POV-Ray : Newsgroups : povray.newusers : mipmapping Server Time
10 Feb 2026 19:17:22 EST (-0500)
  mipmapping (Message 12 to 21 of 31)
Subject: Re: mipmapping
Date: 11 May 2005 15:21:10
Message: <42825b26$1@news.povray.org>
> Trilinear between what? The four corners of the pixel? You'll lose some
> information then (just imagine: 4 black pixels on the texture with white
in
> between! *gosh* :-)
I think he means using mipmaps, and then taking the two nearest mipmaps for
the scale level of the current sample, bilinearly interpolating to get the
color for each of them at the sample position, and then linearly
interpolating between the two results to get the final value.
In my experience, this approach generates a little too much blurring, and
when I program with OpenGL, I often wish that I could have nice
anti-aliasing instead.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 11 May 2005 15:27:08
Message: <42825c8c$1@news.povray.org>
for
As I just recently learned in a course at my university, the way you
describe it is the standard hardcoded way on older graphics cards. The new
ones (ATI Radeon 9800 and upwards, and I think the NVidias FX and upwards)
come with programmable Vertex and Fragment Shaders, and with fragment
shaders you can script some more elaborate way of interpolation. The guy
showed us some examples of the usual mipmap-fading to avoid jumps between
the different mipmaps, and one which interpolates amongst several
mipmap-levels, depending on the angle of the pixel (and thus the area it
would cover on the image-map). It looked real crisp.
However, we're drifting away from the topic at hand, being of help to tahoma
to get his images look good. :-)
"Tim Nikias v2.0"
Date: 11 May 2005 15:45:01
Message: <d5tnad$9nm$1@chho.imagico.de>
Warp wrote:
>   How so?
>   I don't see why mipmapping, and better yet trilinear interpolation
> of image maps could not be implemented in a raytracer. There are a
> couple of twists, but they can be probably solved.
Good luck in doing so.  Note any such technique will have to modify the
very basic concept of raytracing with additions like ray differentials
and you will have a hard time making this work efficiently in arbitrary
cases (i.e. non-standard camera types, reflections/refactions etc.).  In
the end i doubt this will lead to better results in shorter time (but i
will be happy to be proven wrong).
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 11 May 2005 17:50:29
Message: <42827e25@news.povray.org>
> information then (just imagine: 4 black pixels on the texture with white in
> between! *gosh* :-)
  Perhaps you should look up what trilinear interpolation is.
Date: 11 May 2005 17:55:09
Message: <42827f3d@news.povray.org>
  For surfaces seen directly by the camera it's enough to know the length
of the ray and the scale of the image map.
  For surfaces seen indirectly an estimation will usually be more than
enough.
  Pathological cases exist, of course, but I'm pretty sure many people would
be very happy even with an estimated version.
Date: 11 May 2005 17:57:54
Message: <42827fe2@news.povray.org>
tahoma <nomail@nomail> wrote:
> Trilinear filtering is what i asked for. Because of the depedency of
> mipmapping i just mentioned this one. If povray would support mipmapping
> then trilinear filtering would be naturally there i think.
  It's not all that obvious. Just adding support for mipmapping doesn't
automatically add trilinear filtering. That has to be added explicitly
as well. And it's not like trilinear filtering is the only option.
There could be anisotropic filtering instead, for example.
Date: 11 May 2005 18:29:10
Message: <42828736$1@news.povray.org>
Nope, I know what it is. :-) I was just wondering what you wanted to
interpolate, but it seems Slime got it right away. To make things worse, my
description was of course only bilinear, so that should have tipped me off
right away what you were getting at. But then again, it has been a long day
and I'm pretty tired. Sorry for the inconvenience caused. :-)
"Tim Nikias v2.0"
Date: 11 May 2005 18:30:01
Message: <d5u0o9$bpd$1@chho.imagico.de>
Assuming:
- normal perspective camera
- No warps etc. being applied to the image map.
To sum it up - in all cases where you probably are faster using hardware
accelerated scanline rendering anyway.
Again - if you implement something along these lines that is surely
interesting from the technical standpoint but the practical use will be
very limited.
Date: 11 May 2005 18:33:48
Message: <opsqmualixx5erxw@leningrad>
On Wed, 11 May 2005 21:26:33 +0200, Tim Nikias
ps
> for
t
>> the
>> and
> new
> upwards)
uy
een
it
That way i was hoping to go with povray as well. To program the texture
(or
pigment) stage to support different blending mode for example. But it is
another topic :) It's possible, but not like my mind is winded. So i hav
e
to rethink some stuff.
> tahoma
I hope to get them look good when trying different antialiasing settings
More i cannot gain from this thread (mipmapping is not supported and
maybe useless). Adjusting materials is on the one hand an artist task an
d
on the other hand one of the translater from OpenGL materials to povray
one's.
But what i also get is, offline rendering (raytracing) does not really
differ from realtime rendering that much. The concepts are almost the sa
me,
the community is a little different :)
Thanks for you help
Date: 11 May 2005 18:52:41
Message: <opsqmu53xxx5erxw@leningrad>
> In  the end i doubt this will lead to better results in shorter time
> (but i will be happy to be proven wrong).
That's why mipmapping or trilinear filtering is common practice in realt
ime
graphics. Beside the fact that is decreases cache misses for gpu's to fe
tch
texels it gives better results without FSAA.
Nevertheless you can do fancy things with different textures. If you don
't
use
just downsampled textures you can achieve some nice texturing effect
depended
on the fragment distance. I don't know if there exists a pattern in povr
ay
for
this.
