POV-Ray : Newsgroups : povray.newusers : How to model "connecting dirt"? Server Time
28 Jun 2024 22:55:36 EDT (-0400)
  How to model "connecting dirt"? (Message 1 to 8 of 8)
Subject: How to model "connecting dirt"?
Date: 30 Sep 2011 01:25:07
Message: <web.4e8550be646b5d89b9815d200@news.povray.org>
Hi. I want to make a certain kind of transition between an object and the
ground.
To see what I mean, look at the picture "Virtual Joy of Life" in the POV-Ray
Hall of Fame. There, at the ground, the transition from the stairstep to the
rest of the ground. That's what I mean. It's a smooth, but crunchy transition
somehow.
At first, I tried to achieve this effect by using the same technique as shown in
the "wallstucco"-example that came with POV-Ray 3.6., but it didn't turn out the
way I wanted it to be.
The problem is, that I need to "connect" a regular face like a cube to a more or
less random surface. Like in the Picture "Virtual Joy of Life".
How can I do this?
Subject: Re: How to model "connecting dirt"?
Date: 30 Sep 2011 03:09:33
Message: <4e856b2d$1@news.povray.org>
> ground.
> somehow.
> How can I do this?
I am not sure how Tom Aust did the *physical* transition (mesh or
isosurface, combining the step stone and the ground) but the texture
probably involves a slope pattern with altitude control.
Building a mesh is best done with an adequate modeller like Wings3D; an
isosurface can be made very realistic-looking but is also fairly complex
to build, and slow(er) to render.
Date: 30 Sep 2011 05:17:43
Message: <4e858937$1@news.povray.org>
>> and the ground.
>> the POV-Ray Hall of Fame. There, at the ground, the transition from
>> the stairstep to the rest of the ground. That's what I mean. It's a
>> smooth, but crunchy transition somehow.
> I am not sure how Tom Aust did the *physical* transition...
   After zooming in on the picture, I guess the whole ground is just one
heightfield, including the step and the interior ground, which were
textured differently by using a gradient y pattern, as you said.
   Anyhow, what Tommy wanted could be achieved in a similar way, by
painting/rendering a heightfield which takes into account the objects
that will be placed over it. Not easy nor simple, but feasible...
Jaime
Date: 30 Sep 2011 07:44:08
Message: <4e85ab88$1@news.povray.org>
Height_field of course! You are right; I forgot that. It explains the
crude, but effective (here), transition between the step and the dirt.
Your technique would work very well I guess, with an intermediate
orthographic overhead render for localising the exact position of the
objects needing dirt accumulation, then painting the dirt height_field
image from that. Interesting idea: something I should try... Thanks Jaime!
Date: 30 Sep 2011 08:02:55
Message: <4e85afef$1@news.povray.org>
...and you suggested exactly this to me maybe a year ago or longer for
the ruined columns image, and I forgot all about it ;-)
Date: 30 Sep 2011 08:37:15
Message: <4e85b7fb$1@news.povray.org>
Me too! :)
Jaime
Date: 1 Oct 2011 04:45:00
Message: <web.4e86d2afa14e3a7eed0bce00@news.povray.org>
> Thomas
Hi, thanks for replying. I just would like to check if I do understand what
you're talking about:
It's about an algorithm that "sweeps" the heightfield into the shape of an
object placed over it, by making its slope staller and staller the more close
the heightfield gets to that object, right?
Date: 1 Oct 2011 10:26:04
Message: <4e8722fc$1@news.povray.org>
No. the technique makes use of a paint program, taking an orthographic
overhead image of the scene as basis, and painting the dirt in shades of
grey on a separate layer, then applying that layer image as a
height_field in the original scene, superposed if necessary over a
pre-existing height_field or other surface.
It is a business that needs close attention but far from impossible and,
using a paint program in conjunction with a height_field generator, it
can even make more interesting features.
