POV-Ray : Newsgroups : povray.general : Preserving textures through CSG Server Time
28 Feb 2026 19:20:04 EST (-0500)
  Preserving textures through CSG (Message 1 to 10 of 11)
Subject: Preserving textures through CSG
Date: 1 Oct 2005 15:50:45
Message: <433ee895@news.povray.org>
I am building a cutaway image of a machine, but I am having a problem with
the textures. If I texture an object then intersect that object, the texture
of the object is overwritten on those surfaces where the object is cut...
For example:
difference
    cylinder
        <-10, 0, 0>
        <10, 0, 0>
        1
        pigment{colour Red}
    plane{y, 0}
I get half a red cylinder, but the part where the plane cuts the sphere is
the default texture...
I thought there was something like a "preserve_textures" modifier, but I
can't find anything like that in the help. Can anyone suggest what the
modifier might be?
BTW doing the cutaway to each element of the machine before texturing is not
an option. It is just too complex and I rotate/translate a lot of parts
after texturing!
Rarius
Subject: Re: Preserving textures through CSG
Date: 1 Oct 2005 16:00:03
Message: <433eeac3@news.povray.org>
OK.. I found it... I needed to use "cutaway_textures"... Unfortunately I am
still getting exactly the same behaviour! The intersection is still taking
the default texture! Is there a bug in v3.6?
Rarius
"Rarius" <rar### [at] rariuscouk> wrote in message
news:433ee895@news.povray.org...
>texture of the object is overwritten on those surfaces where the object is
>cut...
Date: 1 Oct 2005 16:04:44
Message: <433eebdb@news.povray.org>
> cut... For example:
> difference
>     cylinder
>         <-10, 0, 0>
>         <10, 0, 0>
>         1
>         pigment{colour Red}
>     plane{y, 0}
> modifier might be?
> not an option. It is just too complex and I rotate/translate a lot of
> parts after texturing!
> Rarius
difference
    cylinder
        <-10, 0, 0>
         <10, 0, 0>
        1
    plane{y, 0}
    pigment{colour Red}
This way the plane has the same texture as the cylinder.
Ger
Date: 1 Oct 2005 16:13:06
Message: <433eedd2@news.povray.org>
Thanks for the suggestion Ger, but as I said I can't do that.. The machine
is too complex, with too many textures...
Rarius
"Ger" <No.### [at] ThankYou> wrote in message news:433eebdb@news.povray.org...
>> with
>> is
>> cut... For example:
>> difference
>>     cylinder
>>         <-10, 0, 0>
>>         <10, 0, 0>
>>         1
>>         pigment{colour Red}
>>     plane{y, 0}
>> is
>> modifier might be?
>> Rarius
> difference
>    cylinder
>        <-10, 0, 0>
>         <10, 0, 0>
>        1
>    plane{y, 0}
>    pigment{colour Red}
> Ger
Date: 1 Oct 2005 18:06:32
Message: <433f0868$1@news.povray.org>
> Rarius
>>>with
>>>is
>>>cut... For example:
>>>difference
>>>    cylinder
>>>        <-10, 0, 0>
>>>        <10, 0, 0>
>>>        1
>>>        pigment{colour Red}
>>>    plane{y, 0}
>>>is
>>>modifier might be?
>>>Rarius
>>difference
>>   cylinder
>>       <-10, 0, 0>
>>        <10, 0, 0>
>>       1
>>   plane{y, 0}
>>   pigment{colour Red}
>>Ger
Something like this:
difference
    cylinder
        <-10, 0, 0>
         <10, 0, 0>
        1
        pigment{colour Red}
    plane{y, 0
	pigment { color Green }
Date: 1 Oct 2005 19:02:56
Message: <433f15a0$1@news.povray.org>
You aren't understanding what I need to do... Here is a better example...
difference
    union
        cylinder{-x, y, 1 pigment{Red}}
        cylinder{x, -y, 1 pigment{Yellow}}
    plane{-y, 0}
    cutaway_textures
This works fine, but I have actually found out that my problem is that
instead of a simple plane, I was trying to cut the object with an
intersection as follows:
difference
    union
    intersection
        plane{-y, 0}
        plane{-y, 0 rotate<60, 0, 0>}
    cutaway_textures
Rarius
Date: 2 Oct 2005 02:31:56
Message: <ygav3TAp33PDFwa6@econym.demon.co.uk>
>difference
>    union
>    intersection
>        plane{-y, 0}
>    cutaway_textures
It looks like cutaway_textures doesn't work if the cutting object itself
is compound. Is this a bug?
If your cutting object is an intersection, you can work round it like
this:
#declare Thing = union
union {
  difference {
    object {Thing}
    plane{-y, 0}
    cutaway_textures
  difference {
    object {Thing}
    cutaway_textures
Or if the cutting object is a union or merge, rather than an
intersection, do this:
union {
  difference {
    object {Thing}
    plane{-y, 0}
    cutaway_textures
If the cutting object is a difference, use the same method as for
intersection but add "inverse" to the second object.
Mike Williams
Gentleman of Leisure
Date: 2 Oct 2005 03:35:50
Message: <433f8dd6$1@news.povray.org>
> union {
>   difference {
>     object {Thing}
>     plane{-y, 0}
>     cutaway_textures
>   difference {
>     object {Thing}
>     cutaway_textures
I don't think that would have the desired effect in some cases. Here's what
I would do:
#declare cutpart = intersection
    plane{-y, 0}
union
    difference {
        cylinder{-x, y, 1}
        object {cutpart}
        pigment{Red}
     difference {
        cylinder{x, -y, 1}
        object {cutpart}
        pigment{Yellow}
 - Slime
 [ http://www.slimeland.com/ ]
Date: 2 Oct 2005 06:29:45
Message: <433fb699$1@news.povray.org>
As I said in my original post... My main object is too complex, with too
many textures to difference each part seperately.
As Mike said, it appears that cutout_textures acts very strangely if the
second part of the difference or intersection is a compound object...
sometimes it works sometimes it doesn't!
Rarius
> what
> I would do:
>    plane{-y, 0}
> union
>    difference {
>        cylinder{-x, y, 1}
>        object {cutpart}
>        pigment{Red}
>     difference {
>        cylinder{x, -y, 1}
>        object {cutpart}
>        pigment{Yellow}
> - Slime
Date: 2 Oct 2005 15:58:34
Message: <rEJpOHAYrDQDFwjT@econym.demon.co.uk>
So, does my method work with your complex main object?
Mike Williams
