POV-Ray : Newsgroups : povray.general : Making Code Conditional on Quality Setting Server Time
23 Nov 2025 17:32:11 EST (-0500)
  Making Code Conditional on Quality Setting (Message 1 to 9 of 9)
Subject: Making Code Conditional on Quality Setting
Date: 29 Sep 2003 11:30:02
Message: <web.3f784f827beb29f5458b4d510@news.povray.org>
I am interested in making some of the code in my scene file conditional on
the quality setting.  To speed up rendering, I intend to replace my
detailed models with simple cube shapes when quality=0.   I have in mind to
do something like this:
#if( Quality == 0 )
     box{ ... }
#else
     object{ DetailedModel }
The word Quality doesn't seem to be recognized as a valid variable.  Does
anyone have any thoughts on how I might accomplish this.
Thanks for your help.
Wayne
Subject: Re: Making Code Conditional on Quality Setting
Date: 29 Sep 2003 11:41:10
Message: <3f785296$1@news.povray.org>
In article <web.3f784f827beb29f5458b4d510@news.povray.org> , "wacampbell"
Unless you have an extremely complex scene, this will not really give you
much of a benefit...
> #if( Quality == 0 )
>      box{ ... }
> #else
> #end
Why should it be recognised?  And how did you get the idea it would be
recognised?
>  Does anyone have any thoughts on how I might accomplish this.
You can declare variables on the command-line.  How to do this is explained
in the manual.
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Sep 2003 12:41:40
Message: <jerry-980DDC.09413429092003@netplex.aussie.org>
In article <web.3f784f827beb29f5458b4d510@news.povray.org>,
As far as I know there is no such variable.
I do this also, although I usually do it as simply on/off. If I'm doing
a complex scene, I'll have a really simple version of each
time-consuming object (such as cones for each mountain peak) as well as
the real version.
Something like this:
#declare FINAL=1;
#declare DRAFT=0;
#declare renderVersion=FINAL;
#declare treeVersion=DRAFT;
#declare mountainVersion=FINAL;
#declare NakedMoleRatVersion=DRAFT;
etc....
Then, in the code:
#if (renderVersion | treeVersion)
//do the real tree
#else
//do the simple tree
#if (renderVersion | mountainVersion)
//do the real mountain
#else
//do the simple mountain
#if (renderVersion | NakedMoleRatVersion)
//do the real naked mole rat
#else
//do the simple rat
So if I set renderVersion to FINAL, then everything gets done for
"real"; if I set it to DRAFT, then only the items whose variable is set
to FINAL get done for real, everything else is draft.
Jerry
"Give a man a fish and you feed him for a day. Teach him to fish, and you've
depleted the lake."--It Isn't Murder If They're Yankees
(http://www.ItIsntMurder.com/)
Date: 29 Sep 2003 13:02:20
Message: <3f78659c$1@news.povray.org>
I beg to differ.  This can be a HUGE benifit.
Not so much with actual shapes, as with textures,
and light sources.  Having a "rough draft" declaration
and using it to determine whether you'd like just a flat
gray wall, or a really complicated brick texture complete
with finish, bump maps, and color maps can cut your
render time by more than half.
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3f785296$1@news.povray.org...
on
> > #if( Quality == 0 )
> >      box{ ... }
> > #else
> > #end
> recognised?
explained
> in the manual.
>     Thorsten
Date: 29 Sep 2003 13:18:41
Message: <3f786971@news.povray.org>
news:3f78659c$1@news.povray.org...
That's what the current quality settings already do...
The original poster asked for the quality settings to be usable for other
scene elements. The fact is that, when working one a moderately complex
scene, it's just more flexible to create one's own switches and dummies to
manage this, including textures, shapes, lights, radiosity, media etc. What
one considers to be part of a rough draft is basically scene dependent. I
may very well fine tune the radiosity using a dummy object with high rad
settings, and fine tune the corresponding complex object with low rad
settings etc.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 29 Sep 2003 14:24:11
Message: <3f7878cb@news.povray.org>
I second this idea.  I currently use an IsTest variable for my more complex
scenes to control draft/final renders.
My method uses true and false as opposed to custom variables.
#declare IsTest = [true/false]
#declare ObjTest = [true/false]
#declare TexTest = [true/false]
#declare UseObj = ( IsTest & ObjTest ? RealObj : StubObj )
#declare UseTex = ( IsTest & TexTest ? RealTex : StubTex )
object { UseObj texture { UseTex } }
I differ from Jerry only in that Draft=true and Final=false.
Date: 29 Sep 2003 14:29:42
Message: <cjameshuff-CB177A.14290829092003@netplex.aussie.org>
Why did you think it would be? The documentation does not say it exists,
nor does any other document I've ever seen. On top of that, it isn't
even a valid built-in keyword. All built-in keywords are lower-case.
There was some discussion a while ago about implementing this, maybe you
ran across that...but it isn't, and never has been available.
As for solving your problem...as I recall, you can specify variables in
the *.ini file and command line. The manual should have the details.
http://tag.povray.org/
Date: 29 Sep 2003 15:10:02
Message: <web.3f7882d371802b05458b4d510@news.povray.org>
Thanks all for your helpful input.   I understand now what I have to do.
Wayne
Date: 29 Sep 2003 18:13:13
Message: <3f78ae79$1@news.povray.org>
In article <3f78659c$1@news.povray.org> , "-s0da-" <ske### [at] msncom>
> and light sources.
But setting Quality=n / +Qn with n<=5 disables them!  That is the whole
point of having the quality option in the first place ;-)
    Thorsten
