POV-Ray : Newsgroups : povray.general : POVRAY memory usage Server Time
14 Jan 2026 11:43:04 EST (-0500)
  POVRAY memory usage (Message 1 to 10 of 22)
Subject: POVRAY memory usage
Date: 13 Oct 2017 20:15:00
Message: <web.59e1563095148a195e1bc5320@news.povray.org>
  I've seen posts from folks that claim to use large amounts of memory.
How could I get ahold of either scenes or scenes + options that result in large
memory usage from POVRAY (ideally > 8GB)?
I'm doing some memory performance testing.
Thanks!
Max
Subject: Re: POVRAY memory usage
Date: 14 Oct 2017 08:05:00
Message: <web.59e1fcd8da2c0257acfa72180@news.povray.org>
"Max" <max### [at] intelcom> wrote:
> Hi,
I always just plot a LOT of spheres.
Take a 1024 x 768 scene and just plot a different sphere for each pixel.
Then you can add z-layers if you need more spheres.
Then you can add textures, finishes, etc.
I'm sure filling up arrays will eat up lots of memory as well.
New macros < 256 kb are cached in memory as well - so you could just define a
bunch of macros.
Date: 14 Oct 2017 09:05:00
Message: <web.59e20a34da2c025789df8d30@news.povray.org>
Perhaps run a #while loop or #for loop with a HI-rez image_map in it. (I don't
think such a scene actually needs a full *render*-- the memory requirement will
vastly increase during the parsing stage, IIRC.) Something like...
#declare C=1;
#while(C < 10,000) // or whatever
pigment{image_map{... HI-res image...}}
#declare C = C+1;
That should repeatedly load the image_map into memory.
(BTW: To *prevent* the unnecessary memory usage, #declare the pigment *before*
it's used in the loop.)
Date: 14 Oct 2017 18:28:48
Message: <59e28fa0$1@news.povray.org>
Le 17-10-13 à 20:11, Max a écrit :
> Hi,
> Thanks!
> Max
In a few nested loops, define some objects, each one individualy textured :
#declare R=seed(0);
#declare I=9e9;
#while (I>0)
  #declare J=9e9;
  #while (J>0)
	sphere{
	 <rand(R),rand(R),rand(R)>*10000 0.1+rand(R)
	 pigment{rgb<rand(R),rand(R),rand(R)>}
	 finish{diffuse 0.3+rand(R)/2}
   #delcare J=J-1;
  #declare I=I-1;
81000000000000000000 spheres, each with a different texture. Hope that
you have enough RAM for that...
Date: 15 Oct 2017 12:18:10
Message: <59e38a42@news.povray.org>
Am 14.10.2017 um 14:02 schrieb Bald Eagle:
> bunch of macros.
Hm... did I remember that number wrong?
Nope, source code agrees with my memory: It's 64 kiB.
Date: 16 Oct 2017 19:20:00
Message: <web.59e53e11da2c02574259753d0@news.povray.org>
Thank you! Very helpful. I went with allocating many spheres.
Next question: how likely is someone to do such a thing in a real rendering? Are
there real renderings that need large numbers of objects allocated?
I'm looking for the largest memory using 'real' rendering. Any ideas?
Would povray be able to do more if memory were along the lines of 32GB or larger
for the average user?
Thanks,
Max
Date: 16 Oct 2017 20:45:44
Message: <59e552b8$1@news.povray.org>
Am 17.10.2017 um 01:17 schrieb Max:
The more main memory you have, the more POV-Ray can indeed do in terms of...
- Geometric detail in the scene (number of primitives in case of CSG, or
number of triangles in case of meshes).
- Texture detail in the scene, in case of image-based textures.
- Illumination detail (number of light sources, number of radiosity
samples, photon density).
Date: 17 Oct 2017 02:54:25
Message: <59e5a921$1@news.povray.org>
Well, Vermeer's Cat by Ive (see p.b.i.) would be a good example of large
numbers of objects (cat's hairs).
Date: 17 Oct 2017 08:05:01
Message: <web.59e5f197da2c0257c437ac910@news.povray.org>
Very.
"Taking advantage of POV-Ray's clever memory management for copies of meshes,
this one has more than 12000 oak trees. "
http://hof.povray.org/River.html
 Are
http://hof.povray.org/fallfury.html
This doodle alone consisted of 655,000 untextured spheres.
http://news.povray.org/povray.binaries.animations/message/%3Cweb.592d5e424e850994c437ac910%40news.povray.org%3E/#%3Cweb
That's just the objects.
Now consider that I might want to store the locations in an array, do
calculations with stored variable values, add textures, etc.
Other people routinely work with meshes in excess of a million vertices.
YES.
Date: 17 Oct 2017 15:30:01
Message: <web.59e65999da2c025789df8d30@news.povray.org>
> or larger for the average user?
> YES.
A naive question: Does POV-Ray actually choke on a larger-than-RAM-memory scene?
I thought disc-swapping would take over (slower of course, but with no outright
crash.)
