POV-Ray : Newsgroups : povray.general : Isofunctions and meshes Server Time
24 May 2024 13:31:43 EDT (-0400)
  Isofunctions and meshes (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Isofunctions and meshes
Date: 2 Dec 2016 12:30:00
Message: <web.5841af1fb9cec73d6ebf07f0@news.povray.org>
"John Greenwood" <joh### [at] john-greenwoodcouk> wrote:
> >> can my function, which is a single closed surface, be turned into mesh?
> > Perhaps you can find something useful in this thread:
> > Subject: Isosurface Approximation macros rewrite
> > From: Tor Olav Kristensen
> > Date: 2008 February 22nd
> > Message: <47be20ab@news.povray.org>
> > Newsgroup: povray.binaries.scene-files
http://news.povray.org/povray.binaries.scene-files/thread/%3C47cc76fd@news.povray.org%3E/
> > Tor Olav
> > http://subcube.com
> I have had a look and am floundering.
> An example would be worth ten thousand words.
See the code below.
> Could some kind person point me at an actual example of converting a simple
> function, such as:
>     function(x,y,z){sqrt(pow(x,2)+pow(y,2)+pow(z,2))-L)/r }
> into a mesh object?
That function seemsto be missing a start parenthesis somewhere.
The code below uses a similar function.
Noe that this code also creates a file named triangles.inc that contains all the
triangles.
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 ======= 8
#include "functions.inc"
// Other functions to experiment with
//#declare Fn = function { f_torus(x, y, z, 1, 0.4) }
//#declare Fn = function { y - sin(2*x*z)*cos(x*z) }
//#declare Fn = function { cos(2*pi*x) + cos(2*pi*y) + cos(2*pi*z) }
// A sphere with radius 1.8
// x^2 + y^2 + z^2 = 1.8^2
// (x^2 + y^2 + z^2)^(1/2) = 1.8
// (x^2 + y^2 + z^2)^(1/2) - 1.8 = 0.0
// The elaborate way
//#declare Fn = function(x, y, z) { sqrt(pow(x,2) + pow(y,2) + pow(z,2)) - 1.8 }
// A simpler way
#declare Fn = function { f_sphere(x, y, z, 1.8) }
#declare isoThreshold = 0.0;
// Set to yes to produce the approximation
// or to no for the actual isosurface
#declare approximateIso = yes;
// Set to yes to produce a smooth_triangle approximation
// or to no ro produce a flat triangle approximation
#declare isoSmooth = no;
// Controls the size of the cube that is beeing sampled
#declare R = 2.0;
#declare isoMin = -<1, 1, 1>*R;
#declare isoMax = +<1, 1, 1>*R;
// The resolution of the sampling in the x, y and z directions
#declare Resolution = 6;
#if (approximateIso)
  #declare Depth = 1; // Set to 0 for no recursion
  #declare isoSegs = <1, 1, 1>*Resolution;
  #declare isoFileOption = 1;
  #declare isoFile = "triangles.inc";
  #declare isoName = "Surface";
  #include "isosurface_kl_jf_tok.inc"
  object {
    Surface
    pigment { color rgb <1, 1, 1>*0.9 }
    finish {
      phong 0.5
      phong_size 10
#else
  isosurface {
    function { Fn(x, y, z) }
    max_gradient 8.0
    contained_by { box { isoMin, isoMax } }
    open
    finish {
      phong 0.5
      phong_size 10
#end // if
sky_sphere {
    function { abs(y) }
    color_map {
      [ 0.0 color rgb <0.0, 0.0, 0.6> ]
      [ 1.0 color rgb <1.0, 1.0, 1.0> ]
  location <1, 2, -4>*2*R
  look_at <0, 0, 0>
  angle 32
light_source {
  <1, 2, -1>*100
  color rgb <1, 1, 1>
  shadowless
light_source {
  <-1, -2, -1>*100
  color rgb <1, 1, 1>*0.5
  shadowless
Tor Olav
http://subcube.com
Date: 3 Dec 2016 05:00:01
Message: <web.584296c5b9cec73de15d43a80@news.povray.org>
> See the code below.
> > function, such as:
> > into a mesh object?
> triangles.
> // A simpler way
> #declare R = 2.0;
>   object {
>     Surface
>     finish {
>       phong 0.5
>       phong_size 10
> #else
>   isosurface {
>     max_gradient 8.0
>     open
>     finish {
>       phong 0.5
>       phong_size 10
> #end // if
> sky_sphere {
>   pigment {
>     function { abs(y) }
>     color_map {
> camera {
>   look_at <0, 0, 0>
>   angle 32
> light_source {
>   <1, 2, -1>*100
>   color rgb <1, 1, 1>
>   shadowless
> light_source {
>   <-1, -2, -1>*100
>   shadowless
> Tor Olav
> http://subcube.com
Thanks I will have a go.
Date: 3 Dec 2016 07:30:00
Message: <web.5842b5f4b9cec73de15d43a80@news.povray.org>
snip
> > Tor Olav
> > http://subcube.com
I have had a go and it works!
This is a great help for composing rounded objects. By reducing the resolution
to 5(and ignoring the artifacts) and putting isoSmooth = no, the render time is
4 seconds, AND I can have muliple views, almost essential for creating 3D
objects.
A single isosurface rendering took 88 seconds
I understand that with a mesh object I can change the colour locally. This will
be much better for introducing lip colours and rosy cheeks in this example.
Thanks
John
(I have posted the result in povray.binaries.images/ but am not clear if and how
to make it appear here)
Date: 4 Dec 2016 14:15:00
Message: <web.58446a6bb9cec73d9c5d6c810@news.povray.org>
If by a link...?
http://news.povray.org/web.5842b2dd261ae99ae15d43a80%40news.povray.org
That object to mesh stuff is fascinating, unfortunately I'm terrible with
meshes. And not so good with isosurfaces either. LOL
Looks like you got a fair result. When I tried the in-pov converting from Chris
Young I was getting inner CSG surfaces found until changing from unions to
merge. Something I hadn't expected. No idea what could happen with isosurfaces
based on that.
Wish you luck.
Date: 6 Dec 2016 06:45:00
Message: <web.5846a39db9cec73de15d43a80@news.povray.org>
> based on that.
> Wish you luck.
> Bob
Thanks
I meshed this shape with different settings for resolution. The values are shown
under each example.
isoSmooth was set to no. The failures seem to happen regardless but this gives
an indication that in the first example, with resolution = 5, the failure is due
to the curvature being too tight.
However some of the higher settings of resolution gave what looks like meshing
failure.
Also flat is about 2.5 times faster.
(The meshing time is approximately proportional to the fourth power of the
resolution.)
http://news.povray.org/web.5846a1f84d513ebce15d43a80@news.povray.org
Date: 6 Dec 2016 08:15:00
Message: <web.5846b8b0b9cec73d7b4f57df0@news.povray.org>
> > based on that.
> > Wish you luck.
> > Bob
> Thanks
> under each example.
> failure.
> resolution.)
Have you tried to set the recursion depth to 0 ?
Like this:
#declare Depth = 0;
I'm not able to see if the triangles are missing or if they are just dark. Can
you "see" through the openings where the triangles seem to be missing ?
Tor Olav
http://subcube.com
Date: 6 Dec 2016 14:05:01
Message: <web.58470aa3b9cec73dc6bb200e0@news.povray.org>
> > Tor Olav
> > http://subcube.com
> function, such as:
> into a mesh object?
You can make any POV object into a mesh using trace.
My Rounded Prisms makes a Mesh2 file. Its at
http://leroywhetstone.s5.com/Pages/PovFiles.html#Tools
Although it's not simple, The basic idea is.
You take a mesh(in my case a simple flat surface) put the points into an array
then trace each point and save the new mesh.
Date: 8 Dec 2016 06:35:01
Message: <web.584944a9b9cec73de15d43a80@news.povray.org>
> > under each example.
> > failure.
> > resolution.)
> Like this:
> #declare Depth = 0;
I have just tried this and the results are like a Picasso version of
Frankenstein's monster.
Yes they do seem to be missing and you can see through the holes. I have posted
an example to follow the last one
Date: 8 Dec 2016 07:35:00
Message: <web.58495284b9cec73de15d43a80@news.povray.org>
Interesting... a very limited case mesher, but I think what is needed is a
simple-to-use meshing engine.
Date: 8 Dec 2016 07:50:00
Message: <web.584956dcb9cec73d7b4f57df0@news.povray.org>
> > Like this:
> > #declare Depth = 0;
IIRC the resolution has to be raised considerable if you have no recursion.
Ok. I see.
I think that using recursion may lead to unwanted holes.
Tor Olav
http://subcube.com
