POV-Ray : Newsgroups : povray.general : Sponza radiosity competition Server Time
27 Dec 2025 13:58:51 EST (-0500)
  Sponza radiosity competition (Message 1 to 9 of 9)
Subject: Sponza radiosity competition
Date: 11 Apr 2006 17:30:01
Message: <web.443c1e4be2cf37df182ea82f0@news.povray.org>
Hi.  First post to this newsgroup.  I'm constantly impressed with povray, so
I wanted to see what I could produce for the sponza radiosity challenge
found here:
http://hdri.cgtechniques.com/~sponza/
I've downloaded the megapov file contained on that site, and made some
changes to it:
1.  Set all ambient values for materials to 0.0
2.  Changed the camera posn to that of a maxwell render which I'm using as a
reference
3.  Altered the posn of the sun light and its intensity
4.  Multiplied the normal bump_size by a factor of 10 - which doesn't appear
to affect the render
5.  Added an .ini file and IndoorLQ radiosity
6.  I've also added "normal on" in rad_def.inc
However, my render still looks flat and imho lacks contrast.  Here is my
result:
http://img208.imageshack.us/img208/1516/test4vv.png
Here is the maxwell render I'm trying to imitate:
http://img203.imageshack.us/img203/9802/sponzapalace1ac.jpg
I think the noise in the maxwell render adds alot to its realism.  I've
tarred up the entire scene with all my changes in it, which can be found
here.  I simply execute "megapov test.ini"
http://jsnake.googlepages.com/sponza_megapov.tar.gz
I have no doubt that povray can produce a render which looks very similar to
the maxwell render, I'm just not quite sure how to go about it :)
Subject: Re: Sponza radiosity competition
Date: 12 Apr 2006 06:34:25
Message: <443cd7b1@news.povray.org>
  After playing with it a bit (with povray 3.6; it doesn't really need
megapov per se) I got something which perhaps resembles a bit more (but
not completely) the original:
http://warp.povusers.org/sponza.jpg
  It took 11 hours 23 minutes to render in my computer, though (3.4GHz P4).
  It's interesting to open your rendering and mine in a browser and switch
between the two to see the differences:
Date: 12 Apr 2006 07:41:52
Message: <443ce780$1@news.povray.org>
After looking at the comparison to Warp's version, I'd recommend adding
a "normal on" statement to the radiosity block. I think this is whats
happening.
~Mike
Things! Billions of them!
Date: 12 Apr 2006 07:58:28
Message: <443ceb64@news.povray.org>
> happening.
  What I did was to deepen the normals ten-fold, reverse them (for some
reason they are reversed and need a negative bump_size), changed the
normal accuracy (I don't know if it has a real effect or not), added a
background color (which the original scene didn't seem to have for some
reason), copied the radiosity settings from rad_def.inc and increased
the 'count' and added 'normal on' and changed the assumed_gamma to get
a higher contrast.
  (Besides that, I reduced the disk space needed by the scene from 18 MB
to 9 MB. I did this simply by converting all the tgas to pngs and by
removing 2 megabytes of no-op content from sponzaM_o.inc.)
Date: 12 Apr 2006 08:02:42
Message: <443cec62$1@news.povray.org>
> a higher contrast.
Wow. I would have never guessed. OOC, what happened with just simply a
normal on statement?
Wow. Why use tga in this day and age?
~Mike
Date: 12 Apr 2006 12:35:03
Message: <e1j9ua$lcc$1@chho.imagico.de>
That looks quite reasonable for a straight away render of a converted
scene.  What has to be said however is that competitions of the type
"supplying a scene designed with application X and having programs
compete how well they render this scene" is not a good estimate for
renderer abilities in general - it just benchmarks the conversion
programs and how close the abilities of the renderer match the
requirements of application X and the scene (in this case indirect
illumination of bump mapped meshes).
For an unbiased comparison the rendering problem would have to be
described in a more generic way - and in this case this would of course
be as much a modeling competition as a rendering one.
http://www.imagico.de/ (Last updated 14 Mar. 2006)
Date: 12 Apr 2006 16:02:53
Message: <443d5ced@news.povray.org>
  If you look at his attempt, the normals are not very visible even under
direct lighting. 'normal on' in the radiosity block wouldn't affect that.
Date: 16 Apr 2006 10:55:00
Message: <web.44425a9811c322a9182ea82f0@news.povray.org>
Warp,
Wow - your image looks fantastic.  Thanks alot for taking the time to get
such a great render.  Again, the power of povray has really come through.
The more I learn about povray, the more confident I am that it can do just
about anything I want it to, provided it is given the proper settings.
Date: 26 Apr 2006 18:15:01
Message: <web.444fefd611c322a9e4dd611c0@news.povray.org>
> What has to be said however is that competitions of the type "supplying a
> scene designed with application X and having programs compete how well they
> render this scene" is not a good estimate for renderer abilities in general -
> it just benchmarks the conversion  programs and how close the abilities of
> the renderer match the requirements of application X and the scene (in this
> case indirect illumination of bump mapped meshes).
Almost all renderers understand same scene description. Polygons, textures,
bumpmaps and so on. Conversion between formats is simple task.
Scene to render is good rendering problem, but it requires accurate light
setup and dynamic range description.
Matti
