POV-Ray : Newsgroups : povray.general : Lighting problem at extreme distances Server Time
31 Jul 2024 00:34:46 EDT (-0400)
  Lighting problem at extreme distances (Message 1 to 10 of 18)
Subject: Lighting problem at extreme distances
Date: 24 Mar 2008 13:25:00
Message: <47e7f1fc$1@news.povray.org>
High!
Once more with my long-cherished Solar System project... originally I
equalled 1 POV unit = 1 km - which pretty soon turned out to be
unfeasible, as the Sun is several times farther even from Mercury than
PoV-Ray's epsilon value would allow it to be rendered correctly, let
alone the other celestial bodies in the Solar System.
So I introduced a scale value, based on the aphelion (furthest point of
orbit from the Sun) of trans-Kuiper Belt object Sedna, and adjusted it
dynamically to the distance between camera and the Sun (or any other body):
#declare AU=149597870.691; // 1 Astronomical Unit in kilometres
#declare scconst=14596; // scaling constant, found by manual approximation
#declare objdist=975.56*AU; // Sedna's aphelion
#declare camdist=10000;     // Camera distance from Sedna
#declare sc=scconst*(objdist/(975.56*AU)); // scale factor adjusted to
camera-sun (or camera-other body) distance
light_source // Sun
   0/sc
   color rgb 1
   looks_like
     sphere
       0/sc, 695000/sc
       texture
        pigment { color rgb 1 }
        finish { ambient 1 diffuse 0 }
sphere // Sedna dummy for lighting test
   <0, 0, -objdist>/sc, 1800/sc
   texture
     pigment
       color rgb <0.5, 0.35, 0.2>
     finish { ambient 0 diffuse 1 brilliance 0.4 }
camera
   location <-camdist, 0, -objdist>/sc
   look_at <0, 0, -objdist>/sc
   angle 40
Works fine... as long as I adjust the scale value according to Sedna's
distance to the Sun rather than to the camera-Sedna distance. If I try
the latter (i. e. insert 10000 instead of 975.56*AU, which is about 14
billions), the illuminated half of the Sedna dummy sphere appears
terribly grainy!
Just keeping 975.56*AU (objdist) as scaling parameter, Sedna (about 1800
kms in diameter) would be a mere 0.12 units large, making structures
several orders of magnitude smaller (such as colonies, spaceships, local
terrain features) impossible to model.
Is there a way to avoid this without changing the position of the light
source? I understand that I'll have to fake the visible disk of the sun
(probably by using a sky_sphere with a multi-layered object pattern
pigment), but to have a realistic illumination geometry, it would be
nice to have the actual origin of the light cosistent with the chosen
scale...
See you on www.khyberspace.de!
Yadgar
Subject: Re: Lighting problem at extreme distances
Date: 24 Mar 2008 13:44:26
Message: <47e7f689@news.povray.org>
> terribly grainy!
  This is most probably just a limitation with 64-bit floating point
values. (Less probably a bug.)
  If that is indeed the reason, then there's little one can do about it.
Date: 24 Mar 2008 23:46:05
Message: <47e8838d@news.povray.org>
...other than heavily modifying POV-Ray to use arbitrary precision
floating-point numbers, like with the MPFR library. Would be slow as
hell though :)
Date: 24 Mar 2008 23:48:51
Message: <47e88433$1@news.povray.org>
> hell though :)
Hmm... Looks like there are some C++ wrappers around MPFR that would
make it quite simpler. And when I say simpler, I mean that in many
cases, replacing 'double' with 'mpfr_class' would be all (who said
operator overloading was bad?)
Date: 25 Mar 2008 05:03:55
Message: <47e8ce0b@news.povray.org>
news:47e7f1fc$1@news.povray.org...
> High!
> PoV-Ray's epsilon value would allow it to be rendered correctly, let alone
> body):
I hope future versions of Pov-Ray will fix this problem. A lot of Povers
love doing astronomical stuff =)
-Nekar Xenos-
Date: 25 Mar 2008 06:22:03
Message: <47e8e05b$1@news.povray.org>
>> High!
>> body):
This is not a POV-Ray problem, it is a hardware limitation as has been
explained countless of times over the decades...
	Thorsten
Date: 25 Mar 2008 06:40:41
Message: <47e8e4b9@news.povray.org>
  There may be wrappers, but are they efficient?
  For such a wrapper to be efficient it would require its own allocator
(afaik. with most unlimited floating point libraries initializing a
floating point value is a heavy operation, so it is recommended to
reuse already-initialized values which are no longer used whenever possible
instead of always initializing new ones) and some type of copy-on-write
mechanism or such (to avoid the huge overhead related to copying/assignment
which would otherwise exist).
Date: 25 Mar 2008 06:41:53
Message: <47e8e501@news.povray.org>
  It will only happen when hardware starts supporting floating point
numbers larger than 64 bits.
  (Well, strictly speaking x87 supports 80-bit floating point numbers,
but that isn't usually of much help.)
Date: 25 Mar 2008 08:11:00
Message: <47e8f9e4@news.povray.org>
I do astronomical renders all the time (well I am an astronomy lecturer!)...
I simply choose a better base unit... Megametres, Gigametres or even AUs
instead of kilometres.
1 AU = 149597870.691km
        = 149597.870691Mm
        = 149.597870691Gm
Even Sedna's orbit is now only 75-975 AU or 11219.7-145857Gm... The only
slight problem there is that Sedna is only 0.0015Gm across!
One of these days I'm going to finish my SolarSystem toolkit include file!
Rarius
"Nekar Xenos" <nek### [at] gmailcom> wrote in message
news:47e8ce0b@news.povray.org...
>> High!
>> body):
> -Nekar Xenos-
Date: 25 Mar 2008 09:23:07
Message: <vjMgKvCenQ6HFwRm@econym.demon.co.uk>
If you're going to be combining nearby objects (such as a spaceship) and
astronomical objects (such as Sedna) in the same scene, you may need to
break the scaling.
You can split the scene into things that are nearby and things that are
far away. Then you can use the fact that an object of diameter 1800km at
a distance of 145900000000km looks almost exactly the same as an object
of diameter 1.8m at a distance of 145900km. So dividing the distances
and sizes of all the far away objects by a million makes no difference
to the render.
Mike Williams
Gentleman of Leisure
