POV-Ray : Newsgroups : povray.general : Blender Vs PovRay Server Time
29 Sep 2024 03:13:52 EDT (-0400)
  Blender Vs PovRay (Message 1 to 10 of 44)
Subject: Blender Vs PovRay
Date: 21 Oct 2008 06:30:01
Message: <web.48fdae14f034d1aa519bbb570@news.povray.org>
Hi all!!
Just a comment about my trip from Pov to Blender. I'm still trying to learn
Blenders dark path and I have discovered something astonishing. I haven't found
a texture generator as Pov texture generator. When you jump to programs like
Blender (or 3dS) you are supposed to PAINT almost all the textures you use if
you want them to look right through UV maps.
It is incredible that they didnt put any effort in the developement of a good
texture generator. It is not obvious, for instance, to do a texture map. To put
a standard texture inside another pattern. So, as I have said, you have to use
UV maps or images to texture your Blender models.
It is true that this feature (UV mapping) is easy to use and very well inserted.
But I miss Pov procedurals. I miss them so much that I still use Pov to paint my
textures!!! and then I introduce them into blender as images.
So finally (thanks God) I'm not going to loose my connection with Pov.
Thanks!!!
www.enriquesahagun.es
Subject: Re: Blender Vs PovRay
Date: 21 Oct 2008 08:15:01
Message: <web.48fdc717320575a498a5bb110@news.povray.org>
"kike" <dry### [at] hotmailcom> wrote:
> Hi all!!
> Thanks!!!
This is not quite right.  Perhaps you are just still very green and missing
functionality in the UI.  Procedurals in Blender are about as powerful than in
Povray, except you enter color/texture lists with very practical dragging
controls.
F5 to access the materials panels for an object.  You'll see a Texture/Map
Input/Map To grouping near the end of the panel.  With Texture you can stack
texture maps with several layers.  With Map Input, you can scale and do various
transforms for any of the selected layers.  With Map To, you can adjust
individual features of each layer, like pigment (color), normal, specular,
alpha, warps and the kind of mixing that goes into it with the subsequent
layers (subtract, add, multiply, light etc).
F6 access the "texture" panels.  In it, you may define each layer per se:  the
pattern type, turbulence type, noise type and color list.
The F5 panels still feature a very handy Shaders/Mirror Trans/SSS grouping that
allow you to further define the appearence, including choices of shading models
(lambert, fresnel etc) and subsurface scattering effects.
Blender is a very complete and complex package, that's for sure.
Date: 21 Oct 2008 12:05:25
Message: <48fdfdc5$1@news.povray.org>
kike wrote:
> Hi all!!
> Thanks!!!
You might want check out Wings3D: www.wings3d.com  It comes with a
fairly good POVRAY exporter built in...
Date: 21 Oct 2008 14:46:50
Message: <48fe239a@news.povray.org>
> controls.
"Out of the box," Blender's procedural texturing system is nowhere near
as powerful as POV-Ray's. I suppose if one were to write his own
shaders, and use scripting along with it, Blender's texturing system may
start to approach the level of POV's in terms of flexibility.
Sure, in Blender you have access to certain textural elements, and the
node-based system is nice, but I can imagine that certain things I can
easily do in POV would prove to be very hard if not impossible to do in
Blender.
At any rate, I find that each program is useful for different things. In
POV you can script up anything you desire with little fuss (great for
science), render thousands of instances of a complex object, have
radiosity in your scene, etc. In Blender you can render hair, SSS, make
games (the new GLSL stuff is really cool), etc. It's nice to have more
than one tool at your disposal before embarking on a project. Now, if I
could just find inspiration....
Sam
Date: 21 Oct 2008 15:01:19
Message: <48fe26ff@news.povray.org>
stbenge escreveu:
>>> learn
>>> haven't found
>> missing
>> than in
>> controls.
Really?  As far as I played with it, it seems to share the same level of
functionality, and quite a few more features.
> Blender.
Is this a challenge? ;)
If one can show me some difficult pov-only texture, I may try to
reproduce it with Blender's procedurals alone once I get home... :)
On a side note, Blender also has an internal radiosity engine, along
with a raytracer.
> Now, if I
Oh, come on!  Even uninspired, you're an inspiration to all of us! :D
Date: 21 Oct 2008 17:20:00
Message: <web.48fe46ed320575a45e6ec0f00@news.povray.org>
Jeff Houck <jho### [at] northrimnet> wrote:
> kike wrote:
> > Hi all!!
> > Thanks!!!
Modeling Program: you know how you use it, only if you wrote it; at least for
some time. And so much time to develop, even if you wrote it, takes some effort
to remember what you did.
Blender is the best importer I've seen, almost everything but pov mesh. Then
export to obj and open with PoseRay, what a Gem PoseRay is!
As for modeling with POV, I know I have more possibilities to explore yet feel
modeling programs to be unnecessary at this point, CSG. For modeling human form
we all should have been able to afford hover cars by now, let alone 3D scanners,
but noooooo$, greed has to make it this way.
Date: 22 Oct 2008 05:25:01
Message: <web.48fef052320575a4be7bfb550@news.povray.org>
Ok, Ok, OK, wait a minute:
I'm not saying Blender is not good. Actually I'm learning to use blender because
I wanted to do things I can not do with Pov. In particular those things
connected with mesh and animations, in which Blender is quite powerful. In fact
I'm very grateful to Blender, I'm still astonished with the million things you
can do with it.
And in particular, textures are very powerful in Blender. But in my opinion, not
as powerful as in PovRay. It is true that you can do very interesting things in
the textures section. BUT THERE IS AN OBVIOUS THING you can do in Pov which is
not obvious in Blender. To set textures inside textures. For instance to set a
crackle texture inside a bozo texture in such a way that there is crackle only
in the bozo spots.
When you want to design complex textures in Pov, you have lots of possibilities.
I can make a list of the things I miss:
- Bricks, hexagons
- texture maps (texture INSIDE textures, not textures OVER textures)
- the way you control the noise in your textures (turbulence, wrap, lambda,
omega, etc
When you want complex textures in Blender, it is better to paint it (or to get a
photograph, OR TO USE POV!!! JAJAJA) Obviously, I would be able to make a
similar list about the things that are better in Blender, but that is another
story.
Date: 23 Oct 2008 15:24:24
Message: <4900cf68@news.povray.org>
nemesis wrote:
> stbenge escreveu:
>> near as powerful as POV-Ray's. I suppose if one were to write his own
>> may start to approach the level of POV's in terms of flexibility.
More features like ambient occlusion, angle of incidence shaders and
other mapping features... yes. But as kike mentioned, you can't place
textures inside of textures. POV-Ray also has other pattern modifiers
which make life much easier....
>> in Blender.
If you want it to be :)
Ok, you asked for it! :) Here's a little pattern I whipped up just now
in POV:
// Code
// render with +w500 +h500
global_settings{assumed_gamma 2.2}
#default{finish{ambient 1}}
camera{
  orthographic
  right x*2 up y*2
  location -z*100 look_at 0
#declare native_motif=
pigment{
  gradient y triangle_wave
  #declare V=0;
  #while(V<1)
   translate y*.75
   rotate z*45.2
   //rotate -z*45.1
   scale .98
   warp{repeat x*5 flip x}
   #declare V=V+1/100;
  scale .1
plane{z,-1
  pigment{
   native_motif
   color_map{[0 rgb 0][.5 rgb<.5,.3,.1>][1 rgb 1]}
// End Code
>> In POV you can script up anything you desire with little fuss (great
>> for science), render thousands of instances of a complex object, have
> with a raytracer.
AFAIK, Blender only has ambient occlusion built in to its renderer. You
can color your object based on a sky texture (which actually looks
pretty good), but it's not true radiosity. There is built-in support for
YAFRay, but (with the new releases of Blender) it has become difficult
to use, as you get no preview of the image as it renders. Plus YAFRay
doesn't support all of Blender's rendering options and materials... I
find using YAFRay a pain in the @ss, and usually opt to use POV-Ray if I
need radiosity.
>> Now, if I could just find inspiration....
Sam
Date: 23 Oct 2008 15:49:03
Message: <4900d52f@news.povray.org>
Hash: SHA1
stbenge wrote:
> nemesis wrote:
>> stbenge escreveu:
>> of functionality, and quite a few more features.
>>> the node-based system is nice, but I can imagine that certain things
>>> I can easily do in POV would prove to be very hard if not impossible
>>> to do in Blender.
> in POV:
> // Code
> camera{
>  orthographic
>  right x*2 up y*2
> pigment{
>  #declare V=0;
>  #while(V<1)
>   translate y*.75
>   rotate z*45.2
>   //rotate -z*45.1
>   scale .98
>   #declare V=V+1/100;
>  #end
>  scale .1
> plane{z,-1
>  pigment{
>   native_motif
> // End Code
>> with a raytracer.
	Actually, Blender has "true" radiosity in that it uses the actual
radiosity algorithm: http://en.wikipedia.org/wiki/Radiosity which is
"a finite elements method to solving the rendering equation". Povray
doesn't, what pov calls "radiosity" is actually a Monte Carlo
approach for global illumination ("global illumination" and
radiosity are often confused).
	However, Blender radiosity is pretty difficult to use and get good
results with...
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkkA1UIACgkQd0kWM4JG3k9K2QCfT1RNWbKVRsaoinA0mgfq2Jix
LQYAn0Ij27W5LEmWSFX8jJH2qef3fH/X
=lxwS
-----END PGP SIGNATURE-----
Date: 23 Oct 2008 16:12:19
Message: <4900daa3$1@news.povray.org>
stbenge escreveu:
> nemesis wrote:
>> stbenge escreveu:
>>> to do in Blender.
Shouldn't have asked... :P
> in POV:
> // Code
> camera{
>  orthographic
>  right x*2 up y*2
> pigment{
>  #declare V=0;
>  #while(V<1)
>   translate y*.75
>   rotate z*45.2
>   //rotate -z*45.1
>   scale .98
>   #declare V=V+1/100;
>  #end
>  scale .1
> plane{z,-1
>  pigment{
>   native_motif
> // End Code
Tapestry!  yes, no way of doing that in Blender alone, particularly as
it employs a loop to define further iterations to the warps... I could
try to manually do those transforms, or perhaps learn how to script it
with python... :/
>> with a raytracer.
I'll do a test at home, but I'm pretty sure the tools in the Radio
panels mean true radiosity baking.  They are separate from the occlusion
pass.
> need radiosity.
Blender's internal renderer is becoming better and better.  It features
a mix of scanline and raytracing, plus the ambient occlusion pass and
radiosity.  I think only photon mapping and media are missing.  In the
galleries, many incredible images are rendered internally...
