusively for me, and it worked,
you would surely have a large proportion of that figure.
>>> think - gives you telnet access to a Bash shell...)
> It means... It probably has all the standard Linux tools, and if you're a
> Linux hacker, you can probably change the configuration in ways that the
    HAHA! Ok, explained perfectly.
        ~Steve~
Date: 19 Sep 2008 04:36:00
Message: <48d36470$1@news.povray.org>
>> sense...
In that case... it'll be the number of individual messages ("packets")
sent and received over the link.
Heh, what did you have in mind? ;-)
I'm good at explaining. ;-)
Date: 19 Sep 2008 07:42:40
Message: <op.uhp71s16c3xi7v@news.povray.org>
And lo on Thu, 18 Sep 2008 17:55:10 +0100, St. <dot### [at] dotcom> did spake,
saying:
> setup,
> that I
As you've discovered most newer routers have an HTML interface accessed
via their IP address (the most popular appears to be 192.168.1.1) the
newer netgear models also have a Device Name stamped on the botton of them
something like NETGEARnnnXXn and you can tap this is as well to gain
access. Deafult login details are normally the pathetic "admin"/"password"
or sometimes "admin"/"admin" there really aren't many combinations to try.
The last one I messed with I don't think I even bothered installing the
disc that came with it.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 19 Sep 2008 07:50:01
Message: <48d391e9$1@news.povray.org>
Or 192.168.0.1. Or 10.0.0.1. Or sometimes it's .254 instead of .1
(The IP address ranges 192.168.x.x, 172.168.x.x and 10.x.x.x are
"resurved for private use" by RFC-1918.)
> "admin"/"password" or sometimes "admin"/"admin" there really aren't many
Reading the manual will usually elicit this quite quickly.
> bothered installing the disc that came with it.
I never bother with any software. If you're connected by Ethernet, you
don't need it.
