POV-Ray : Newsgroups : povray.general : Blender Vs PovRay Server Time
21 Nov 2026 22:25:08 EST (-0500)
  Blender Vs PovRay (Message 1 to 44 of 44)
Subject: Blender Vs PovRay
Date: 21 Oct 2008 06:30:01
Message: <web.48fdae14f034d1aa519bbb570@news.povray.org>
Hi all!!
Just a comment about my trip from Pov to Blender. I'm still trying to learn
Blenders dark path and I have discovered something astonishing. I haven't found
a texture generator as Pov texture generator. When you jump to programs like
Blender (or 3dS) you are supposed to PAINT almost all the textures you use if
you want them to look right through UV maps.
It is incredible that they didnt put any effort in the developement of a good
texture generator. It is not obvious, for instance, to do a texture map. To put
a standard texture inside another pattern. So, as I have said, you have to use
UV maps or images to texture your Blender models.
It is true that this feature (UV mapping) is easy to use and very well inserted.
But I miss Pov procedurals. I miss them so much that I still use Pov to paint my
textures!!! and then I introduce them into blender as images.
So finally (thanks God) I'm not going to loose my connection with Pov.
Thanks!!!
www.enriquesahagun.es
Subject: Re: Blender Vs PovRay
Date: 21 Oct 2008 08:15:01
Message: <web.48fdc717320575a498a5bb110@news.povray.org>
"kike" <dry### [at] hotmailcom> wrote:
> Hi all!!
> Thanks!!!
This is not quite right.  Perhaps you are just still very green and missing
functionality in the UI.  Procedurals in Blender are about as powerful than in
Povray, except you enter color/texture lists with very practical dragging
controls.
F5 to access the materials panels for an object.  You'll see a Texture/Map
Input/Map To grouping near the end of the panel.  With Texture you can stack
texture maps with several layers.  With Map Input, you can scale and do various
transforms for any of the selected layers.  With Map To, you can adjust
individual features of each layer, like pigment (color), normal, specular,
alpha, warps and the kind of mixing that goes into it with the subsequent
layers (subtract, add, multiply, light etc).
F6 access the "texture" panels.  In it, you may define each layer per se:  the
pattern type, turbulence type, noise type and color list.
The F5 panels still feature a very handy Shaders/Mirror Trans/SSS grouping that
allow you to further define the appearence, including choices of shading models
(lambert, fresnel etc) and subsurface scattering effects.
Blender is a very complete and complex package, that's for sure.
Date: 21 Oct 2008 12:05:25
Message: <48fdfdc5$1@news.povray.org>
kike wrote:
> Hi all!!
> Thanks!!!
You might want check out Wings3D: www.wings3d.com  It comes with a
fairly good POVRAY exporter built in...
Date: 21 Oct 2008 14:46:50
Message: <48fe239a@news.povray.org>
> controls.
"Out of the box," Blender's procedural texturing system is nowhere near
as powerful as POV-Ray's. I suppose if one were to write his own
shaders, and use scripting along with it, Blender's texturing system may
start to approach the level of POV's in terms of flexibility.
Sure, in Blender you have access to certain textural elements, and the
node-based system is nice, but I can imagine that certain things I can
easily do in POV would prove to be very hard if not impossible to do in
Blender.
At any rate, I find that each program is useful for different things. In
POV you can script up anything you desire with little fuss (great for
science), render thousands of instances of a complex object, have
radiosity in your scene, etc. In Blender you can render hair, SSS, make
games (the new GLSL stuff is really cool), etc. It's nice to have more
than one tool at your disposal before embarking on a project. Now, if I
could just find inspiration....
Sam
Date: 21 Oct 2008 15:01:19
Message: <48fe26ff@news.povray.org>
stbenge escreveu:
>>> learn
>>> haven't found
>> missing
>> than in
>> controls.
Really?  As far as I played with it, it seems to share the same level of
functionality, and quite a few more features.
> Blender.
Is this a challenge? ;)
If one can show me some difficult pov-only texture, I may try to
reproduce it with Blender's procedurals alone once I get home... :)
On a side note, Blender also has an internal radiosity engine, along
with a raytracer.
> Now, if I
Oh, come on!  Even uninspired, you're an inspiration to all of us! :D
Date: 21 Oct 2008 17:20:00
Message: <web.48fe46ed320575a45e6ec0f00@news.povray.org>
Jeff Houck <jho### [at] northrimnet> wrote:
> kike wrote:
> > Hi all!!
> > Thanks!!!
Modeling Program: you know how you use it, only if you wrote it; at least for
some time. And so much time to develop, even if you wrote it, takes some effort
to remember what you did.
Blender is the best importer I've seen, almost everything but pov mesh. Then
export to obj and open with PoseRay, what a Gem PoseRay is!
As for modeling with POV, I know I have more possibilities to explore yet feel
modeling programs to be unnecessary at this point, CSG. For modeling human form
we all should have been able to afford hover cars by now, let alone 3D scanners,
but noooooo$, greed has to make it this way.
Date: 22 Oct 2008 05:25:01
Message: <web.48fef052320575a4be7bfb550@news.povray.org>
Ok, Ok, OK, wait a minute:
I'm not saying Blender is not good. Actually I'm learning to use blender because
I wanted to do things I can not do with Pov. In particular those things
connected with mesh and animations, in which Blender is quite powerful. In fact
I'm very grateful to Blender, I'm still astonished with the million things you
can do with it.
And in particular, textures are very powerful in Blender. But in my opinion, not
as powerful as in PovRay. It is true that you can do very interesting things in
the textures section. BUT THERE IS AN OBVIOUS THING you can do in Pov which is
not obvious in Blender. To set textures inside textures. For instance to set a
crackle texture inside a bozo texture in such a way that there is crackle only
in the bozo spots.
When you want to design complex textures in Pov, you have lots of possibilities.
I can make a list of the things I miss:
- Bricks, hexagons
- texture maps (texture INSIDE textures, not textures OVER textures)
- the way you control the noise in your textures (turbulence, wrap, lambda,
omega, etc
When you want complex textures in Blender, it is better to paint it (or to get a
photograph, OR TO USE POV!!! JAJAJA) Obviously, I would be able to make a
similar list about the things that are better in Blender, but that is another
story.
Date: 23 Oct 2008 15:24:24
Message: <4900cf68@news.povray.org>
nemesis wrote:
> stbenge escreveu:
>> near as powerful as POV-Ray's. I suppose if one were to write his own
>> may start to approach the level of POV's in terms of flexibility.
More features like ambient occlusion, angle of incidence shaders and
other mapping features... yes. But as kike mentioned, you can't place
textures inside of textures. POV-Ray also has other pattern modifiers
which make life much easier....
>> in Blender.
If you want it to be :)
Ok, you asked for it! :) Here's a little pattern I whipped up just now
in POV:
// Code
// render with +w500 +h500
global_settings{assumed_gamma 2.2}
#default{finish{ambient 1}}
camera{
  orthographic
  right x*2 up y*2
  location -z*100 look_at 0
#declare native_motif=
pigment{
  gradient y triangle_wave
  #declare V=0;
  #while(V<1)
   translate y*.75
   rotate z*45.2
   //rotate -z*45.1
   scale .98
   warp{repeat x*5 flip x}
   #declare V=V+1/100;
  scale .1
plane{z,-1
  pigment{
   native_motif
   color_map{[0 rgb 0][.5 rgb<.5,.3,.1>][1 rgb 1]}
// End Code
>> In POV you can script up anything you desire with little fuss (great
>> for science), render thousands of instances of a complex object, have
> with a raytracer.
AFAIK, Blender only has ambient occlusion built in to its renderer. You
can color your object based on a sky texture (which actually looks
pretty good), but it's not true radiosity. There is built-in support for
YAFRay, but (with the new releases of Blender) it has become difficult
to use, as you get no preview of the image as it renders. Plus YAFRay
doesn't support all of Blender's rendering options and materials... I
find using YAFRay a pain in the @ss, and usually opt to use POV-Ray if I
need radiosity.
>> Now, if I could just find inspiration....
Sam
Date: 23 Oct 2008 15:49:03
Message: <4900d52f@news.povray.org>
Hash: SHA1
stbenge wrote:
> nemesis wrote:
>> stbenge escreveu:
>> of functionality, and quite a few more features.
>>> the node-based system is nice, but I can imagine that certain things
>>> I can easily do in POV would prove to be very hard if not impossible
>>> to do in Blender.
> in POV:
> // Code
> camera{
>  orthographic
>  right x*2 up y*2
> pigment{
>  #declare V=0;
>  #while(V<1)
>   translate y*.75
>   rotate z*45.2
>   //rotate -z*45.1
>   scale .98
>   #declare V=V+1/100;
>  #end
>  scale .1
> plane{z,-1
>  pigment{
>   native_motif
> // End Code
>> with a raytracer.
	Actually, Blender has "true" radiosity in that it uses the actual
radiosity algorithm: http://en.wikipedia.org/wiki/Radiosity which is
"a finite elements method to solving the rendering equation". Povray
doesn't, what pov calls "radiosity" is actually a Monte Carlo
approach for global illumination ("global illumination" and
radiosity are often confused).
	However, Blender radiosity is pretty difficult to use and get good
results with...
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkkA1UIACgkQd0kWM4JG3k9K2QCfT1RNWbKVRsaoinA0mgfq2Jix
LQYAn0Ij27W5LEmWSFX8jJH2qef3fH/X
=lxwS
-----END PGP SIGNATURE-----
Date: 23 Oct 2008 16:12:19
Message: <4900daa3$1@news.povray.org>
stbenge escreveu:
> nemesis wrote:
>> stbenge escreveu:
>>> to do in Blender.
Shouldn't have asked... :P
> in POV:
> // Code
> camera{
>  orthographic
>  right x*2 up y*2
> pigment{
>  #declare V=0;
>  #while(V<1)
>   translate y*.75
>   rotate z*45.2
>   //rotate -z*45.1
>   scale .98
>   #declare V=V+1/100;
>  #end
>  scale .1
> plane{z,-1
>  pigment{
>   native_motif
> // End Code
Tapestry!  yes, no way of doing that in Blender alone, particularly as
it employs a loop to define further iterations to the warps... I could
try to manually do those transforms, or perhaps learn how to script it
with python... :/
>> with a raytracer.
I'll do a test at home, but I'm pretty sure the tools in the Radio
panels mean true radiosity baking.  They are separate from the occlusion
pass.
> need radiosity.
Blender's internal renderer is becoming better and better.  It features
a mix of scanline and raytracing, plus the ambient occlusion pass and
radiosity.  I think only photon mapping and media are missing.  In the
galleries, many incredible images are rendered internally...
Date: 23 Oct 2008 17:49:47
Message: <4900f17b@news.povray.org>
nemesis wrote:
> stbenge escreveu:
> with python... :/
Are you backing down from the challenge? :)
I find myself using loops for patterns all the time, as it's one of the
ways to add a great deal of complexity to them.
>>> with a raytracer.
>> You can color your object based on a sky texture (which actually looks
> pass.
You and Jerome are absolutely right; I forgot all about Blender's
ability to bake radiosity into objects. I don't ever use this feature,
as it difficult to use and not very dynamic. You have to re-bake all the
objects if you want to change something. It's a nice feature to have
though, since you can precompute the radiosity for games and animations.
>> There is built-in support for YAFRay, but (with the new releases of
>> Blender) it has become difficult to use, as you get no preview of the
>> image as it renders. Plus YAFRay doesn't support all of Blender's
>> rendering options and materials... I find using YAFRay a pain in the
>> @ss, and usually opt to use POV-Ray if I need radiosity.
I agree with you on all points. Blender is coming along quite nicely, to
be sure. It looks like a kind of media will be available soon (it
already is for certain test builds), and radiosity will also be
available in the form of "light cuts," a technique which tends to look
rather nice and is almost indistinguishable from true radiosity.
As it stands now, Blender's ambient occlusion+environment-based lighting
works very well. If the sky texture has a bright spot for a "light
source," it will actually cause objects to cast shadows.
Sam
Date: 24 Oct 2008 03:23:26
Message: <490177ee@news.povray.org>
Wow, this is really nice. And each time I change some parameters, I get
something different but also beautiful. Thanks for sharing this.
Thibaut
> in POV:
> // Code
> camera{
>  orthographic
>  right x*2 up y*2
> pigment{
>  #declare V=0;
>  #while(V<1)
>   translate y*.75
>   rotate z*45.2
>   //rotate -z*45.1
>   scale .98
>   #declare V=V+1/100;
>  #end
>  scale .1
> plane{z,-1
>  pigment{
>   native_motif
> // End Code
Date: 24 Oct 2008 05:45:00
Message: <web.490198c9320575a4be7bfb550@news.povray.org>
Hey guys! I didnt wanted to start a war between Pov and Blender!!! It was just a
comment!! jejeje
I'm still learning how to use Blender (I started 6 months ago, compared with my
8 years on Pov is nothing!) But anyway, my conclusion is that both are good but
different. And that changing from Pov to Blender doesnt mean forgetting about
Pov, because in my opinion Pov is still better than Blender in some features.
Not only talking about quality but in terms of WHAT IS EASIER TO USE.
For instance, both programs work with focal blur, but Pov's is easier to
implement. Or motion blur (in MegaPov). I havent found this feature in Blender
(probably it exists).
Date: 24 Oct 2008 09:33:19
Message: <4901ce9f$1@news.povray.org>
stbenge escreveu:
> nemesis wrote:
>> stbenge escreveu:
>> with python... :/
I'm afraid so.  Very, very afraid. :P
that tapestry texture is amazing.  I'm also reminded of Jaime's
ceramic tiles macro that do it with function patterns:
http://www.ignorancia.org/en/index.php?page=Ceramic_Tiles
Yes, Blender's procedurals still have a long way until being as
featureful as Pov's... if the GUI doesn't get in the way, that is... :P
Date: 24 Oct 2008 10:34:55
Message: <4901dd0f$1@news.povray.org>
"stbenge" <THI### [at] hotmailcom> schreef in bericht
news:4900cf68@news.povray.org...
> Ok, you asked for it! :) Here's a little pattern I whipped up just now in
> POV:
My goodness! *whipped up* you say?  I would have needed at couple of days at
least...
I am deeply impressed. I could very well use these kind of patterns, and I
shall... with due credit of course.
Date: 24 Oct 2008 10:45:33
Message: <4901df8d$1@news.povray.org>
Thomas de Groot escreveu:
>> POV:
Yeah, true hackers are humble. :D
Date: 24 Oct 2008 15:10:36
Message: <49021dac@news.povray.org>
>> POV:
> least...
> Thomas
Oh no, don't get me wrong here. I whipped up a *variation* of a pattern
I've been playing with for quite some time. Since the technique is well
known to me, it didn't take long to arrive at the version I posted. I
should have used better words :/
I got the idea from somebody who posted to p.b.i. a long time ago. The
person made a sort of "rose window" pattern using loops and repeat
warps. I tried it out, started tweaking some settings, and arrived at
something fractaline. I don't think I ever posted my results... until
yesterday.
Sam
Date: 24 Oct 2008 15:11:52
Message: <49021df8$1@news.povray.org>
> Thibaut
You're welcome. I have had the idea for quite some time, but to post it
must have slipped my mind :/
Sam
Date: 24 Oct 2008 15:28:08
Message: <490221c8@news.povray.org>
nemesis wrote:
> stbenge escreveu:
>> nemesis wrote:
>>> stbenge escreveu:
>>> as it employs a loop to define further iterations to the warps... I
>>> could try to manually do those transforms, or perhaps learn how to
>>> script it with python... :/
Well, I won't hold you to it ;) We can't go on comparing corundums to
tourmalines :)
I remember doing something like this a long, long time ago. I think
Jaime took it further than I did. Looks neat :)
Everything hinges on that darned GUI! The developers have to find ways
to incorporate new features into the program without making the GUI a
difficult monstrosity to contend with. More procedurals would be nice,
and wouldn't add unnecessary clutter.
Sam
Date: 24 Oct 2008 15:47:45
Message: <49022661@news.povray.org>
> comment!! jejeje
There is no war! There's only mutual distrust ;)
This makes sense. I can't see anyone abandoning POV-Ray altogether.
POV-Ray's usefulness goes beyond any other program in existence, IMO. It
will always be one of my favorite tools; it won't be leaving my tool bag
any time soon :)
Here's how to get motion blur in Blender. You need to go to
Scene(F10)>Render>and press the MBLUR button. Motion blur won't work
unless you have animated elements in your scene (obviously). You may
need to go ahead a few frames to see the effects fully. OSA samples
equals motion blur samples. It's all fairly straightforward once you
know where to look.
Sam
Date: 24 Oct 2008 20:07:00
Message: <49026324@news.povray.org>
Seconded. The one thing that code is missing is an explicit copyright and
license :D
Date: 24 Oct 2008 21:45:00
Message: <web.49027933320575a485de7b680@news.povray.org>
stbenge <THI### [at] hotmailcom> wrote:
>    #declare V=V+1/100;
Do you often use fractional loop counters?
Lovely pattern.
Date: 24 Oct 2008 22:08:12
Message: <49027f8c@news.povray.org>
>>    #declare V=V+1/100;
Yes, that's my automatic way of laying out a loop. I do this because
variables which go from 0 to 1 are easier to implement in color_maps and
sin/cos statements. It wasn't needed for this particular loop, but since
POV-Ray treats all variables as floats, I can't see how it could harm
things. I should have made it different so the code was easier to read,
but like I said, I'm on automatic when writing code sometimes ;)
> Lovely pattern.
Thanks!
Sam
Date: 24 Oct 2008 22:23:52
Message: <49028337@news.povray.org>
The problem with doing #declare V=V+1/100; is that it might not reach 1.0000
exactly at the end of the loop (because of floating point inaccuracies), so
it might run one time too many.
Since integers are accurate (unless they're really big), I personally do
this:
#declare I=0;
#declare V=0;
#while (I<100)
  //useful code
  #declare I=I+1;
  #declare V=I/100;
Date: 24 Oct 2008 22:29:52
Message: <490284a0@news.povray.org>
> 1.0000 exactly at the end of the loop (because of floating point
> inaccuracies), so it might run one time too many.
Or even if it runs runs the correct number of times, it may have slightly
off values. And errors would *accumulate*.
Tested in Python:
>>> x = 0;
>>> for i in range(0,100):
...     x += 1.0/100;
>>> print x;
1.0000000000000007
Date: 25 Oct 2008 00:13:41
Message: <49029cf5@news.povray.org>
> Tested in Python:
>>>> x = 0;
> ...     x += 1.0/100;
>>>> print x;
> 1.0000000000000007
I see what you mean. I've never encountered any unwanted effects from
using fractional number-dependent loops, but it's a good thing to keep
in mind. Errors at the 16th decimal place are acceptable for most of the
things I do, but there will probably come a time when your input saves
me from beating my head against a hard surface :)
Sam
Date: 25 Oct 2008 10:14:36
Message: <490329cc$1@news.povray.org>
Right. If you MUST use floats, more robust is this sort of thing:
#local xmin = ....;
#local xmax = ....;
#local dx = .....;
#local x = xmin;
#while (x < xmax + dx / 2)
   #local x = x + dx;
Date: 25 Oct 2008 14:41:52
Message: <49036870$1@news.povray.org>
stbenge  wrote in message <49027f8c@news.povray.org>:
>								 but since
> things.
You mean, instead of using an integer counter? There is a big difference:
with most architectures, floats can represent reasonably-small integers in
an exact manner. On the other hand, 1/100 is not an exact float; 1/64 and
1/128 would have been, but not 1/100.
So the point that PoV internally uses floats is not valid: there are more
robust ways to use floats than others, and using an integer counter for
looks is one.
Date: 25 Oct 2008 14:46:55
Message: <4903699f@news.povray.org>
It's mainly relevant if you loop thousands of times. With 100 iterations
it's not a big problem :)
Date: 26 Oct 2008 08:45:52
Message: <49046680$1@news.povray.org>
Nicolas Alvarez  wrote in message <4903699f@news.povray.org>:
Quite the contrary, with this code, there may be problems even for a very
small number of iterations.
For example, consider the following code:
#local n = 10;
#local t = 0;
#while(t < 1)
  #local t = t + 1/n;
and the same with n = 11. It happens that the float value for 1/10 is
slightly smaller than the exact value 1/10, while the float value for 1/11
is slightly greater than the exact value for 1/11. The result is that both
loops make 11 iterations.
This issue can be fixed by using a float-friendly bound, as suggested
earlier by someone: t < 1 + dt / 2 or t < 1 - dt / 2, depending on whether
the loop is supposed to be inclusive or not.
Date: 26 Oct 2008 13:52:55
Message: <4904ae77@news.povray.org>
> #local n = 10;
> #local t = 0;
> #while(t < 1)
>   #local t = t + 1/n;
> #end
Well, t's a a reserved identifier, but otherwise....
If you change it count from 0 to "< 10" in increments of 1 (ie in integers), it's
fine.
Dan
Date: 26 Oct 2008 14:02:09
Message: <4904b0a1@news.povray.org>
> integers), it's fine.
Yes, that's exactly the point. Use integers instead of floats.
Date: 28 Oct 2008 20:50:00
Message: <web.4907b2b2320575a46670cae90@news.povray.org>
> pigment{
>   #declare V=0;
>   #while(V<1)
>    translate y*.75
>    rotate z*45.2
>    //rotate -z*45.1
>    scale .98
>    #declare V=V+1/100;
>   #end
>   scale .1
I just want to say this is so much fun to play around with. Thanks for sharing
it.
Janet
Date: 29 Oct 2008 08:10:00
Message: <web.490851d4320575a4208d05c80@news.povray.org>
> it.
My mother would have given her eye teeth for a pattern generator like this. I
can see her using it for Fair Isle jumpers.
Date: 29 Oct 2008 12:48:53
Message: <490893f5@news.povray.org>
Now that you mention it, I think I've found the basis of a macro for my
walk-thru castle's tapestries. :-)
Date: 29 Oct 2008 14:37:35
Message: <4908ad6f$1@news.povray.org>
> it.
> Janet
Your welcome :)
Sam
Date: 29 Oct 2008 14:40:51
Message: <4908ae33$1@news.povray.org>
>> it.
> Stephen
Eye teeth? Are those little stones you put into your teeth? If so, I
thought Kim Stanley Robinson came up with that...
Oh, I just remembered why I didn't post this pattern before. Your
message reminded me that I once had plans to generate textile patterns
with the hopes of selling them, using this generator. Oh well, maybe one
of you can do it ;)
Sam
Date: 29 Oct 2008 15:30:00
Message: <web.4908b850320575a412258d5e0@news.povray.org>
LOL, Your eye teeth are your canine teeth and those gem stones are an African
thing to show your wealth.
> of you can do it ;)
The best laid schemes o’ mice and men gang aft a gley
Date: 30 Oct 2008 06:25:01
Message: <web.49098ab4320575a4519bbb570@news.povray.org>
> // Code
> camera{
>   orthographic
>   right x*2 up y*2
> pigment{
>   #declare V=0;
>   #while(V<1)
>    translate y*.75
>    rotate z*45.2
>    //rotate -z*45.1
>    scale .98
>    #declare V=V+1/100;
>   #end
>   scale .1
> plane{z,-1
>   pigment{
>    native_motif
This was exactly what I was talking about... well, I didnt expected something as
beautiful as this!!! it is incredible!!! Congratulations.
Well, at this point I have to say that I have discovered two promissing ways in
Blender to improve its not-so-good textures generator. One is to use nodes
(still dont know exactly what it is). The other way is that you can program
things in phyton, still dont know if you can program textures...
I will probably try with nodes, but I wont with Phyton. I have too many
programation languages in my head. Dont want another one!!!!
We'll always have PovRay!
Date: 15 Nov 2008 20:57:09
Message: <491f7df5$1@news.povray.org>
OTOH, seems like Blender is getting node-based textures, so
textures-inside-textures is now possible. :)
http://www.blendernation.com/2008/11/13/new-feature-in-development-texture-nodes/
http://www.blendernation.com/wp-content/uploads/2008/11/manual-part-iv-texture-node-example.png
I don't have a problem with Blender's GUI, but then, it's the only 3D
editor I know.  What I like about it the most is all the keyboard
shortcuts, so that I hardly use the mouse to do anything other then mesh
editing.
Date: 15 Nov 2008 21:50:01
Message: <web.491f89f4320575a47d55e4a40@news.povray.org>
I think the node-based approach is very powerful, and can benefit more than just
shading. Some apps, such as Houdini or (recently, with ICE) XSI seem to take
full advantage of nodes in modelling, animation, compositing, the lot.
Tom
Date: 15 Nov 2008 22:10:00
Message: <web.491f8ec5320575a43c5d60fd0@news.povray.org>
Yes.  Blender already had node-based materials and scene compositing.  Users are
demanding action nodes for animation as well.
Date: 16 Nov 2008 15:51:22
Message: <492087ca@news.povray.org>
I saw this yesterday, and was reminded of this thread :) It looks really
cool, and should make Blender's texture system much more flexible. That
Mandelbrot node setup was just insane, did you see that?
> editing.
I like Blender's GUI, but seriously, I would not want to program one
like it. The developers have done a good job so far, keeping things
under the proper tabs, menus and window types. I agree with you about
the keyboard shortcuts; they make life much easier. Sounds like you're
farther into that than I am :)
Sam
Date: 16 Nov 2008 19:50:00
Message: <web.4920befd320575a4b1532a2b0@news.povray.org>
Yes!  Should've linked to it instead!! O_o
I think it's one of the things that make it so light and portable.  I mean, the
whole thing being OpenGL.
It reminds me very much of the text editor vi.  All keys are command shortcuts.
I decided to seriously learn it these past weeks.  I mean, learning about all
modelling mesh techiniques and Blender as well.  Right now, I'm not yet
concerned with full scenes, just sketches to learn to model, radiosity, AO and
all the different render passes and composition.  I'll soon post a complete
scene with my progress.  Visual mesh modelling is truly amazing. :)
