POV-Ray : Newsgroups : povray.newusers : First render - no luck... Server Time
19 Nov 2025 00:53:40 EST (-0500)
  First render - no luck... (Message 1 to 10 of 11)
Subject: First render - no luck...
Date: 22 Nov 2009 04:15:00
Message: <web.4b08ffbbc7b4de328c48d20a0@news.povray.org>
Hi!
I am trying to render a Rhino file saved in .pov format.  The Povray process
does not complete, it finds parsing errors in the file.  I have used the
standard output from rhino, and materials.inc from the Rhino folder.
Any pointers?
Thank you!
Subject: Re: First render - no luck...
Date: 22 Nov 2009 05:05:01
Message: <web.4b090c653d2954ce8c48d20a0@news.povray.org>
"cyberpunk" <cou### [at] hotmailcom> wrote:
> Hi!
> Any pointers?
> Thank you!
// This is where the process stops (the second line), and says 'Parse Error:
Cannot assign uninitialized identifier':
#include "C:/Program Files/Rhinoceros 4.0/Plug-ins/POV/materials.inc"
#declare Object1Material = Plane (19)
One material in the materials.inc file looks like this:
#declare plastic = material {
  pigment { rgbf rh_color }
  finish {
    ambient 1
    diffuse 1
  phong rh_phong
  phong_size rh_phong_size
Should I add a section in the materials file like this?:
#declare Object1Material = material {
Date: 22 Nov 2009 05:07:16
Message: <4b090d54$1@news.povray.org>
> Any pointers?
Sounds like version incompatibility to me; what version of POV-Ray are
you using?
With POV-Ray 3.7.beta, one possible problem would be buggy exporters
writing illegal code which used to be accepted by 3.6, but not so by
3.7. (A known instance are extra decimal points in numbers, which were
silently ignored by POV-Ray 3.6, but are rejected by 3.7.)
Date: 22 Nov 2009 05:35:01
Message: <web.4b0912af3d2954ce8c48d20a0@news.povray.org>
> > Any pointers?
> you using?
Thank you for your response!
I am using POV-Ray 3.6.2.msvc9.win32.  Here's what i (am trying to) do:
*  Save the model from Rhino (4.0 eval - will get full licence)
*  Save as .pov geometry
*  Open the .pov file, POV-Ray opens
*  Then I 'Run' the renderer - and the parsing jams on the described line...
Date: 22 Nov 2009 05:55:01
Message: <web.4b0917dc3d2954ce8c48d20a0@news.povray.org>
One step closer!
I removed all material definitions from the model in Rhino, then re-saved as
..pov.
Now POV-Ray goes through the whole file - no parsing errors.  I think if I
carefully re-define materials and properties for the model from within Rhino
now, I should get moving.
The first render I did now became very flat (of course!), but at least I
produced a rendered image, that was fun!
Thank you for the feedback :-)
Date: 22 Nov 2009 06:31:37
Message: <4b092119$1@news.povray.org>
Just in case you should be running into the same problem again:
No, definitely not. In the way "Plane" is used, it must be defined as a
macro. It's pretty hard to guess what should go in there, so the
Rhino-to-POV exporter should better take care of that.
Unless it's documented somewhere in Rhino (or the exporter).
Date: 22 Nov 2009 06:32:30
Message: <4b09214e@news.povray.org>
cyberpunk wrote:
> One step closer!
> ...pov.
If Rhino can export meshes in the OBJ format you could use PoseRay
(http://mysite.verizon.net/sfg0000/) to convert it to a PovRay INC file
as an alternative method of rendering it.
Best Regards,
Date: 22 Nov 2009 12:26:44
Message: <4b097454@news.povray.org>
> One step closer!
> ..pov.
If that works, it means that the Rhino exporter is making gross errors.
In this case, it's obvious to an experienced user, that at least one of
the following is appening:
rh_color  is not defined.
rh_phong  is not defined.
rh_phong_size  is not defined.
A workaround would be to create your own definitions for those variables.
#declare rh_color = <0.1, 0.8, 0.27, 0>;
// Slightly bluish green
// Change the colour definition as you want.
// The last value controlls transparency.
// Zero = no transparency, 1 = fully transparent.
#declare rh_phong = 0.5;
// medium phong highlight
// smaler value for more subtil highlight, larger for srtonger effect
#declare rh_phong_size = 200;
// relatively tight highlight
// small value = broad highlight.
Manualy add those #declare at the very top of the generated .pov file
and start the render.
Personnaly, I'd edit that material and set ambient to zero. ambient 1
difuse 1 is highly unrealistic.
ambient 1 makes the object fully illuminated without any light source.
If you use radiosity, then that object will act as an illumination
source. You probably don't want that.
diffuse 1 makes the object react 100% to the illumination from light source.
This often leads to oversaturation where surfaces with a pigment of
rgb<1, 0.5,0.5>, rgb<0.5,0.75,0.8> and rgb<1,1,1> can all looks identical.
Do a search and replace to change ambient 1 to ambient 0 or some small
value no larger than 0.1
If you set ambient to a non-zero value, you should also reduce the
diffuse value somewhat.
Date: 22 Nov 2009 13:10:00
Message: <web.4b097e2f3d2954ce8c48d20a0@news.povray.org>
Hi guys!
Thank you all for the assistance & feedback!  Turns out the non-functioning
material definitions were Brazil-materials previously used in my model.  At the
time of export the Brazil module was de-activated.
I am trying to find the best combination of tools for modelling + rendering
(photo-realistic / mechanical engineering), and in this process I have been
testing a time-limited trial version of the Brazil renderer for Rhino, which was
expired before I tried PR today.
Now I have started wondering:
Do all you experts generate your geometry in one system [without 'materials'],
and then syntactically edit the .pov file from within the POV-Ray application?
OR
Do you use some other tricks to smooth the integration between your geometry
application and POV-Ray?
Date: 22 Nov 2009 15:16:15
Message: <4b099c0f$1@news.povray.org>
> Hi guys!
> OR
Usualy, I create my images in pure SDL. No modeler used, most of the time.
I've tried Wings3D and some others.
You can also use Poseray. It's a scene editor and format converter. It
can convert scenes created in many modelers and convert them for use in
POV-Ray. It can do some manipulations, like subdividing a mesh to make
it smoother.
