POV-Ray : Newsgroups : povray.general : Flocking Server Time
18 Nov 2025 08:59:45 EST (-0500)
  Flocking (Message 1 to 10 of 25)
Subject: Flocking
Date: 1 Jul 2016 19:15:00
Message: <web.5776f827627fb0fffd6b6fe10@news.povray.org>
Can anybody give ideas for a process which would simulate flocking?
Something like you might use on a diorama.
A.D.B.
Subject: Re: Flocking
Date: 1 Jul 2016 23:12:06
Message: <57773106$1@news.povray.org>
A couple of years ago. Greg M. Johnson posted a couple of animations
using a boids algorithm for making flocking particles. There are a
couple of examples here.
http://www.reocities.com/pterandon/boids.html
I said a couple of years ago. The date on the website is 2000.
Regards
Date: 2 Jul 2016 00:15:01
Message: <web.57773fb7706bc742fd6b6fe10@news.povray.org>
Thanks, I'll take a look.
Sometimes it's hard to believe I've been on this forum for 13 years...
And then I start to believe it, and I get depressed.
A.D.B.
Date: 2 Jul 2016 01:15:01
Message: <web.57774cb8706bc742fd6b6fe10@news.povray.org>
> Regards,
> A.D.B.
On closer inspection, I think this is the wrong kind of Flocking.  I'm looking
for a flocking texture technique.
A.D.B.
Date: 2 Jul 2016 03:09:24
Message: <577768a4$1@news.povray.org>
Not the same but maybe on-the-way-to. Would starting with a damascene
texture help? That can be done with a pigment_pattern. An example of use
(without the image_maps used):
#declare PR_DIFFUSE=p_map17; //a patterned image_map
#declare F1=
finish {
   specular 0.2431373
   roughness 0.00286312
   diffuse 0.6
   reflection{0 } conserve_energy
#declare F2=
finish {
   specular 0
   diffuse 0.6
#declare Damask_Red_1_=
material {
     uv_mapping
     pigment_pattern {p_map18}	//the same image_map but reduced to grey
tones
     texture_map {
       [0 pigment {PR_DIFFUSE}
          finish {F2}
       [1 pigment{PR_DIFFUSE}
          finish {F1}
Date: 2 Jul 2016 05:34:45
Message: <57778ab5@news.povray.org>
Well it was quite early in the morning for me.
Do you remember Rune's Fur texture from about the same time?
Last entry on the page.
Regards
Date: 2 Jul 2016 05:40:22
Message: <57778c06$1@news.povray.org>
On 7/2/2016 8:09 AM, Thomas de Groot wrote:
> damascene texture
Not often you slip up with your English.
Damask. :-P
I wonder if your texture can be combined with Rune's Fur Texture.
Regards
Date: 2 Jul 2016 07:15:29
Message: <5777a251$1@news.povray.org>
>> damascene texture
> Damask. :-P
It is confusing. Damask is certainly right, but damascene is also used
in this context. See: https://en.wikipedia.org/wiki/Damascening and
especially 'Damascene in Toledo, Spain'.
I should revisit Rune's texture to be sure, but I suppose it should be
possible one way or another. I was thinking in the line of a contrast of
strong and weak (micro-) normals controlled by the pigment_pattern.
Date: 2 Jul 2016 10:11:34
Message: <5777cb96$1@news.povray.org>
>>> damascene texture
>> Damask. :-P
True, true and true. But for cloth... ;)
My first thought on damascene is related to, "on the road to Damascus"
Checking up on my memory. I found the meaning of "damask cheek" as used
by Shakespeare. Rosy cheeked.
I like Rune's macro (attached). It is simple. :)
I took a look at your code but since Bishop3d does not support
pigment_pattern. I tied myself in knots with the syntax in Ver 3·62.
I'll try again when I am not doing six things at the same time. Soon
come. :)
Regards
Download 'furtex.zip' (1 KB)
Date: 5 Jul 2016 02:42:01
Message: <577b56b9$1@news.povray.org>
>>>> damascene texture
>>> Damask. :-P
You are absolutely right of course. 'Damask' should be used for cloth,
damascene for inlay work, but do we know what Anthony intends to do? ;-)
> come. :)
I am busy with something else now but I shall want to have a try too.
