POV-Ray : Newsgroups : povray.newusers : <no subject> Server Time
11 Oct 2025 10:58:36 EDT (-0400)
  <no subject> (Message 1 to 10 of 12)
Subject: <no subject>
Date: 1 Jul 2011 06:15:01
Message: <web.4e0d9d8dc23a6d9f58fe2c40@news.povray.org>
Hello Povray users!
I have a quite annoying problem which I've been trying to figure out for the
last
month...please help. The thing is have exported model with given texture(and
there are lots of elements with the same texture) the texture looks like that:
texture
    uv_mapping
    pigment
     color <0, 0, 0>
     transmit 0.5
     filter 1
    finish
     diffuse 1
     ambient 0
I have declared another texture:
#declare Milky =
texture{
    pigment
     rgbft <1, 1, 1, 0.4, 0.5>
    finish
     diffuse 1.5
     ambient 0
     specular 0.2
     phong 0.4
     roughness 0.1
     reflection 0.05
And now the question is: HOW TO REPLACE THE EXPORTED TEXTURE WITH THE NEW ONE
ON ALL THESE ELEMENTS??
Subject: Re: <no subject>
Date: 1 Jul 2011 06:54:17
Message: <4e0da759@news.povray.org>
On 07/01/2011 07:12 AM, rode wrote:
> Hello Povray users!
> last
> texture
>      uv_mapping
>      pigment
>       color<0, 0, 0>
>       transmit 0.5
>       filter 1
>      finish
>       diffuse 1
>       ambient 0
> #declare Milky =
> texture{
>      pigment
>       rgbft<1, 1, 1, 0.4, 0.5>
>      finish
>       diffuse 1.5
>       ambient 0
>       specular 0.2
>       phong 0.4
>       roughness 0.1
>       reflection 0.05
unless I'm missing something ... sounds like you'll need to edit the
exported model file!
make sure the Milky texture is declared in your main scene file /before/
you have your model include directive (so the model file knows about
Milky) then find all the occurrences of the original texture and replace
them with texture { Milky }
Date: 1 Jul 2011 07:35:01
Message: <web.4e0db01d6f92e856f58fe2c40@news.povray.org>
Povray is recognizing the texture "Milky" becouse I have made it in the Povray
so this is not the problem the thing is how to replace the imported texture (I
can not change it in the software I have exported the model from)  with the
"Milky" that I have created in the Povray on the numerous of elements.
To make it straightforward:
1.How to replace one texture with the other one on the numerous of elements?
Date: 1 Jul 2011 07:47:19
Message: <4e0db3c7$1@news.povray.org>
unless you're handy with regex pattern matching and can write a
script/program to do it for you ... you will have to bite the bullet and
hand edit
Date: 1 Jul 2011 07:55:01
Message: <web.4e0db5506f92e856f58fe2c40@news.povray.org>
that's exactly the point. Till now I have made it line by line (but it took me
hours and hours to replace just a few of the elements textures) also I have
tried FindReplace command but it doesn't work, is there a formula I can use for
such
action?
Date: 1 Jul 2011 09:55:12
Message: <4e0dd1c0@news.povray.org>
> such
> action?
try this ... find the 1st occurrence of the texture you want to replace
in your exported model (include) file. Select the /entire/ texture
statement and copy it into the copy & paste buffer, then paste that into
the find or search for dialog, then in the replace portion of the dialog
type texture {Milky} ... this worked in gedit (picked up invisible
characters like newline \n, \t ...), I'm not using windows version and
it's built-in editor, so I don't know if that will work
Date: 1 Jul 2011 10:03:53
Message: <4e0dd3c9$1@news.povray.org>
> replace in your exported model (include) file. Select the /entire/
> texture statement and copy it into the copy & paste buffer, then
> paste that into the find or search for dialog, then in the replace
> portion of the dialog type texture {Milky} ... this worked in gedit
> (picked up invisible characters like newline \n, \t ...), I'm not
> using windows version and it's built-in editor, so I don't know if
> that will work
   That also works great for me with SciTE... which is available for
Windows too.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 1 Jul 2011 12:34:41
Message: <4e0df721$1@news.povray.org>
> Hello Povray users!
> last
> texture
>      uv_mapping
>      pigment
>       color<0, 0, 0>
>       transmit 0.5
>       filter 1
>      finish
>       diffuse 1
>       ambient 0
> #declare Milky =
> texture{
>      pigment
>      finish
>       diffuse 1.5
>       ambient 0
>       specular 0.2
>       phong 0.4
>       roughness 0.1
>       reflection 0.05
If the texture is present as a texture block everywhere, you need to
replace is with: texture{Milky} everywhere it's used.
Do a search in the exported file for "texture".
Then, you replace the content of the texture with "Milky".
You also can remove all texture and use this:
IF the exported file #declare the objects:
object{ExportedObjectName texture{Milky}}
Or, like this:
union{object{Object001}
	object{Object002}
	texture{Milky}
// Optional transforms
scale<1,1,1>
rotate<0,0,0>
translate<0,0,0>
IF you include the file to place the objects (there are NO #declare in
the file):
union{
	#include "ExportedFile.inc"
	texture{Milky}
scale<1,1,1>
rotate<0,0,0>
translate<0,0,0>
If there is a #declare statement for it, you only need to change it's
#declare to read as: #declare Texture=texture{Milky}
Date: 2 Jul 2011 13:45:00
Message: <web.4e0f58d06f92e856f58fe2c40@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hello Povray users!
> > last
> > texture
> >      uv_mapping
> >      pigment
> >       color<0, 0, 0>
> >       transmit 0.5
> >       filter 1
> >      finish
> >       diffuse 1
> >       ambient 0
> > #declare Milky =
> > texture{
> >      pigment
> >      finish
> >       diffuse 1.5
> >       ambient 0
> >       specular 0.2
> >       phong 0.4
> >       roughness 0.1
> >       reflection 0.05
> Or, like this:
>  object{Object002}
>  texture{Milky}
> scale<1,1,1>
> rotate<0,0,0>
> translate<0,0,0>
> the file):
> union{
>  texture{Milky}
> scale<1,1,1>
> rotate<0,0,0>
> translate<0,0,0>
> Alain
Alain thank you for your reply. Following your tips I have made something like
that (those are the initial lines from my scene):
#declare Milky =
texture{
    pigment
    finish
     diffuse 1.5
     ambient 0
     specular 0.2
     phong 0.4
     roughness 0.1
     reflection 0.05
unfortunately it doesn't work (the elements keep their original texture) Did I
miss something?
Date: 2 Jul 2011 14:15:01
Message: <web.4e0f5f776f92e856f58fe2c40@news.povray.org>
I've digged out through the Pov-ray help and found something like this
#ifdef (User_Thing)
  // This section is parsed if the
  // identifier "User_Thing" was
  // previously declared
  object{User_Thing} // invoke identifier
 #else
  // identifier "User_Thing" was not
  box{<0,0,0>,<1,1,1>} // use a default
  // End of conditional part
is it usefull for the textures replacement?
