POV-Ray : Newsgroups : povray.off-topic : Re: stochastic (monte-carlo) tracing Server Time
16 May 2026 13:08:41 EDT (-0400)
  Re: stochastic (monte-carlo) tracing (Message 13 to 22 of 22)
Subject: Re: stochastic (monte-carlo) tracing
Date: 13 Sep 2008 10:59:21
Message: <48cbd549$1@news.povray.org>
> Nice! Maybe no accurate but the results look good.
> If you want better, see this:
> http://en.wikipedia.org/wiki/Specular_highlight
> (I have not implemented them yet, but some people use Blinn or
> Cook...)
I'm familiar with Phong, but I've not used any of the others.
Curiously these models all seem to describe ways to approximate the
resulting light intensity fall-off for direct ray-tracing to light sources.
None of them seem to describe methods to actually perturb the normal to
directly simulate micro-facets.
Hence my method (whilst not strictly accurate) produces blurred reflections
of the entire scene, and not just specular reflections of the light sources.
I guess that's the advantage of the Monte Carlo method - if you're going to
cast millions of rays you can afford to average out the results numerically,
rather than use a mathematical approximation.
> Anyway, good that I'm not the only one interested in this
> madness :)
Indeed.
I'd also be happy to share my code...
Do you happen to have the geometry of your sample images available?  I'd
like to try to create the same scenes to compare results.
cheers,
Ray
Date: 13 Sep 2008 11:10:01
Message: <web.48cbd75d3ac6d32033b2d9360@news.povray.org>
> > 4. After this you can continue tracing the path normally. But if the
> > ray next hits the same light source, ignore it as otherwise you have
> > calculated it twice.
> Do you still trace some random diffuse rays too?  Otherwise how do you end
> up with diffuse inter-reflection?
Yes, that is the step 4 above. After you evaluate direct lighting component you
can continue normally to random direction. And at the next intersection you do
the same steps again. We definitely want to have global illumination...
> In either event the maths sounds pretty tricky :(
It is not really _that_ tricky. But I needed a pencil and a piece (or 2) of
paper to figure out how to calculate the solid angle thingy. And how to take
the object color into account during this incremental path creation.
> It also appears to mean that you need to treat your light sources
> differently to normal objects.  At the moment my light sources are just
> high-ambient primitives.
Yes, that is correct. The renderer has to have a list of light sources. I also
did first what you do now: light sources are normal objects with emission. And
all images on my page are rendered that way. This "new" method is great because
it improves speed so much. It is worth implementing.
Date: 13 Sep 2008 23:53:13
Message: <48cc8aa9@news.povray.org>
Severi Salminen wrote:
>> * Instead of shooting RGB rays, shoot photons of a particular wave
>> length, selected randomly from the spectrum of the light source at the
>> emission point;
> Yes. This should be implemented at some point to enable accurate dispersion.
I should say that the weakness of this approach is that a surface that
is supposed to be a uniform color will now appear to be a mixture of
pixels that average to that color.
>> * A photon isn't drawn on the screen unless it hits the virtual film.
>> Then you calculate its RGB value, and add that to the pixel at that
>> point in the screen.
> I start the rays from film plane so all rays always hit the film. I'm not sure
> if anyone does it the other way and how it works in practice.
So it traces from 'film' to light source, instead of the other way
around?  I had assumed that it went the other way.  Maybe I could try
writing a renderer that does that.
John
Date: 14 Sep 2008 03:05:01
Message: <web.48ccb7173ac6d32033b2d9360@news.povray.org>
Then you just have to give it a few more days to render and the variance will go
away :-)
Join the crowd! If you start from light sources you have to have some clever way
to get the rays inside camera view angle and then hit the camera. The other way
around you have to make them hit the light sources eventually. Both are
plausible but I have no idea how to prevent from shooting totally unnecessary
rays (ie. those just misses the camera) with the first method.
Date: 14 Sep 2008 11:28:57
Message: <48cd2db9@news.povray.org>
John VanSickle nous illumina en ce 2008-09-13 23:53 -->
>>> emission point;
>> dispersion.
>> not sure
> Regards,
> John
All ray tracers go from the camera to the objects in the scene then to the light
source(s). It's called backward ray tracing. Much more effecient that way.
If That Phone Was Up Your Butt, Maybe You Could Drive A Little Better!
Date: 14 Sep 2008 12:36:17
Message: <48cd3d81$1@news.povray.org>
> the light source(s). It's called backward ray tracing. Much more
> effecient that way.
Actually, many raytracers do a hybrid: they start simultaneously from
camera AND lightsource. At least bidirectional path tracing works like
that. They then connect the paths somewhere in between. That seems very
promising technique.
Date: 14 Sep 2008 14:25:36
Message: <48cd571f@news.povray.org>
>> effecient that way.
I saw one that starts from the light sources (which are high-ambient
objects) bouncing rays around. When the rays hit objects, the "hits" are
saved in a buffer. When the buffer gets full, it does a normal backwards
raytracing (from the camera), collecting the buffered hits near the
intersection point of the bw-raytracing ray. Then the buffer is emptied and
process repeats.
Date: 16 Sep 2008 08:06:08
Message: <48cfa130@news.povray.org>
I would probably set the renderer so that after so many reflections, the
current ray origin is tested to see if it is in the camera view.  If so,
reflect the photon directly at the camera.  Otherwise, cancel the
photon.  It probably won't help much, but it could help a bit.
The real weakness of the whole approach is that for animation work, the
rendering has to be allowed to go on until the graininess is gone, and
there isn't a reliable way to predict that.
John
Date: 17 Sep 2008 05:53:42
Message: <48d0d3a6$1@news.povray.org>
Not sure if the wikipedia article was the best to cover path tracing
needs. But at least pbrt/Luxrender has implemented Blinn stuff. And it
seems good (and definitely works for any light arriving to a point, not
just direct)
Yeah, and with modern multi-core CPUs Monte Carlo is actually possible.
You get good image usually in hours and more the cores we get, the
better. This stuff scales perfectly.
Not at present. I still try to figure out a few problems in my code.
When I know the results are truly unbiased and accurate, I can put a few
simple test scene geometries somewhere and the output.
Date: 19 Sep 2008 03:54:51
Message: <48d35acb@news.povray.org>
I think the new feature is working properly now. Still have to test a
bit more. But the speedup is really astonishing. The newest image (the
grid of colorful blocks) on my site was first rendered in over 24 hours
with the old and slow method.
With the new direct lighting method I can achieve same noise levels in
less than hour, more like 30minutes! Than is more than one order of
magnitude speedup! And the smaller the light source is, the bigger the
difference gets.
W00t.
