POV-Ray : Newsgroups : povray.general : Blobs to mesh conversion? Server Time
25 Dec 2025 03:54:39 EST (-0500)
  Blobs to mesh conversion? (Message 1 to 10 of 20)
Subject: Blobs to mesh conversion?
Date: 10 Dec 2010 20:58:33
Message: <op.vni03ubk0819q0@gdsentropy.nc.rr.com>
Hello,
I think I may perhaps remember various segments of conversation on this
server over the years relating to the ability to convert a pov object to a
mesh. I am not sure what happened with that. I remember one version for
object export, which I care nothing about (save the conversion), and then
other fragments about just converting regular objects to mesh.
My snow/icicle macro uses blobs; it looks great and parses very quickly.
However, the blobs render so very, very, VERY slowly with interior of any
kind, not to mention layered slope based material maps...we are talking
WEEKS for the torus I posted in p.b.i if I use the high quality
textures...only minutes for the one I posted. SSS will be used for the
ultimate 3.7 final release of this...but that is not either here or there
at this juncture.
What good is wonderful geometry if no one can use high quality textures
with it?
For the final release I would very much like to follow something close to
the process below:
1) Parse and create my snow/ice in memory (done)
2) Adaptively convert to mesh object (triangle or quadrangle or whatever
gives the best results at the best time based on geometry)
3) Only render that mesh object, ignoring completely and garbage
collecting if possible the original blob object. (even better, GC'ing
adaptively as each object within an extinction radius is converted to mesh)
I would love to hear any good ideas that have a pov SDL or MathML (I can
convert that to C#, and then to SDL) starting place. I would be even
happier with something which already does this that I could just hack to
suit.
That which follows is a bit of last ditch "brainstorm in the last 2 min"
conjecture, that I really hope I won't need:
Is it possible to create an array of points and Trace() each to the
surface of the object, so triangles or what-not are created and a mesh
object would ultimately result?
Is Trace only viable for objects, and not Types?
Is this something that would require "obtaining" the geometry with an SDL
raytracer that dumps optimized points to a mesh creation/optimization
macro? (I really hope not..REALLY hope not..)
Thanks,
Ian
Using Opera's revolutionary email client: http://www.opera.com/mail/
Subject: Re: Blobs to mesh conversion?
Date: 11 Dec 2010 05:07:45
Message: <4d034d70@news.povray.org>
  Tesselation is a hard problem. Blobs are relatively easy to tesselate
(because they are finite and don't contain hard edges), but the tesselation
algorithm itself is non-trivial. The so-called marching triangles algorithm
is probably the best one, so you might search for that (but, as said, be
aware that it's a complicated algorithm). In your case the algorithm will
have to be implemented in POV-Ray SDL.
  You can use the inside() function to determine if a point is inside or
outside an object (eg. your blob) and the trace() function to find the
surface. These can probably be used in the tesselation algorithm.
Date: 11 Dec 2010 15:07:15
Message: <4d03d9f3$1@news.povray.org>
Am 11.12.2010 02:58, schrieb [GDS|Entropy]:
> SDL raytracer that dumps optimized points to a mesh
> creation/optimization macro? (I really hope not..REALLY hope not..)
Normally yes - sorry.
But then again, POV-Ray has super-normal powers ;-)
One option that springs to my mind is to render an animation series of
"slices" of the object, then use an external tool to trace the outlines
of the shape in order to create a vertex cloud, and ultimately connect
them to a mesh. Maybe do some sophisticated cleanup to reduce the vertex
count where possible. Voila.
Date: 13 Dec 2010 22:17:56
Message: <op.vnoor4ym0819q0@gdsentropy.nc.rr.com>
Ah...man...errrrrgh...
So...a little practical advice would be in order here...
What would be the best course of action "in general"?
1) Create some sort of SDL raytracer which creates a mesh of my object
 from scratch, so people can use realistic ice/snow textures with SSS and
interior
or
2) Forget #1 and just perfect what I have, and put a big fat disclaimer
about using any texture with IOR and filter/transmit, because single
pixels can take a week or more..
or
3) Somehow find exemplars of macros which raytrace/mesh convert/export so
I can Frankenstein something half respectable
So long as you do not use any fancy textures, this thing flies...
Given all I have going on I really don't think #1 is very practical if
starting from absolute scratch.
#2 simply doesn't taste right to me...
Maybe if someone has retained a *good and simple* SDL raytracer sample,
which I know has been posted at some time, *and* if I someone has a copy
of a *good and simple* mesh converter, of which I also know exists and has
been posted, #1 or #3 may become significantly more feasible. #3 looks
best to me..
I know someone made a mesh object pov converter one time...but I don't
know where to start in finding it..if I could just get my hands on those
things previously listed, I know I could hack something together that
would (probably with some advice from the community) get the job done and
be re-usable for other macros in at least some capacity.
Does anyone remember the names of the files/who made, the sdl raytracers,
mesh converters and export utilities I mentioned?
Ian McDonald
Date: 13 Dec 2010 22:28:22
Message: <4d06e456@news.povray.org>
The mesh camera with the max_distance setting could be used to probe an
entire blob in a single render.
  http://wiki.povray.org/content/Documentation:Reference_Section_3#Max_Distance
Of course this doesn't solve the problem of getting the point cloud into
vertexes.
Date: 13 Dec 2010 22:36:37
Message: <4d06e645@news.povray.org>
> with it?
are the textures you're using suitable for baking? (I see you are using
interior, so I'm guessing not).
if it seriously would take weeks to render at any reasonable resolution,
then it might be worthwhile for me to run the render in question under a
profiler to see where the time is being spent. however there's no chance of
that happening this year due to the pending release of 3.7.
-- Chris
Date: 13 Dec 2010 23:05:05
Message: <op.vnoqypja0819q0@gdsentropy.nc.rr.com>
Interesting...quite interesting.
I wonder though; no matter the non-blob approach taken, it seems that when
considering the textures, if one were to have two blobs of differing
texture they would no longer "mix" as they do with blob objects. If this
is the case then a lot of the realism gained through slope textures+blobs
would be lost.
Ian
On Mon, 13 Dec 2010 22:28:21 -0500, Chris Cason
> vertexes.
Date: 13 Dec 2010 23:10:21
Message: <op.vnoq7hhj0819q0@gdsentropy.nc.rr.com>
It has taken 4 days to render 1 pixel that I am now looking at. :(
I do not think the textures would bake well, as they are slope based and
use interior, in addition to the fact they are designed to be blended by
the "blobbing" of differently textured blobs.
However the profiler idea is very interesting.
I have converted a beta of this to pov 3.7 but it blows up during
parse/just before render with an "unspecified error"; this was attempted
using only a pigment of <1,1,1> and nothing more complex. No syntax errors
encountered. The MegaPov #set keyword is the only non-standard feature
used; #local works fine with 3.6 but not 3.7 when I tested, if I recall
correctly.
Ian
On Mon, 13 Dec 2010 22:36:36 -0500, Chris Cason
>> with it?
> of
> -- Chris
Date: 13 Dec 2010 23:18:05
Message: <op.vnorkds20819q0@gdsentropy.nc.rr.com>
Ok; very good then. I know someone has already made something of this sort
here...and I have seen a number of c# versions.
My snow/icicle macro already uses trace and inside, but I was quite
unaware that a point was a valid parameter of the inside method; I thought
that it only accepted objects. I guess pov has overloads too. ;)
I have noticed a pattern...almost everything I want to do with a computer
involves complicated stuff that hasn't been implemented yet lol! ;)
Ian
> tesselation
> algorithm
Date: 14 Dec 2010 07:40:18
Message: <4d0765b2@news.povray.org>
Am 14.12.2010 05:05, schrieb [GDS|Entropy]:
> when considering the textures, if one were to have two blobs of
> differing texture they would no longer "mix" as they do with blob
> objects. If this is the case then a lot of the realism gained through
> slope textures+blobs would be lost.
You could do a render with the different textures replaced by simple
pigments "red 1", "green 1" and "blue 1", respectively. The resulting
data could be used as a basis for a texture_map to apply to the mesh via
UV mapping.
