![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am building a cutaway image of a machine, but I am having a problem with
the textures. If I texture an object then intersect that object, the texture
of the object is overwritten on those surfaces where the object is cut...
For example:
difference
cylinder
<-10, 0, 0>
<10, 0, 0>
1
pigment{colour Red}
plane{y, 0}
I get half a red cylinder, but the part where the plane cuts the sphere is
the default texture...
I thought there was something like a "preserve_textures" modifier, but I
can't find anything like that in the help. Can anyone suggest what the
modifier might be?
BTW doing the cutaway to each element of the machine before texturing is not
an option. It is just too complex and I rotate/translate a lot of parts
after texturing!
Rarius
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK.. I found it... I needed to use "cutaway_textures"... Unfortunately I am
still getting exactly the same behaviour! The intersection is still taking
the default texture! Is there a bug in v3.6?
Rarius
"Rarius" <rar### [at] rarius co uk> wrote in message
news:433ee895@news.povray.org...
>texture of the object is overwritten on those surfaces where the object is
>cut...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> cut... For example:
> difference
> cylinder
> <-10, 0, 0>
> <10, 0, 0>
> 1
> pigment{colour Red}
> plane{y, 0}
> modifier might be?
> not an option. It is just too complex and I rotate/translate a lot of
> parts after texturing!
> Rarius
difference
cylinder
<-10, 0, 0>
<10, 0, 0>
1
plane{y, 0}
pigment{colour Red}
This way the plane has the same texture as the cylinder.
Ger
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for the suggestion Ger, but as I said I can't do that.. The machine
is too complex, with too many textures...
Rarius
"Ger" <No.### [at] Thank You> wrote in message news:433eebdb@news.povray.org...
>> with
>> is
>> cut... For example:
>> difference
>> cylinder
>> <-10, 0, 0>
>> <10, 0, 0>
>> 1
>> pigment{colour Red}
>> plane{y, 0}
>> is
>> modifier might be?
>> Rarius
> difference
> cylinder
> <-10, 0, 0>
> <10, 0, 0>
> 1
> plane{y, 0}
> pigment{colour Red}
> Ger
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Rarius
>>>with
>>>is
>>>cut... For example:
>>>difference
>>> cylinder
>>> <-10, 0, 0>
>>> <10, 0, 0>
>>> 1
>>> pigment{colour Red}
>>> plane{y, 0}
>>>is
>>>modifier might be?
>>>Rarius
>>difference
>> cylinder
>> <-10, 0, 0>
>> <10, 0, 0>
>> 1
>> plane{y, 0}
>> pigment{colour Red}
>>Ger
Something like this:
difference
cylinder
<-10, 0, 0>
<10, 0, 0>
1
pigment{colour Red}
plane{y, 0
pigment { color Green }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You aren't understanding what I need to do... Here is a better example...
difference
union
cylinder{-x, y, 1 pigment{Red}}
cylinder{x, -y, 1 pigment{Yellow}}
plane{-y, 0}
cutaway_textures
This works fine, but I have actually found out that my problem is that
instead of a simple plane, I was trying to cut the object with an
intersection as follows:
difference
union
intersection
plane{-y, 0}
plane{-y, 0 rotate<60, 0, 0>}
cutaway_textures
Rarius
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>difference
> union
> intersection
> plane{-y, 0}
> cutaway_textures
It looks like cutaway_textures doesn't work if the cutting object itself
is compound. Is this a bug?
If your cutting object is an intersection, you can work round it like
this:
#declare Thing = union
union {
difference {
object {Thing}
plane{-y, 0}
cutaway_textures
difference {
object {Thing}
cutaway_textures
Or if the cutting object is a union or merge, rather than an
intersection, do this:
union {
difference {
object {Thing}
plane{-y, 0}
cutaway_textures
If the cutting object is a difference, use the same method as for
intersection but add "inverse" to the second object.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> union {
> difference {
> object {Thing}
> plane{-y, 0}
> cutaway_textures
> difference {
> object {Thing}
> cutaway_textures
I don't think that would have the desired effect in some cases. Here's what
I would do:
#declare cutpart = intersection
plane{-y, 0}
union
difference {
cylinder{-x, y, 1}
object {cutpart}
pigment{Red}
difference {
cylinder{x, -y, 1}
object {cutpart}
pigment{Yellow}
- Slime
[ http://www.slimeland.com/ ]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As I said in my original post... My main object is too complex, with too
many textures to difference each part seperately.
As Mike said, it appears that cutout_textures acts very strangely if the
second part of the difference or intersection is a compound object...
sometimes it works sometimes it doesn't!
Rarius
> what
> I would do:
> plane{-y, 0}
> union
> difference {
> cylinder{-x, y, 1}
> object {cutpart}
> pigment{Red}
> difference {
> cylinder{x, -y, 1}
> object {cutpart}
> pigment{Yellow}
> - Slime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
So, does my method work with your complex main object?
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
