POV-Ray : Newsgroups : povray.general : Soft Shadows? Server Time
25 Feb 2026 11:32:52 EST (-0500)
  Soft Shadows? (Message 1 to 10 of 22)
Subject: Soft Shadows?
Date: 7 Feb 2015 14:50:01
Message: <web.54d66c3668a5702357b385d60@news.povray.org>
I expect this question has been asked before, but i'm wondering whether there is
a specific reason why POV-Ray only supports soft shadows on Area lights,
considering its age and all the other features it has (e.g. radiosity,
volumetrics, photon mapping etc.).
Soft shadows on all lights is quite a standard feature of renderers, and in
theory quite a simple process (although I'm not a programmer), but I have no
idea why this renderer never got it despite its age. Being able to add soft
shadows to directional and point lights would be a tremendous benefit to most
scenes, unless of course there is a workaround for it.
P.S. Same goes for glossy reflections too, while there is a workaround for it,
it is not a particularly 'clean' solution (unless you use MegaPOV instead). AO
also seems impossible without using a workaround with Radiosity, which kind of
kills the point of using AO to 'fake' GI a bit and speed up renders :/
Subject: Re: Soft Shadows?
Date: 7 Feb 2015 15:40:04
Message: <54d67824@news.povray.org>
What is GI, AO ?
About soft shadow... if it's a point of light, it cannot be soft.-
Or you have a definition of point that is no more a point.
Area lights have many optimisation (such as adaptative) which can be
used to have real large array without the cost of as many point lights.
jitter, orient & circular are cool too.
http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_4_1_5
Maybe wanting something like the fading cone of spot light ?
Date: 7 Feb 2015 22:22:13
Message: <54d6d665$1@news.povray.org>
 From the documentation:
   "Any type of light source may be an area light."
In essence, the "area_light" keyword in POV-Ray should probably be
regarded as the name of the option that enables "soft shadows" for any
given light source (although it can do more with "area_illumination").
Also, since you mention radiosity, that will also give you soft
shadows appropriate for the geometry of the objects that are emitting
or scattering light.
Date: 8 Feb 2015 11:05:01
Message: <web.54d7889215c15fdc57b385d60@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> What is GI, AO ?
GI = Indirect Lighting (Like Radiosity), AO is a fast method of faking shadows
in crevices, which helps enormously when faking indirect lighting to speed up
renders.
Also you can have soft shadows with point lights (or in fact any light), many
other render engines do it. You just have to trace a bunch of shadow rays up
towards the light rather than just one, and give them a semi-random offset
between the direction of the light and a user defined maximum (which defines how
soft the shadow is). The more rays you trace the cleaner it will be.
Date: 8 Feb 2015 11:10:00
Message: <web.54d789b615c15fdc57b385d60@news.povray.org>
Ah thanks, that worked well. I was under the impression you could either have a
point, directional, or area light, but it seems some of their features are very
much 'stackable'.
Date: 8 Feb 2015 12:03:13
Message: <54d796d1$1@news.povray.org>
How is that still a point light then?
I'm not really familiar with many render engines, but as far as I
understand, it's the same with every renderer: to get soft shadows, you
either fake it with blurry shadow maps, or you have to use lights of a
size>0, which means it's not a point light anymore.
Date: 8 Feb 2015 13:02:56
Message: <op.xtq2241vufxv4h@xena.home>
>> What is GI, AO ?
> shadows
> speed up
> renders.
> many
> rays up
> offset
> defines how
Do you mean like the shadows in Sky Captain and Toy Story 1?
Such shadows are totally unrealistic because they are blurred the same
amount not matter how far away they are from the object. Just because
other renderers do it, doesn't mean it is correct. These soft shadows are
a scan-line renderer shortcut for actual area light shadows that render
longer. Pov-Ray is not a scan-line renderer, it is a ray-tracer. I suggest
you use an Area Light with jitter, circular and orient, and making it the
size of the globe it represents to give you a more realistic soft shadow.
Take a look at any soft shadow in real life and you will see that where
the shadow meats the object casting it, the shadow is sharp. The further
away the shadow is from the object, the softer the shadow is.
-Nekar Xenos-
Date: 8 Feb 2015 13:04:33
Message: <op.xtq25vcgufxv4h@xena.home>
> have a
> are very
> much 'stackable'.
In that case you can ignore my previous comment :)
-Nekar Xenos-
Date: 8 Feb 2015 15:07:48
Message: <54d7c214$1@news.povray.org>
Am 08.02.2015 um 17:02 schrieb IronLogic:
Well, that's /exactly/ what POV-Ray area lights do in the "circular
orient jitter" mode - except that POV-Ray uses stratified sampling in
that mode rather than purely random offsets, and that it also still
supports adaptive supersampling in that mode.
Date: 8 Feb 2015 15:57:53
Message: <54d7cdd1@news.povray.org>
>> What is GI, AO ?
> renders.
Does AO mean ambient oclusion? If that's the case, it's only a tiny
subset of radiosity. It lack the ability to take into account the colour
and reflectivity of the ocluding object: it may be black or white and
cause exactly the same darkening.
NO, it's absolutely impossible to have any kind of soft shadow from a
point light. Other renderers may /fake/ soft shadows, like you can
/fake/ focal blur, in a non-realistic way.
The mechanism that you mention is faking it. It's probably no faster,
nor beter, than using an area_light in POV-Ray.
Just use a light source, add area_light, the dimentions of the area, and
the number of sub-lights. Greatly improve the performances by using
adaptive. Great controll, good performance.
The larger the number of sub-lights, the cleaner the result. Make the
dimention larger to get broader penumbrae.
