POV-Ray : Newsgroups : povray.newusers : Invisible plane to shade objects Server Time
18 Nov 2025 20:04:07 EST (-0500)
  Invisible plane to shade objects (Message 1 to 10 of 11)
Subject: Invisible plane to shade objects
Date: 6 Apr 2011 14:10:00
Message: <web.4d9cabb55d1d79dcdca78c960@news.povray.org>
Hy everybody!
How can I create an invisible plane to shade objects? I need this, because
there's an another object, what have a lot of point lights, and their power are
too strong.
Subject: Re: Invisible plane to shade objects
Date: 6 Apr 2011 14:30:01
Message: <web.4d9cb04181a50bad81c811d20@news.povray.org>
"gregtom6" <gre### [at] freemailhu> wrote:
> Hy everybody!
> too strong.
The following flags can be set in any objects individually or together:
no_image: object is not visible directly, but produces shadows and is visible in
reflections
no_reflection:  object is visible, but not in reflections
no_shadow: object does not produce a shadow
In your case it looks like you would want to add the no_image and no_reflection
flags to your plane.
See 3.4.9.7 & 3.4.9.9 of the docs for more info.
-tgq
Date: 6 Apr 2011 14:32:14
Message: <4d9cb1ae@news.povray.org>
> Hy everybody!
> too strong.
How about reducing the power of your point_lights, or beter, combine
them into one area_light? Good if they are aranged into a squarish,
circular or spherical pattern.
The area_light would have the advantage of been faster, especialy if you
use the adaptive feature.
Add circular to have it act as if it was a disk.
Also add orient to have it acts like a sperical light.
Anyway, you can add no_image to any object. The affected object will
still cast shadows and be visible in reflection. If you also want it to
eacape reflection, then also add no_reflection.
Date: 6 Apr 2011 14:36:40
Message: <4d9cb2b8$1@news.povray.org>
On 04/06/2011 03:06 PM, gregtom6 wrote:
> Hy everybody!
> too strong.
You can vary the see through properties of the plane (or any other
object) with pigment identifiers ... rgbt or rgbf is what you should be
looking for:
http://wiki.povray.org/content/Documentation:Reference_Section_2.1#Specifying_Colors
But maybe you don't need to shade with an object. You could vary the
strength of the light source ...
http://wiki.povray.org/content/Documentation:Tutorial_Section_2.1#The_Light_Source
maybe fade distance might be helpful, but have a look at the entire
tutorial just to get a feel for what's going on.
Date: 6 Apr 2011 15:25:00
Message: <web.4d9cbd9c81a50baddca78c960@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hy everybody!
> > too strong.
> Alain
The lightning object is a spaceship, and it has got a lot of point lights. If I
reduce the fade distance and/or fade power, that won't light the ship.
The lights are enough strong on the ship, but too strong, if an object is too
close to the ship.
Date: 6 Apr 2011 17:30:40
Message: <4d9cdb80@news.povray.org>
> close to the ship.
In case you want to render a realistic image, you can't have it both
ways. If you think it looks odd, then something may be wrong about other
setup. If there are lights directly on the ship they would not provide
much light to the hull, as the angle of incidence will be very small.
So if you think the ship should be bright, the hull itself needs to
be glowing (ambient/emissive) or you need an external light source
such as a star.
Date: 7 Apr 2011 08:35:01
Message: <web.4d9daee181a50bad692e56d30@news.povray.org>
> > close to the ship.
> such as a star.
No. I want only small light sources on the hull, to light small areas.
My ship has got a lot of small point lights, and it seems to be there're a lot
of lamps on the ship.
Date: 7 Apr 2011 13:45:01
Message: <web.4d9df7c481a50bad3ef509f10@news.povray.org>
> > > close to the ship.
> > such as a star.
Ok, I finally solved this problem. When I gave 0 value to fade distance, it went
wrong, but when I changed that to 1, it solved the problem:)
Date: 7 Apr 2011 14:20:01
Message: <web.4d9dff5e81a50bad1218473e0@news.povray.org>
I
> > > > close to the ship.
> > > such as a star.
Yes, as per recent discussions, fade distance should be small, but not that
small!
-tgq
Date: 7 Apr 2011 17:05:47
Message: <4d9e272b$1@news.povray.org>
>>> close to the ship.
>> such as a star.
In that case, you can use spot_light that point at the hull's areas that
you want illuminated.
Just remenber that the radius is in degrees, not in units around the
point_at location. (I've seen scenes with that mistake)
You can still use fade_distance and fade_power for those.
As a bonus, you may get some speed improvements as you will save on the
shadow ray tests.
